Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 01-03-2007, 04:28 PM   #1
Coolingmist
Vendor Sales Rating: (0)
Member#: 67024
2009 BMW 135 I
space grey
Default Methanol and Water Injection Systems by Coolingmist
Thanks for reading this. www.coolingmist.com is a leading manufacturer of Methanol/Water injection systems. Our phone # is 888-MORE-HPW or 770.416.1041. We accept all credit cards and paypal. For those of you that dont know, Methanol/Water Injection is a concept where a fluid (water/methanol or a mix of both) is injected into the intake tract of your vehicle, usually after your intercooler. The water evaporates and soaks up the heat....this gives you very cold combustion temperatures which leads to more timing, more power and the ability to run more boost. If you tune your vehicle with the methanol injection you will gain even greater power.
We have many products, however our best selling products have been our trunk mount kits.
The picture below is of our standard kit. Compared with other kits on the market this kit is really easy to install. Our signature 1.5 gallon tank contains the pump, boost switch, checkvalve and fittings. Its all done for you. Not much to do other than to give power to the red wire, ground the black wire and put your vacuum line over the port. The Injector simply taps into the intake tract if your vehicle. Very simple install. this goes in your trunk. It has a boost switch, you set at what ever setting you want, when your boost = or is greater than that setting it injects. It turns off when you drop below. This does not vary the flow, its on/off. The price is $369.95 and is a great deal.
Here is a link to the product:
http://www.coolingmist.com/detailmai...dardtrunkmount
Our Varicool trunk mount kit is set up similar but has our Vari-Cool Controller. This controller allows you to set a min boost and max. The system will then vary the flow between those two points. With a 10 position tuning curve and the ability to change the methanol/water curve you can be certain this is the only tuneable progressive controller on the market. You can also datalog if you have a laptop or our additional commander. The more boost you make, the more flow you get. This kit is priced at $599.95
Trunk mount controller kit! Easiest install on the market.
http://www.coolingmist.com/detailmai...=varicooltrunk
Our new Direct port Trunk Mount!
http://www.coolingmist.com/detailmai...pid=Directport
Call us today 888-MORE-HPW...we ship same day in most cases!
Coolingmist is offline   Reply With Quote
Old 01-03-2007, 09:30 PM   #2
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
bump!!
Old 01-05-2007, 03:19 PM   #4
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
For a limited time we are offering Free shipping on all kits $299 and up. Just call your order in at 888-MORE-HPW or 770.416.1041.
Thanks!
Old 01-07-2007, 10:15 PM   #5
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
Bump !
Old 01-09-2007, 07:42 PM   #6
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
Check us out at www.coolingmist.com or post with any questions.
Old 01-10-2007, 04:39 PM   #7
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
Here is an upclose picture of our digital controller (included in all Vari-Cool kits).
Old 01-11-2007, 10:50 PM   #8
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
Call us at 888-MORE-HPW with any questions.
Old 01-13-2007, 06:48 PM   #9
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
These kits are easy to install and the best bang for the buck! Check us out today at www.coolingmist.com.
Old 01-15-2007, 11:12 PM   #10
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
Call us toll free 888-MORE-HPW. No extra charge for paypal! Accept credit cards as well.
Old 01-17-2007, 06:17 PM   #11
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
Bump!
Old 01-22-2007, 11:11 AM   #12
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
check us out at www.coolingmist.com
Old 01-24-2007, 09:37 PM   #13
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
Anyone looking for a great kit check us out. Infact, check out the competition first and then check us out and you will be glad you did.
Trunk mount varicool controller
engine bay mount
Old 01-25-2007, 10:06 PM   #14
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
To see recent dyno sheets on STI's with our Vari-Cool and a great tune please go here: http://www.coolingmist.com/info.aspx?key=Dyno
Old 01-28-2007, 03:53 AM   #15
mikzcha
Member Sales Rating: (1)
Member#: 111439
2006 WRX tr
Originally Posted by Coolingmist View Post
engine bay mount
does this kit fit in the 06 wrx? i noticed the SMC kit goes where the older wrx's wiper fluid is. since i have a 06 the design under the hood in my car is different. do you have any pics of this installed in a 06? how easy is installation of this kit also?
thanks
mikzcha is offline   Reply With Quote
Old 01-28-2007, 04:31 AM   #16
mikzcha
Member#: 111439
2006 WRX tr
how do you tie down the trunk mount system? does it come with something to secure it?
Old 01-28-2007, 10:33 AM   #17
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
thanks
The trunk mount version is designed to be put in your trunk. Its simple, just strap it down. Its universal for every vehicle. If you want to use your stock tank, you can get a kit without a tank and just tap your WW or IC tank. The trunk mount has many advantages including capacity, ease of install and ability to prime correctly.
Old 01-28-2007, 10:36 AM   #18
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
It does not come with straps. Due to the configurations of different vehicles, we leave that up to the customer. We found that many customers want aluminum straps, many want just simple tie downs from the store. You can pick up style and color of straps you want very inexpensive at the auto parts store or home depot. The bungji style cords with hooks on the end are very easy to use.
Let me know if you have more questions, we are open today as well. 888-MORE-HPW.
David
Old 01-28-2007, 07:20 PM   #19
mikzcha
Member#: 111439
2006 WRX tr
with that engine bay mount kit where is that tank supposed to be installed? is there a preselected place or is that up to the consumer to place it where they desire?
Old 01-28-2007, 07:23 PM   #20
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
we can get you a kit without a tank and you can tap the bottom of the stock windshield tank (fitting included). Our 2 quart or 1 gallon tanks are pretty small, it would be up to the customer to mount if they want our tank. We have all the dimensions if you need them.
Thanks
Old 01-29-2007, 10:21 PM   #21
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
bump!
Old 01-30-2007, 04:36 AM   #22
mikzcha
Member#: 111439
2006 WRX tr
looks like a awesome kit i plan on getting the trunk mount system when i get some money!
Old 01-31-2007, 12:36 PM   #23
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
Old 02-01-2007, 10:06 AM   #24
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
bump!
Old 02-02-2007, 04:52 PM   #25
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
Check us out at www.coolingmist.com or call us at 888-MORE-HPW. We take sales orders 7 days a week!
FS: NJ Coolingmist Trunkmount Methanol Meth Water Injection Kit Trunk Mount bmw50021 Engine/Power/Exhaust 5 11-02-2008 03:30 PM
brand new coolingmist dual stage water injection system anthonyrb98 Engine/Power/Exhaust 17 03-06-2007 12:16 AM
Methanol and Water Injection Systems by Coolingmist Coolingmist Engine/Power/Exhaust 0 01-03-2007 04:21 PM
coolingmist water injection systems w.zaluski Water/Methanol Injection, Nitrous & Intercooler Cooling 1 09-05-2006 03:27 AM
coolingmist METHANOL/WATER Injection systems Coolingmist Private 'For Sale' Classifieds 0 07-06-2006 08:54 PM
