Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Vancouver Impreza Club
Old 01-03-2007, 01:15 PM   #1
deaton
Member#: 126368
Default Burnt out fog light
Hey guys,
One of my fog lights is burnt out. What's the easiest way to get a replacement, and how hard is it to change it yourself (what tools are needed to get in there)? I've never really done much on my car before besides change tires and oil, so I don't know!
Thanks.
deaton is offline   Reply With Quote
Old 01-03-2007, 01:19 PM   #2
crashfx
Member#: 34887
03 WRX RIP
Gas Guzzling Wh0^e
Easy...and a good time to upgrade your lights! It's a standard off-the-shelf bulb.
Surprisingly, there is a section in your owners manual that covers it (towards the back section 12?). Basically, a screw-driver, and a ratchet (IIRC). About a 5 minute job.
Good luck.
crashfx is offline   Reply With Quote
Old 01-03-2007, 01:23 PM   #3
deaton
Member#: 126368
Thanks!
Old 01-03-2007, 02:16 PM   #4
bezerk
Member#: 44809
2008 BMW M3
SATURDAY!!!!!!!!!!!!!!!
Make sure you have the correct size screw driver....the screws strip easily if you are using one that is too small. And yes, very easy to change....did it all the time at the drag strip for my home-made "ram-air" intake system.
bezerk is offline   Reply With Quote
Old 01-04-2007, 02:44 AM   #5
deaton
Member#: 126368
Make that fog lights, plural, now that I look closer.
I'm looking at buying Hella Yellowstars. It sounds like you can get away with 85W ones in the 55W-rated stock lamps... can anyone counsel me either way?
Old 01-04-2007, 09:25 PM   #6
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
my 1999 had 85W bulbs in the regular lamps, and blew a fuse. mind you, i bought it that way, and i have no idea how long they were in for, might have been a bad fuse/something else.
my .02
i'm sure there are others who have experience with the bugeye fogs though
FunkMasta is offline   Reply With Quote
Old 01-04-2007, 10:09 PM   #7
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
You run the risk of melted wires and/or starting a fire when running a higher wattage bulb in the stock wiring harness. You could also melt the housing.
Unless you're planning on running thicker gauge wire pulled directly from the battery, I wouldn't recommend running 85W bulbs. Stick with the stock wattage.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Burnt out dash lights steven765 Baja Forum 6 09-21-2009 10:25 PM
2006 WRX Burned out fog light FearTheTurtle Electrical & Lighting 1 08-21-2007 12:55 AM
Burnt out Fog Light button Skylab Electrical & Lighting 6 03-16-2004 06:47 PM
Burnt out fog creature546 Electrical & Lighting 1 06-01-2003 01:33 PM
Burned out fog light spriggan Legacy Forum 4 04-26-2003 01:59 AM
