Old 01-03-2007, 06:51 PM   #1
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
Default Transmission noise fixed! center diff bearing
I didnt want to hijack the other thread, but hres the background info..
http://forums.nasioc.com/forums/show....php?t=1147847
Thanks Jose (pacobeagle) for diagnosing and fixing the problem.
To sum it up, I had some strange whining noises coming from the tranny, and subaru quoted me 3500 to fix. I called up Jose and he suggested to put it on the lift and use a stethoscope. We found that most of the noise was coming from the center diff. He suggested that I order these 4 bearings:
top left G32204 roller bearing
top right G33008 roller bering
bot right G23017 ball bearing
bot left G25501 ball bearing
here are the ok bearings
and here is the one that was making all the noise (i think top right)
every single roller was out and lose in my assembly, jose found all 14 and put the new one in.
the transmission sounds awsome, I can finally hear the straight cut gears without that annoying whiine/whir
BTW my center diff was in good condition
Subaru inspected it and said it needed to be repalced a few months ago
VideoGameWrx is offline   Reply With Quote
Old 01-04-2007, 01:54 AM   #2
nich0lai
Member#: 111538
2003 wagon go vroom
bug covered
Glad it worked out for you, thanks for the info.
nich0lai is offline   Reply With Quote
Old 01-04-2007, 07:02 AM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Nice kill! And props to Jose for using his noodle!
Old 01-04-2007, 02:15 PM   #4
ThankZero
Member#: 73064
I'm pretty sure this is the noise my car is making. Should I just take it to a local tranny shop and have them listen to it? How much do you think the repairs will run if the problem is similar?
ThankZero is offline   Reply With Quote
Old 01-04-2007, 05:52 PM   #5
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
Well, the transmission doesnt have to be dropped to work on the center diff, so its fairly cheap(compared to breaking a gear). The actual bearing I needed was only 40 dollars ordered from subaru, but we replaced them all ($140) just to be safe. If your center diff is damaged (it hsouldnt be unless you autox), those run about 500 dollars. Shouldnt be more than 3-4 hours of labor in any case.
Old 02-16-2007, 12:45 PM   #6
ksouro1
Member#: 111977
It seems as if I am dealing with the same problem, but before i go ahead and do anything i want to get a professional to diagnose it. My question is, in the case that its just the bearings, will there be any further/significant damage done to the central differential if i continue to drive the car ?
ksouro1 is offline   Reply With Quote
Old 02-16-2007, 12:54 PM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Hey! Good job with the search.
I would be mor concerned with damaging the transfer drive and driven shafts than the center diff. Any time you have bearing failure you risk damaging the surface they ride on more than anything else.
For instance, front wheel bearings. When they go bad they tear the heck out of the hub unless you catch it early.
So, use your own judgement but I would not wait too terribly long.
Tim Sanderson is offline   Reply With Quote
Old 02-28-2008, 02:09 PM   #8
djart
Member#: 172877
Did it sound like this when it was bad?
http://www.youtube.com/watch?v=6YDR8OG-8YM
djart is offline   Reply With Quote
Old 09-29-2008, 11:48 AM   #9
SubieRon
Member#: 64485
2004 GGA
damn...i think i may have this problem
any write up on a DIY instead of taking into a shop?
SubieRon is offline   Reply With Quote
Old 11-10-2008, 06:38 PM   #10
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
bump because I think I have the same problem
medamullet is offline   Reply With Quote
Old 06-09-2010, 09:58 AM   #11
bmanke
Member#: 190434
Does anyone have a write up on the center differential repair without pulling the transmission? My 05 with 118,000 is whining pretty bad.......
bmanke is offline   Reply With Quote
Old 06-10-2010, 06:46 AM   #12
dkili2
Member#: 249057
thank you man
dkili2 is offline   Reply With Quote
Old 06-10-2010, 06:54 PM   #13
boostedscooby2002
Member#: 112589
2002 Subaru WRX
UR Stage3 fmic vf34
I know this is an old thread. But maybe it is the same problem I am having. Its an 02 vf34'd wrx with 108000 miles on it. I am getting a loud whinning sound only while under load/acceleration. It actually almost sounds like those wrc rally cars when they are accelerating. hehehe. When I take my foot off the gas, the whinning pretty much goes completely away. It used to do this quietly in first and second, but now it does it on all gears much louder it seems. Anybody?
boostedscooby2002 is offline   Reply With Quote
Old 10-15-2010, 07:52 PM   #14
ragejed
Member#: 76817
2005 WRX
+1 for this!
ragejed is offline   Reply With Quote
Old 12-15-2010, 03:48 PM   #15
redwrxviking
Member#: 185070
2002 WRX Wagon!
SRP on GOLD rims baby!
I have what sounds like the EXACT same problem as boostedscooby2002. Gear-ish sounding whine that increases pitch (not volume) with speed, only increses volume under increased load, and only has any volume from about 35-65 and no volume if not under load and no volume under deceleration, even if still in gear.
To recap, only gear whine while under load from 35-65ish, regardless of gear.
Anyone?
redwrxviking is offline   Reply With Quote
Old 12-28-2010, 01:09 PM   #16
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
folks
if anyone is looking for this bearing set, i've got BNIB FS here:
bearing set for 5mt center diff / transfer case
Old 07-31-2012, 05:31 PM   #17
robbyh
Member#: 326959
2004 wrx
black
Just thought I'd add some info to this post since I'm sure people are still using (like me) when they have a whining from under the car. i had a hard time looking up the parts cause the numbers listed but eventually the dealer traced all the number changes.
The updated part numbers for the bearings are:
G32204 roller bearing - Subaru Part# 806322080 subaru $56.68
G33008 roller bearing - Subaru Part# 806330120 subaru $49.24
G23017 ball bearing - Subaru Part# 806230170 $53.54
G25501 ball bearing - Subaru Part# 806255010 $62.06
Prices were from my local dealer so I'm sure they will vary some at other dealers.
robbyh is offline   Reply With Quote
Old 08-27-2012, 01:07 PM   #18
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
So if I am going to be replacing my center diff with a new oem center diff from Subaru, and not knowing what bearings may or may not be bad, should I replace all these bearings as well just to be safe? I really dont wanna spend another $150 but without looking in the trans their is no way of knowing. And I would hate to have it at the shop and them tell me I need new bearings and we dont have them.
However, if I only used 1 of the bearings, could I return them to Subaru??
shamrock 05 is offline   Reply With Quote
Old 08-27-2012, 01:42 PM   #19
Boostingwrx89
Member#: 279634
2002 wrx
silver psm
Yes u can. I jut got done returning some washers I didn't need. On the invoice it says return policy they will charge u a restocking fee. But if there not ******** they will just do it and they should.
Boostingwrx89 is offline   Reply With Quote
Old 04-17-2013, 04:11 AM   #20
salvi
Member#: 188132
Im having the same noise as the one in the video, is that the noise the OP fixed?
salvi is offline   Reply With Quote
Old 04-17-2013, 08:02 AM   #21
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
Had the same annoying noise, fixed when I changed the center diff for a dccd diff with a new bearing
666stars is offline   Reply With Quote
Old 04-17-2013, 01:02 PM   #22
salvi
Member#: 188132
So you think it's a diff bearing?
Old 05-04-2013, 04:38 PM   #23
salvi
Member#: 188132
The noise on the car has gotten louder and now I'm hearing a humming noise that seems to be coming from the passenger front side. The noise only starts at 40 mph and stops at 50 mph. It only happens when you are accelerating, doesn't happen in neutral or when you are not on the gas. It happens in all gears though.
Any clue on what it could be? I'm planning to start dropping the tranny today and see what I find inside. Wondering if it's even worth it trying to fix it or to just get a replacement.
Old 05-04-2013, 07:17 PM   #24
willg
Member#: 256344
2008 Subaru WRX
I did it on an 08. The humming you have sounds more like a wheel bearing. I had a humming noise in my car but couldn't figure out where it was coming from, so I had a passenger climb around while on the highway to determine its source.
The rear wheel bearings and the center diff bearings on my car went within 1500 miles of each other. The center diff bearings are not too bad to fix on your own, they are relatively cheap, and you can do it with the tranny still in the car.
willg is offline   Reply With Quote
Old 05-04-2013, 09:56 PM   #25
salvi
Member#: 188132
I thought wheel bearing noise was a constant noise that gets louder as speed increases? This humming only happens from 40-50mph.
Can I use 98 outback manual center diff in my 01 rs manual trans? scurabus Transmission (AT/MT) & Driveline 9 06-04-2010 07:32 AM
Transmission noise fixed! center diff bearing VideoGameWrx Transmission (AT/MT) & Driveline 0 01-03-2007 07:01 PM
check engine light / funky clunking noise from center diff? JessesTalon North West Impreza Club Forum -- NWIC 3 12-28-2004 12:19 AM
How much to fix center diff? Chaincat Transmission (AT/MT) & Driveline 3 07-07-2004 02:33 AM
Transmission Noise Fix in LA/OC? dingsand Southern California Impreza Club Forum -- SCIC 4 04-15-2002 02:45 PM
