Old 01-03-2007, 07:31 PM   #1
lawman246
Member#: 136536
2002 wrx
midnight black pearl
Default cam seals leaking
i have an 02 wrx and i think my cam seals are leaking does anyone have any insite on how they are replased?
lawman246 is offline   Reply With Quote
Old 01-03-2007, 07:35 PM   #2
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
Well first... how do you know it is your cam seals? If you need them replaced then.....well replace them. It is a common thing for cam seals to go out. In the mean time keep oil in the car. Always check your levels and you should be fine driving it around until you get the problem fixed.
JMK508 is offline   Reply With Quote
Old 01-04-2007, 07:52 AM   #3
lawman246
Member#: 136536
2002 wrx
Default cam seals
well i took off my headers and followed the oil with a light and found it looks like it is comeing from the cam seals. i was hopeing that maybe someone could either direct me to a link that could walk me trought it or kinda tell me how.
Old 01-04-2007, 08:45 AM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Remove timing covers, pin timing belt tensioner, remove belt, remove cams, pull/replace seals, reverse the process .
Brian
Old 01-04-2007, 05:15 PM   #5
lawman246
Member#: 136536
2002 wrx
can you send me a link that might be able to walk me throught it please
Old 01-04-2007, 06:38 PM   #6
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Find a walk through for replacing the timing belt. But loosen the cam gear bolts after you take the timing belt cover off. Once the belt is off you can take the cam gears off and then use a seal puller (bent flat head screw driver) to pull the seal. Then use the old seal to push the new seal in.
-Chav
Chav is offline   Reply With Quote
Old 01-05-2007, 07:31 PM   #7
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default WRX Timing Belt
North Ursalia has a nice link that you should find helpful:
http://www.northursalia.com/modifica.../tbeltwrx.html
-Charles-
ImprezaVA is offline   Reply With Quote
2.5 SOHC Cam Seal Leak,. Next Step?? Bullwinkle Service & Maintenance 2 08-28-2009 10:08 PM
Cam Seal Leak DHRDAN Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 07-08-2009 06:19 PM
Cam seal leak bennd87 Built Motor Discussion 7 01-12-2009 11:41 AM
Cam seal leaking oil. Again! b0dh1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-02-2005 03:51 PM
Auto Rx Product for Leaking Cam Seals/Engine Cleaning??? pdigiacinto Legacy Forum 9 01-27-2004 03:43 PM
