Old 01-02-2007, 05:43 PM   #1
o2sys
Member#: 43842
200? WRX STI
Default USDM STI not compatible with ECUexplorer?
Ok i recently upgraded to STG 2 using Open ECU. Everything was easy and everything went pretty smooth. Now i want to data log my car to see if the changes are hurting my car or not. I am trying to use ECUeplorer and under tools and ecuflash i dont see a tab for USDM STI. Then what do i use? Also i read something about pressing the defog switch (im assuming is the rear defog switch) help me please~~
thank you!
o2sys is offline   Reply With Quote
Old 01-02-2007, 06:40 PM   #2
k mier
Member#: 98000
05 sti [email protected]
You can set the defrog switch to start data logging in ecuexplorer, under realtime data view, bottom pane. Can also enable knock signal there. Engine load is ff4f48 for 05' sti.
k mier is offline   Reply With Quote
Old 01-02-2007, 06:40 PM   #3
Freon
Member#: 88322
2009 BMW 135i
You have to use Ecuflash to flash.
You can use ecuexplorer to log, but not flash. Ecuexplorer is no longer under development, though it does work for what it does.
Freon is offline   Reply With Quote
Old 01-02-2007, 09:30 PM   #4
o2sys
Member#: 43842
200? WRX STI
yea i already used ECUflash to flash my ECU. Im just trying to log and on the top left panel it says ECU(disconnected) am i suppose to have the test connectors plugged in while doing this?
Old 01-02-2007, 09:41 PM   #5
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
You do not need to have the test connectors plugged in to log. In fact, you can even download the ROM without them. The only thing you need them plugged in for is flashing.
Make sure that you have the right port selected in the bottom left corner of the screen. You should see your tactrix cable connection listed there.
Ziggyrama is offline   Reply With Quote
Old 01-04-2007, 02:58 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
left click on the bottom left panel where is says disconnected there is an important setting in there
02/03/V7 struts not compatible with 04/V8 hats/springs Arnie Brakes, Steering & Suspension 235 01-10-2016 08:52 PM
JDM AVCS Solenoid... is the USDM STI one compatible? InfamousDX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-23-2007 06:33 PM
02 WRX front brackets & rotors not compatible with 02 RS calipers DrBoy01 Brakes, Steering & Suspension 2 04-29-2005 05:54 PM
HELP!! Autometer A/F guage not compatible with 2002 WRX wide band O2 sensor?? aznfoos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-09-2004 09:28 PM
PocketLogger not compatible with 99RS? Warp3 Service & Maintenance 3 06-14-2002 09:18 PM
