Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 01-03-2007, 04:21 PM   #1
Coolingmist
Vendor Sales Rating: (0)
Member#: 67024
2009 BMW 135 I
space grey
Default Methanol and Water Injection Systems by Coolingmist
Thanks for reading this. www.coolingmist.com is a leading manufacturer of Methanol/Water injection systems. Our phone # is 888-MORE-HPW or 770.416.1041. We accept all credit cards and paypal. For those of you that dont know, Methanol/Water Injection is a concept where a fluid (water/methanol or a mix of both) is injected into the intake tract of your vehicle, usually after your intercooler. The water evaporates and soaks up the heat....this gives you very cold combustion temperatures which leads to more timing, more power and the ability to run more boost. If you tune your vehicle with the methanol injection you will gain even greater power.
We have many products, however our best selling products have been our trunk mount kits.
The picture below is of our standard kit. Compared with other kits on the market this kit is really easy to install. Our signature 1.5 gallon tank contains the pump, boost switch, checkvalve and fittings. Its all done for you. Not much to do other than to give power to the red wire, ground the black wire and put your vacuum line over the port. The Injector simply taps into the intake tract if your vehicle. Very simple install. this goes in your trunk. It has a boost switch, you set at what ever setting you want, when your boost = or is greater than that setting it injects. It turns off when you drop below. This does not vary the flow, its on/off. The price is $369.95 and is a great deal.
Here is a link to the product:
http://www.coolingmist.com/detailmai...dardtrunkmount
Our Varicool trunk mount kit is set up similar but has our Vari-Cool Controller. This controller allows you to set a min boost and max. The system will then vary the flow between those two points. With a 10 position tuning curve and the ability to change the methanol/water curve you can be certain this is the only tuneable progressive controller on the market. You can also datalog if you have a laptop or our additional commander. The more boost you make, the more flow you get. This kit is priced at $599.95
http://www.coolingmist.com/detailmain.aspx?pid=varicooltrunk[/url]
[url]
To see recent dyno sheets on STI's with our Vari-Cool and a great tune please go here: http://www.coolingmist.com/info.aspx?key=Dyno
Call us today 888-MORE-HPW...we ship same day in most cases!
Coolingmist is offline
Closed Thread
FS: NJ Coolingmist Trunkmount Methanol Meth Water Injection Kit Trunk Mount bmw50021 Engine/Power/Exhaust 5 11-02-2008 03:30 PM
Methanol and Water Injection Systems by Coolingmist Coolingmist Engine/Power/Exhaust 95 07-12-2007 01:22 PM
brand new coolingmist dual stage water injection system anthonyrb98 Engine/Power/Exhaust 17 03-06-2007 12:16 AM
coolingmist water injection systems w.zaluski Water/Methanol Injection, Nitrous & Intercooler Cooling 1 09-05-2006 03:27 AM
coolingmist METHANOL/WATER Injection systems Coolingmist Private 'For Sale' Classifieds 0 07-06-2006 08:54 PM
