Old 01-03-2007, 04:03 AM   #1
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
Default Best spark plugs to use with vf34 setup?
in the process of installing my vf34 on my wrx; just wondering what the best spark plug to use with the turbo is? im trying to prevent pinging at high boost. any suggestions and where to buy/order would be appreciated.
Cusson is offline   Reply With Quote
Old 01-03-2007, 04:13 AM   #2
02blueWRX
Member#: 52817
04 STi - Whateva
- I do what I want!
you can never go wrong with NGK Iridium one step colder...
02blueWRX is offline   Reply With Quote
Old 01-03-2007, 04:15 AM   #3
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
those are definately ones i was considering
Old 01-03-2007, 04:18 AM   #4
02blueWRX
Member#: 52817
04 STi - Whateva
- I do what I want!
can be purchased here:
http://www.oakos.com/Merchant2/merch...ct_Code=NGKBKR
or check vendor listings as well..
Old 01-03-2007, 04:42 AM   #5
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
thanks for the link
Old 01-03-2007, 05:28 AM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
that's what I have had for the last several times. Just be careful when you gap them and you will be fine. When I got them out of the box they were gaped at .037 or something. If simply installed it will hesitate and cause p0447 or rich error with a fuel cut like feel around 4k rpm @ wot. Mine are gaped at .032 and I don't have any problems.
Old 01-03-2007, 06:03 AM   #7
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
maybe on a STi but since he has a wrx he NEEDS copper 1 colder at .028 ir are very knock prone
AWDWRXLOVER is offline   Reply With Quote
Old 01-03-2007, 06:43 AM   #8
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
+1 go for the coppers. You will have to change more often but you get better performance from them. I think they are BKR6E. These are what I run with my VF22. No problems and I always by 8 so I will have some for later. They are only like $1 and some change.
breathinez is offline   Reply With Quote
Old 01-03-2007, 09:19 AM   #9
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Silverstones are also a very good choice. They will last longer than coppers and have better conductive properties.
Check nology.com
blkscooby is offline   Reply With Quote
Old 01-03-2007, 10:25 AM   #10
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Best place to post a question that has been discussed 9000 times? The appropriate forum!
Best spark plug? Maybe reading the sticky at the top of the appropriate forum.
Best spark plug advice? Referring to your tuner's advice.
Old 01-04-2007, 03:58 AM   #11
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
NGK BKR7ES-11 gap .28
I change mine every 5,000 miles, they cost like $10 a box of 10 or something they are cheap but they work well in my engine.
PaulRex is offline   Reply With Quote
What spark plugs to use?? wombatsauce Bay Area Impreza Club Forum -- BAIC 4 04-14-2003 05:36 PM
what spark plugs to use? Impreza25RS Normally Aspirated with bolt-on Forced Induction Powertrain 10 11-02-2002 02:20 PM
what spark plug to use? Hojai Normally Aspirated with bolt-on Forced Induction Powertrain 15 07-12-2002 10:55 AM
the best spark plugs to use wrextuner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-12-2002 02:14 PM
Spark Plug for use with nitrous?? Supapooh Normally Aspirated Powertrain 8 02-22-2002 09:19 PM
