Old 01-03-2007, 08:27 PM   #1
SubarNoober
Member#: 133261
Default Question about belts gaskets and seals
I'm considering a 96 2.2 legacy with 128k for purchase needing a few things that I know of:
1) timing belts (probably, since no record)
2) cam shaft end seals (leaking) (correct name?
i.e. those that seal the egress point of the camshafts)
3) valve cover gaskets (leaking)
These are mysterious problems, I know. But I have no idea what the ballpark cost of replacement is (parts & labor) for these. Any feedback is appreciated.
SubarNoober is offline   Reply With Quote
Old 01-05-2007, 08:47 PM   #2
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
I would estimate around $600 bucks
blackfang is offline   Reply With Quote
Old 01-06-2007, 11:54 AM   #3
birukun
Member#: 52801
1999 Legacy Wagon L
Green 30th Anniv.
Sounds about right, I did my '99 2.2l timing belt, cam and crank seals, water pump, radiator hoses for ~400.00.
Of course I supplied the labor. Working on this engine is easy with a few tools.
Do a search for 'timing belt change 2.2' - I did mine with all the info from this board.
Also check http://endwrench.com/main.php?smPID=...php&&RECID=171
for an idea of what it takes to do it yourself.
Bill in SD
birukun is offline   Reply With Quote
Question about a wheel bearing seal / axle seal anon_az Transmission (AT/MT) & Driveline 0 03-17-2010 05:59 PM
FS: Used STi Pistons, Timing Belt Tensioner, Various STi Engine Gaskets and seals,... fattie92 MWSOC Private Classifieds 2 05-10-2009 10:18 PM
Questions about port matching and gasket match porting B16A2NR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-14-2007 01:44 PM
Question about DOJ boot and front inner alxe seal replacement roninwarior007 Transmission (AT/MT) & Driveline 1 10-29-2005 02:25 PM
N.J. Partially used OEM Gasket and Seal set and rings 1fst_bl_WRX Private 'For Sale' Classifieds 8 08-17-2003 11:52 PM
