Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 01-03-2007, 06:23 PM   #1
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
Question ebay HID conversion kit w/ pics help
I got my kit in the mail and opened it this morning, placed the instructions aside, took everything to the garage, went out, and back to get instructions and have not seen them since.
Sice I lost my instructions, now I am lost as far as the install goes, here are some pics....
most of the kit....
seems simple enough to get the light inside the housing...then mount the ballast...
im pretty lost here...where does this all connect? wheres all the power located under my hood?
if any one has any input thanks
email convo with vendor...whos more retarded: me for losing instructions within 5 min of opening box ,or the vendor?
me: Hello, I recieved my kit this morning and noticed thre was a small instruction booklet. I cant seem to find it, and was wondering if there are any other instructions? thanks
vendor: Hi, There should be a install manual inside with it. Thanks!
me: Yes, there was, but I think i accidently threw it away =( I was seeing if
you have a copy as I am stuck installing them now
vendor: HI, Sorry but i don't have any extra to send you. Thanks!
VideoGameWrx is offline   Reply With Quote
Old 01-03-2007, 06:41 PM   #2
paulmofyourhand
Member#: 116355
2004 Impreza STI
bassboat JBP
OP: screw you, and i want to return this
then...
hid retrofit
paulmofyourhand is offline   Reply With Quote
Old 01-03-2007, 06:52 PM   #3
jezzy
Member#: 121883
The red would go to the battery positive (red) terminal.
The black goes to a chassis ground.
The 2 wires you indicate as "switch" are the leds that would fit into your headlight harness where you originally plugged it to the light bulb.
But nonetheless, you should do a real retrofit. It'll be brighter, but thats about it.. (ack! GLARE!)
jezzy is offline   Reply With Quote
Old 01-03-2007, 06:55 PM   #4
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
thanks that verifies the battery, but what/where exactly is the headlight harness? it should be close to the battery because the wire isnt that long?
why is one black and on red for the leds?
whats a real retrofit? lol I THOUGHT THESE WERE PLUG AND PLAY ******!
Old 01-03-2007, 07:24 PM   #5
jezzy
Member#: 121883
News
Originally Posted by VideoGameWrx View Post
thanks that verifies the battery, but what exactly is the headlight harness? I have to do one on each side, these wires are both together?
Hmm, I don't know what your bulb type is..
But when I got an H7 aftermarket HID kit, I had to use those 2 wires (the black and red) and plug them into the bulb connector. (The wire that you unplug from your lowbeam bulb, and these 2 wires would clip into where the bulb used to clip in)
As for a real retrofit. You're maybe running a pre-06 Subaru (which were non-projector housing based) and thus means you're Halogen (reflector) based. The 04-05 STI's were reflector HID kits.. sure it's bright, but there's no sharp cut-off line that a projector housing (and even better, an HID projector housing can provide).
Because you're running a rebased bulb to fit into your headlight (reflector), chances are that you'll have to lower your headlights (re-adjust them lower) so now to blind your on coming traffic. Read the threads, there's TONS of posts on this.
Hope this helps.
Old 01-03-2007, 07:35 PM   #6
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
its an H1..thats what i origally thought, but theres only 1 pair of these wires( coming out of the main center fuse thing from the first pic)? so what about the other side, also they dont seperate so it looks like the are supposed to go in the same place
Old 01-03-2007, 07:43 PM   #7
jezzy
Member#: 121883
I believe you only need to connect this to 1 side as it will only act as the "switch-ON" for your headlights. This will receive your signal from the headlight switch and thus will turn on your ballasts to turn on the lights.
Try it out. I'd remove the fuse in the HID kit that you got first (the fuses thats on the red line that goes to your battery terminal. Once everything's installed, re-install the fuse and switch on your headlights. Have your car running.
MAKE SURE YOU DISABLE YOUR DAYTIME RUNNING BEFORE ANYTHING ELSE!
Old 01-03-2007, 08:21 PM   #8
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
thanks, it worked! Just got to put it all together now, and fix my eyes, I looked at the bulb with nothing covering it and I feel like I just took 10000 school pictures
to disable the runnig ligths i just unpug the thing in the glove box right?
Old 01-05-2007, 06:58 AM   #9
jezzy
Member#: 121883
Correct. Behind the glovebox.
iBrite HID Conversion Kits - 10% OFF ANY HID KIT - Sonic Motor April Sale Sonic Motor Exterior/Styling 12 04-30-2010 08:58 PM
HID conversion kit HELP jonny5 Electrical & Lighting 0 11-26-2007 11:47 AM
HID Conversion Kits Help Googs211 Interior & Exterior Modification 1 04-29-2006 05:13 PM
HID Conversion Kit Help TecnoWRX Electrical & Lighting 5 01-21-2006 10:28 AM
FS: On EBAY 9007 McCulloch 5300K HID Conversion Kit Light BoyLunching Private 'For Sale' Classifieds 0 10-25-2004 02:50 AM
