Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 01-01-2007, 09:44 PM   #1
snowcrzy
Member#: 110895
Default What spark plugs should I use?
I want/need to replace my spark plugs and I'm just looking for suggestions on which ones to use. Any difference?
stock ej20 lots of mods.
I did a search...
snowcrzy is offline   Reply With Quote
Old 01-01-2007, 09:54 PM   #2
AlboWRX
Member#: 37719
2003 WRX
Post your mods.
AlboWRX is offline   Reply With Quote
Old 01-01-2007, 09:59 PM   #3
AllAWD
Member#: 17079
Probably the stock plugs unless you are recommended otherwise for your mods by your tuner.
AllAWD is offline   Reply With Quote
Old 01-01-2007, 10:00 PM   #4
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
You did a search but..
a. You didn't post in the right forum
b. You didn't read the sticky post all about Spark Plugs in the Newbies, 2.0, 2.5, and Service Forums. It's posted in FOUR FORUMS buddy.....let's try to read it, mmmkay?
Now I gotta move this to the right forum....once you are there, you might want to visit the stickys.
Old 01-01-2007, 10:03 PM   #5
snowcrzy
Member#: 110895
VF 39 for one more day then aps sr40
pinks - injectors
Walboro - Fuel pump
aps dr650 - Fmic
aps 60mm - cai
samco - inlet
catless - header-back
acessport - vf34 map - !non tuned!
6 speed
Old 01-01-2007, 10:04 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I did a search...
ngk bkr7e...gap at .028" - .030"
replace every 15-20k miles or as needed
Old 01-01-2007, 10:05 PM   #7
snowcrzy
Member#: 110895
a. my bad
b. I am a "specialist" I don't go in the newbie sections
I am asking for peoples opinions that might not be on a "sticky".
Old 01-01-2007, 10:21 PM   #8
snowcrzy
Member#: 110895
http://forums.nasioc.com/forums/showthread.php?t=518633
Unabomber, you should add to your "sticky" a spark plug table that tells me which is the perfect spark plug for my setup. That way when people ask something like, "Any suggestions on which spark plugs to use" there would be a purpose to responding how you did.
Which type should I use?
That depends on how often you are interested in changing the spark plugs. Conventional spark plugs generally last one year. Platinum or iridium can last, depending on manufacturer specifications, up to seven years.
That doesn't tell me which type I should use... next!
Old 01-01-2007, 11:04 PM   #9
AlboWRX
Member#: 37719
2003 WRX
You want a one step colder spark plug. I recommend NGK BKR7E Stock # 6097 gapped at 0.28. Thats what I was recommended by my tuner. Keep in mnd that these are copper and they need to be changed out every 10k or about every year.
Old 01-01-2007, 11:54 PM   #10
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
I dont list what to use as if you read the ENTIRE FAQ, you should come to the realizaton that if you use spark plugs from your lawn mower or Triple iridium, laser, ninja, 7 step colder T-G mofo plugs or OEM units with 52,000 miles on them....you will have the same HP.
What kind of spark plugs should I use? WRX_MAVERICK Newbies & FAQs 14 04-11-2010 07:42 PM
what spark plugs should i get? thetomstudley Alaskan Impreza Club Forum -- AKIC 21 06-06-2008 12:09 AM
what spark plugs should I use for over 550+whp on 2.5L WRXINTX Built Motor Discussion 20 08-09-2006 01:45 PM
EJ257 Shortblock w/EJ20 STi Ver III heads - What Spark Plugs should I be using??? mykrrrr Subaru Conversions 14 08-10-2004 05:04 PM
What spark plugs should I get 2.5rsMI Normally Aspirated Powertrain 19 07-08-2001 11:45 AM
