01-01-2007, 08:34 PM | #1 |
Member#: 52890
Problems re-starting my car when its warmed up????
I have been getting problems with the fact that once the car fires up and i go out for a run 10-20 mins or so the car will not re-start? I bought another battery as the old one i had went dead a couple of times however that battery was less than a year old and with less than 5 k on it. So the new battery i got, i made sure it has better cranking power and still the same problem???? I have looked around to see if i have a bad ground but it all seems good and there is also no light coming on due to the alternator not charging. i also notice that the car starts fine once it has cooled down it just seems to do it when the engine gets hot? Any ideas guys?
01-02-2007, 08:08 AM | #2 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
This is with a Hydra... or... ?
You say it doesn't start. Does that mean it doesn't even crank, or does that mean it's cranking but not turning over? Assuming it can crank, and assuming a Hydra, what does "BATT" read while cranking? What battery is it? |
01-02-2007, 09:45 AM | #3 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
Needs more hot start "cranking enrichment" likely in the 70-100C coolant temp range. Some of the modified cars I've tuned need 25 in that range.
Thanks, Phil www.elementtuning.com |
01-02-2007, 12:44 PM | #4 | |
Member#: 52890
Car turns but wont fire up I only read on my computer with the last battery 11.7 I bought a duralast gold comes with a free jumpstart service |
01-02-2007, 12:44 PM | #5 | |
Member#: 52890
Cheers phil for awesome support i'll check it out |
01-02-2007, 12:47 PM | #6 |
Member#: 8512
South East
Yeah, sounds like the fueling Phil was talking about then.
01-02-2007, 03:51 PM | #7 |
Member#: 54918
01-03-2007, 01:52 AM | #8 |
Member#: 52890
yes i do, does that make a difference?
01-03-2007, 10:04 AM | #9 |
Member#: 54918
Yes for whatever reason those heads require a lot of hot cranking enrichment and act like they have high lift, high duration cams. 25-30 should do the trick for cranking enrichment.
01-03-2007, 02:59 PM | #10 |
Member#: 52890
I thought the JDM Ver8 sti heads had higher lift and dur than the us sti? i'm gonna try that out
Cheers Stu |
01-05-2007, 05:50 PM | #11 |
Member#: 121156
Vehicle:2006 18G'd Up WHITE DIZZLE |
yo scooby, I got a question to ask but your inbox is full!!
Car hesitant to start when already warmed up | ihavebettersound | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 15 | 04-14-2006 12:39 PM |
car not starting when its warmed up, help | adrian559 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 17 | 03-21-2006 01:42 PM |
('93-'01) warm up the car or not warm up? | Wrx0R | Impreza Forum | 58 | 04-03-2003 02:55 AM |
('93-'01) Weird problem when I try to start my car | Dobes | Impreza Forum | 13 | 09-16-2001 09:49 PM |
Weird sound when I started my car... | Alex RS | General Forum Archive | 3 | 03-20-2001 12:05 AM |
