Old 01-02-2007, 02:41 PM   #1
MorallyBass
Member#: 58094
2004 WRX STi
Default Swaybar Advice? w/ new Ohlin Fixed-Perch Struts
Hi Guys,
It's getting to be time to replace struts, and I've decided to upgrade all around to the Ohlins fixed-perch setup. While I'm doing all that labor, I thought I should re-evaluate swaybars as well. I've decided to stick with the stock springs/tophats. I've got about 63k miles on the 04 STi, looking for streetability with occasional (5-6 times a year) autocross and ice racing. I'm not completely happy with the degree of understeer on the stock STi setup, so contemplating a stiffer rear swaybar.
Advice on brands and setup? Thanks.
-Winfield
MorallyBass is offline   Reply With Quote
Old 01-02-2007, 03:13 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Look also at the front sway. I know it goes against conventional thinking when it comes to sways, but a quick search here will reveal some interesting information.
As for the rear - given that you'll be rolling on stock springs I suggest a 22mm solid rear bar. That will equate to about a 23.5ish in the commone hollow bars out there.
I must also encourage you to replace your rear endlinks.
Old 01-02-2007, 03:35 PM   #3
MorallyBass
Member#: 58094
2004 WRX STi
turnin - thanks!
I don't know much about endlinks, could you elaborate on your comment there?
Old 01-02-2007, 05:18 PM   #4
ddunk12
Member#: 116596
2012 STI
I just put on whiteline 27mm adj. front and 24mm adj. rear sways and they are godly. I have basically zero body roll now and my car just sticks. Oh yeah and i havent noticed any understeer. should also point out that Im on RCE springs.
[quote=I don't know much about endlinks, could you elaborate on your comment there?[/QUOTE] <- morallybass
He means the stockers will eventually break with the beefier sway so you should upgrade.
Most people seem to like kartboys.
Edit. qoute screwed up for some reason.
ddunk12 is offline   Reply With Quote
Old 01-02-2007, 05:44 PM   #5
REACT
Member#: 103587
add an end ] after the first [QUOTE= and capitalize it.
REACT is offline   Reply With Quote
Old 01-02-2007, 06:41 PM   #6
Turn in Concepts
Member#: 93646
Many Track Records
<- morallybass
Just remember - you can still understeer if you go in too hot and exceed the lateral grip of your tires. I'm really good at this if you want a demonstration some time.
I have an idea to lessen this, but it's gonna take a g-meter to get actual measurement numbers. I've been thinking about this little guy:
http://3dyn.com/products.html
Old 01-02-2007, 07:39 PM   #7
ddunk12
Member#: 116596
2012 STI
I know you can still understeer its just not very bad. I love a demonstration sometime if I werent located in florida.
Oh yeah that little device seems pretty sweet kinda expensive though.
Old 01-02-2007, 07:44 PM   #8
Turn in Concepts
Member#: 93646
Many Track Records
Read everything that it does, and you'll see that for what you get it's not that bad. We really need to get one before the dragon meet so we can map the dragon and share it with others. I gotta look to see if that model does elevation or if I need to get one of the uprated ones for that.
Old 01-02-2007, 07:51 PM   #9
ddunk12
Member#: 116596
2012 STI
If I had the money I would buy it (would be fun to play around with) but I'd rather finish upgrading my suspension first. Plus Im runnin real low on funds.
Old 01-02-2007, 11:28 PM   #10
LOLSTi
Member#: 51452
2004 Subaru WRX STi
1992 Mazda Miata
I'd be willing to pitch in. That's way too cool.
LOLSTi is offline   Reply With Quote
Old 01-05-2007, 01:16 AM   #11
chudlo
Member#: 15505
2002 JDMV8 STI Wagon
OMG! I soooo want to know what my car is doing on the Dragon! I never thought of using data aquisition like that. VERY good idea.
Mmm....Now I want to know how Porter car is doing on those roads....
PS Hope to see you there!
chudlo is offline   Reply With Quote
Old 01-05-2007, 10:28 AM   #12
Turn in Concepts
Member#: 93646
Many Track Records
Yes you can!!! I will vouch for Clint being able to defy all odds and still be able to do this.
Tony
Old 01-05-2007, 10:58 AM   #13
waktasz
Member#: 86356
2015 s1000r
wheelie monster
That's actually really cheap for what it does...BUT, I'd have a hard time autocrossing with my laptop in the passenger seat.
waktasz is offline   Reply With Quote
Old 01-05-2007, 07:50 PM   #14
ace996
Member#: 79874
2006 STI
GreyDragon
No laptop...use a pocketPC...with Bluetooth.
ace996 is offline   Reply With Quote
Old 01-05-2007, 07:52 PM   #15
waktasz
Member#: 86356
2015 s1000r
wheelie monster
ooo. I actually have an extra one of those that gets no use since I have a blackberry. I'll report back with details, I think I'm gonna have to buy this
FS : Ohlins Fixed Perch Struts for 2005-2007 STI Brand New! speedmonkey Suspension/Brakes/Handling 2 06-01-2010 02:40 AM
FS : Ohlins Fixed Perch Struts 2005+ STi Brand New! speedmonkey Tri-State Area Private Classifieds 0 05-31-2010 03:06 PM
Ohlins fixed perch struts for '02-'06 WRX and '04 STi JDM addict Car Part Reviews 83 04-11-2009 11:01 PM
fs ohlin fixed perch struts KOPFJAGER Suspension/Brakes/Handling 6 09-19-2006 11:55 PM
