Old 01-01-2007, 09:40 PM   #1
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
Default i think i need a new tranny?
well just went driving today and suddenly NO second, third, fourth or fifth gear went it. it was stuck good. after a good minute or so, i drove it on first and it slowly went into 3,4, and 5. when i got home, it's only stuck on first, so i'm guessin' my tranny is crapped out. any advice is needed.
choung
illegal2.2 is offline   Reply With Quote
Old 01-01-2007, 09:46 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
6MT time!
fibuz is offline   Reply With Quote
Old 01-01-2007, 11:15 PM   #3
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Clutch or shift-forks perhaps? Also may want to check your linkage for the obvious...
xcntrk75 is offline   Reply With Quote
Old 01-01-2007, 11:40 PM   #4
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
The shifter was stuck, or would the gears just not switch no matter where you moved the shifter?
Wiscon_Mark is offline   Reply With Quote
Old 01-02-2007, 08:59 AM   #5
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Oh... this is an auto?
Old 01-02-2007, 09:12 AM   #6
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
I don't see how, as that years auto would be a 4EAT....and who would swap a modern 5EAT etc into a 97
Old 01-02-2007, 11:58 AM   #7
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
^ .... Doah... (smacks head)
Old 01-02-2007, 12:05 PM   #8
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
no, it's a 5mt. anywho, this morning the shifter will not go into any gear. plans are already made with my buddy. getting a low miles my00 rs tranny about 35-40k put in tommorow with new shift linkage. probably tear out the tranny and see what the hell was going on???
choung
Old 01-02-2007, 12:27 PM   #9
sha_zapple
Member#: 41012
1998 Legacy L
have you at least checked the fluid (or lack thereof) or the shifter forks before you go nuts with a new one?
sha_zapple is offline   Reply With Quote
Old 01-02-2007, 12:37 PM   #10
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
i changed the fluids about a year ago with uncle scotty's mix. as the shifter fork, i'll check that tomorrow since i'm at work all day today
choung
Old 01-07-2007, 08:39 PM   #11
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
well plans with my buddy was canceled since he needed his tranny. i was lucky enough to pick up a 97 OBS 4.11 tranny. some say that it has shorter 5th gears so eh, we'll see. took approx. 9-10 hrs to take out and put in the tranny. i wish i should have taken pictures for others to see how easy this is to do. called in at dealership for a tranny job, about 600-1000 :O
Old 01-07-2007, 09:47 PM   #12
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Shorter than previous Impreza/Legacy trannys that were 3.9FD
But it's the same as your 97LGT.
Old 01-08-2007, 11:23 AM   #13
linsavy
Member#: 11620
1997 GF4-STiV3 clone
A 97 OBS 5spd with 4.11? IIRC...Manuals had a 3.90 and auto's had the 4.11.
You might want to double check that ratio.
linsavy is offline   Reply With Quote
Old 01-08-2007, 12:48 PM   #14
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
I know that the 97-99 Outback trans uses the same 4.11 final drive and the same 1-4 ratios as the GT, however 5th is different, it's 0.871 in the outback and 0.78 in the GT.
The 2.5 RS transmission uses the same ratios as the GT, and the same 4.11 final drive. The 2.2l Impreza uses the same ratios with a 3.90 final drive, I can only assume that the OBS would have this setup, being a 2.2l car.
Here are the breakdowns (copied from RS25):
You have a WIDE range of trannies to choose from.
None is better than the other aside from gear ratios and syncro wear rate. But it depends on usage.
All the manual tranny MY96+ Imprezas run the same gearing 1st - 5th (2.2L & 2.5L engine models). The only difference is that the MY96-MY01 Impreza L's run a 3.900 final drive, while the MY98-MY01 2.5RS runs a 4.111 final drive.
The manual tranny MY93-MY95 2.2L Impreza's run a 4.111 final drive, but they have a different 2nd - 4th gear ratio.
So it's your choice in final drive and gearing.
MY93 - MY95 Impreza L/LS/Brighton manual transmission with 2.2L engine:
1st - 3.545
2nd - 1.947
3rd - 1.366
4th - .972
5th - .780
Final Drive: 4.111
MY96 - MY01 Impreza L manual transmission with 2.2L engine:
1st - 3.545
2nd - 2.111
3rd - 1.448
4th - 1.088
5th - .780
Final drive: 3.900
MY98 - MY01 Impreza 2.5RS manual transmission with 2.5L engine:
1st - 3.545
2nd - 2.111
3rd - 1.448
4th - 1.088
5th - .780
Final Drive: 4.111
The MY96+ will have a better gearing than the older models. If you get the 2.5RS tranny, it will have a shorter final drive ratio of 4.111. The older model may have the 4.111, but the gearing makes it fall out of the powerband on the 1st-2nd shift and it isn't geared as short through gears 1-4. The MY96+ is geared better 1-4th gear but you'll have to decide if you want 4.111(2.5RS) or 3.900(Impreza L). The OTHER tranny that is nicer than all is the MY97-MY99 Legacy Outback tranny. It runs a 4.111 AND has a shorter 5th gear ratio.
MY97 - MY99 Subaru Legacy Outback manual transmission with 2.5L engine:
1st - 3.545
2nd - 2.111
3rd - 1.448
4th - 1.088
5th - .871
Final Drive: 4.111
Dan Cech is offline   Reply With Quote
Old 01-08-2007, 01:58 PM   #15
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Thanks for the info, Dan. Looks like I was mistaken about a few things...
Old 01-08-2007, 02:01 PM   #16
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
ahhh i picked up the right one. my buddy talked to me and said he wanted a trade now with the other impreza tranny with 40k.
drove the car today about at 60mph, freakin' 2900rpm's!
Old 01-08-2007, 02:05 PM   #17
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
That sounds like a bad clutch...
Old 01-08-2007, 02:16 PM   #18
subielicious02
Member#: 133964
1991 legacy
gold brown champagne ish
yea first chech the easiest, look at your linkage.i need new bushings and i have to do alittle persuasive action sometimes to get it into gear. ya just gotta know how to work it. then i would check the tranny out.
subielicious02 is offline   Reply With Quote
Old 01-09-2007, 03:17 PM   #19
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
mark, i don't think it's the clutch. the clutch was replaced about a year ago with a stage 1 excedy as i posted on sl-i. I think that the rev's are high due to the new outback tranny.
choung
Old 01-09-2007, 04:26 PM   #20
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Yeah, I remember you telling me about your exedy at LaCrosse. Considering your other symptoms, it's not clutch.
I think I need a new monitor...which kind? JGard Off-Topic 45 11-27-2009 02:25 PM
Do I need a new tranny or a new clutch? axleon2 Transmission (AT/MT) & Driveline 3 10-02-2007 03:26 PM
I think I need a new horn.. MattDell Mid Atlantic Impreza Club -- MAIC 19 09-05-2002 09:34 AM
Help- need a new tranny Hojai Transmission (AT/MT) & Driveline 4 08-16-2002 01:15 AM
