Old 01-03-2007, 11:58 PM   #1
doubleyouarex
Member#: 125377
Default radiator cap
I drive a 2002 wrx. I got some sealant stuff cuz my radiator was leaking. The directions say to remove the radiator cap and pour in the solution. I couldnt find a damn radiator cap? Does the 2002 wrx not have 1, or am i just an idiot? Is there anywhere else that I can put the solution because I really want to fix this asap.
Thanks again guys,
Bryan
doubleyouarex is offline   Reply With Quote
Old 01-04-2007, 02:51 AM   #2
dbrunner
Member#: 122171
For the 2002 WRX, the radiator cap is located near the intake manifold. Basically right above the intake.
dbrunner is offline   Reply With Quote
Old 01-04-2007, 06:38 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What "sealant stuff" did you get? It really isn't a good idea to use products such as Stop Leak to try and fix a leaky radiator since it may eventually clog the small passages in the cooling system. If this is the official Subaru conditioner it may not do that but it probably won't fix your leak either, it isn't intended for that purpose.
Your best bet is to get a new radiator rather than try fixing the old one on the cheap, it may just cost you more later. This is also a good opportunity to upgrade to the later style radiator which does have a cap on it, those are less prone to leakage and also the second cap makes cooling system service much easier (less trapped air when refilling).
Old 01-04-2007, 06:50 AM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Mulder is 100% spot on. Back in the old iron block days....Bars Stop Leak or a little egg whites dribbled into your coolant was the money. Nowadays....not so much.
FS:GT Spec radiator shroud, Perrin radiator hoses, Greddy 1.3 radiator cap Copper Rex Tri-State Area Private Classifieds 4 04-16-2010 04:35 PM
NC: ARC oil cap and radiator cap MartinD Private 'For Sale' Classifieds 39 06-15-2006 11:18 PM
FS: STi radiator cap and Zerosports oil cap blk rix wagon Private 'For Sale' Classifieds 48 06-14-2005 01:38 AM
Changing stock radiator cap to STi cap? millionsofsubys Normally Aspirated Powertrain 4 07-08-2004 10:27 PM
FS: SARD BOV, STi radiator cap, Billet Oil Cap adrive43 Tri-State Area Forum 5 05-31-2004 09:17 PM
