South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 01-03-2007, 07:49 PM   #1
subyflynn05
Member#: 122624
Default emissions
i took the emissions test today and failed. how do you guys pass the emissions?
subyflynn05 is offline   Reply With Quote
Old 01-03-2007, 08:29 PM   #2
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
put stock catback on for it and make sure all your CEL codes are cleared
szeny is offline   Reply With Quote
Old 01-03-2007, 08:49 PM   #3
dozer54321
Member#: 116437
im going with just the stock axelback and a reflash to prevent the cel
dozer54321 is offline   Reply With Quote
Old 01-04-2007, 10:19 AM   #4
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Umm, what state/city? What car and year? What modifications have been done?
AaronB is offline   Reply With Quote
Old 01-04-2007, 10:28 AM   #5
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
^^^^ What Aaron said.
Valhakar is offline   Reply With Quote
Old 01-04-2007, 10:59 AM   #6
#522
Member#: 2185
01 RS
swirly blue
Yes, so tell. I've dealt with emissions A LOT over the past year.
#522 is offline   Reply With Quote
Old 01-04-2007, 02:49 PM   #7
Lazaride
Member#: 90336
2004 Forester
Subaru Stars
And I am coming up on it and I do have a cel still Clark was not able to tune it out, it is the rear sensor with cat efficincey - he thinks the sensor might be bad / burnt out, I think I will put the stock cat back on reset and see if it stays gone - Good luck with your emissions, oh yeah other than what mods you are running, which cel code(s) do you get?
Lazaride is offline   Reply With Quote
Old 01-04-2007, 08:41 PM   #8
subyflynn05
Member#: 122624
the code that i am getting is the p0420. i have a turbo back, so i know it is the rear sensor.
Old 01-04-2007, 08:59 PM   #9
subyflynn05
Member#: 122624
what about a cel fix?
Old 01-05-2007, 03:32 PM   #10
#522
Member#: 2185
01 RS
swirly blue
You can try it. I had the o2 extender that seemed to delay it some. it seems to vary by car and exhaust. i was able to keep mine off for weeks at a time by not driving for extended amounts of time at light throttle loads. basically, if I was on the freeway, i just varied the gas as I drove and that seemed to keep it at bay long enough to get tested. the trick is, when you clear the code, the system takes several drive cycles to get to "readiness" so even if the code is gone, the car still may not pass.
KNow anyone with an OBD scan tool you can borrow? Checker sells one for about $70. It shows "ready" "not ready" and "fail"
There's always the stock exhaust...
Old 01-05-2007, 03:34 PM   #11
boosted20
Member#: 79576
if your car is fairly new then all you have to worry about is the CEL in az. right?
boosted20 is offline   Reply With Quote
Old 01-05-2007, 03:49 PM   #12
#522
Member#: 2185
01 RS
swirly blue
Yep. OBDII (95/96 or newer) is just a plug in ordeal. Took about 10 mins when I went in my 01.
Old 01-05-2007, 05:34 PM   #13
Fhqwhgads
Member#: 43049
In my Evo, I stacked mechanical fixes until it stayed away permanently. I had the brass Helix one (from Gruppe-S) but it eventually threw the code. I added an undrilled piece from the Help! brand (just one) that's in the stores before the brass one, and it has been off for 10k miles.
So it goes:
Exhaust -> Help! -> Brass Helix -> 02 sensor = Golden
Fhqwhgads is offline   Reply With Quote
IMMEDIATELY! 06/07 secondary emissions air pump!! pics inside! generalganja SCIC Private Classifieds 3 06-03-2010 02:33 PM
In an attempt to lower my emissions....looking for Catted DP emissions specs... Electric-Mayhem Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-14-2007 07:19 PM
European emissions vs. American emissions Driveway Off-Topic 7 12-17-2003 12:51 AM
('93-'01) Emissions after motor swap mykrrrr Impreza Forum 8 04-27-2001 12:31 AM
Supercharger, emissions legal in CA? Andrew Bay Area Impreza Club Forum -- BAIC 5 08-02-2000 08:13 AM
