Old 01-03-2007, 03:34 AM   #1
NLspiked02
Member#: 127345
2004 Impreza WRX STi
WRB/Bronze BBS Rims
Default Ecuteck
i have been reading alot about engine managment on the forums and web sites. seems that alot of ppl are going with protune (COBB?). i called the local dyno shop to me and he said that i should go with an ecuteck. why the protune? why not ecutek? what system is better or worst than the other and why? should i be going with the protune and find another dyno?
my mods
2004 STi
3" turbo back exhaust
FMIC
short ram intake
12.7 lbs flywheel
excedy clutch
i hope i dont get flamed to bad for this question...
NLspiked02 is offline   Reply With Quote
Old 01-03-2007, 07:59 AM   #2
Schnitz
Member#: 119499
2006 STI
This should be in the 'Engine Management & tuning' forum. That dyno shop either only deals with Ecutek or they don't have as much experience with Cobb.
That's about a Stage 2.5 (only because of the FMIC) you have there. From all my research Cobb is the way to go at this stage. I am hoarding parts right now to be ready for Stage 2 come spring. Do a little more research and I'm sure you'll come to the same conclusion.
Schnitz is offline   Reply With Quote
Old 01-03-2007, 09:36 AM   #3
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
There is not much difference between the two systems with the exception of the accesport with allows you to switch maps. Ecutek has the easy ECU now which allows you to do the same thing though and the data logging is probably the best you can get. Both will get you roughly the same power if tuned the same
Mistake on ECUteck Website Chaste Automotive Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-21-2009 10:20 PM
FL: Vishnu Tuned Ecuteck ECU for sale! two_ton_tammy Private 'For Sale' Classifieds 2 09-29-2003 04:17 PM
Cobb,Ecuteck,Utec,.... t-kid Engine Management & Tuning 9 07-13-2003 10:28 PM
ECUTeck Sub-zero review dandbest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 02-12-2003 07:58 PM
