Old 01-03-2007, 03:49 PM   #1
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
Default Oil wont stop leaking
changed my oil a few days ago; replaced the oil plug washer and reused the oil plug. now im noticing puddles of oil on the floor of my garage. i jacked the car up and noticed the oil was leaking from the plug. i tightened the plug but the oil is still leaking. ive had the problem before after oil changes, im just wondering what the best solutions is? i really dont want to drain my whole system again...
Cusson is offline   Reply With Quote
Old 01-03-2007, 03:53 PM   #2
Rev1
Member#: 51240
08 Lexus IS350
Are you putting the crush washer the correct way? What did you torque down the oil drain plug to?
Maybe you have stripped oil pan threads or something...
Rev1 is offline   Reply With Quote
Old 01-03-2007, 03:56 PM   #3
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
the oil pan threads arent stripped; the plug still fits nice and snug, just fine. i wasnt aware there was a correct way to put the crush washer? i just put it on the plug and installed. what should the proper torque specs be?
Old 01-03-2007, 04:01 PM   #4
Rev1
Member#: 51240
08 Lexus IS350
IIRC, the stock Suby washer is two concentric rings bonded together... you put the wider ring towards the plug, and the smaller concentric ring towards the pan.
Also, did you make sure the drain plug doesn't have an old crush washer stuck to it?
Search the forums for the torque specs, don't remember it off the top of my head.
Old 01-03-2007, 04:15 PM   #5
Hagbeard
Member#: 40286
'04 WRX Sedan
Platinum Silver
36 ft-lb. Huge for a drain plug.
Hagbeard is offline   Reply With Quote
Old 01-03-2007, 04:33 PM   #6
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
seems like a lot?
Old 01-03-2007, 04:38 PM   #7
Rev1
Member#: 51240
08 Lexus IS350
Found it, it's 33lb-ft for the oil drain plug.
Old 01-03-2007, 05:06 PM   #8
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
thanks - ill go see if my plug is remotely close to that torque...
if the plug is tight enough and the leak continues, do you guys suggest i drain the whole system and start with a new washer?
Old 01-03-2007, 05:10 PM   #9
steeter
Member#: 47632
2013 WRX 4dr
Dark Grey
Unfortunately yes.
However, I would try to save the oil by emptying into a clean container...may only loose a little. No need to change the filter....
Steve
steeter is offline   Reply With Quote
Old 01-03-2007, 05:22 PM   #10
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
Originally Posted by steeter View Post
Unfortunately yes.
Steve
yea i was hoping to reuse that oil if that was the scenario
Old 01-03-2007, 06:49 PM   #11
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
It may be a burr on the oil pan or oil pan bent.Some teflon tape around the threads always works too.
crampfan is offline   Reply With Quote
Old 01-04-2007, 08:11 AM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.....the washer has a flat side and a rounded side-----it ya look......the flat side goes toward the bolt head....the rounded side towards the pan.
Old 01-04-2007, 03:40 PM   #13
ronan1975
Member#: 72380
2009 F-150
Green
When I used the factory 33 lbs on the torque wrench it would still leak. I Slowly increased the torque a couple of pounds each day until it stopped leaking(40lbs) For the last few oil changes I have gone straight to 40lbs and there have been no leaks.
The crush washer will leak if you over or under tighten.
ronan1975 is offline   Reply With Quote
Alarm wont stop going off, car wont start!! felixk Car Audio, Video & Security 3 08-20-2009 06:10 PM
Tape deck wont stop spinning? joshuagore Interior & Exterior Modification 2 01-21-2005 08:16 PM
97 legacy hazards wont stop blinking. please help another_97 Electrical & Lighting 3 02-06-2004 01:13 PM
Okthe misfire codes wont stop.. cronic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 11-11-2003 06:22 PM
Car wont stop dying! RocketFuel Service & Maintenance 10 06-09-2003 11:59 PM
