Old 01-04-2007, 09:45 AM   #1
erichollins
Member#: 89523
2002 Outback LTD
Green
Default Timing belt change at 60k due to Texas heat?
I just dropped my 2002 Outback off at the dealer to get the timing belt changed (I know it's a little overdue) and for a 112k service (oil change). I've owned this car for 7 months now and it's my first Subaru. Since I was there, I asked the guy about how much the 120k (60k) service would be. He told me something like $800 and that included the timing belt. I told him that I thought the timing belt was due at 105k and not every 60k. His response was that they like doing it every 60k due to the Texas heat being considered extreme conditions and they like to be safe. I'm thinking that he's wanting to get more money from customers.
What do you guys think? Is he trying to get more money or is it a good idea to get the timing belt changed every 60k due to the central Texas (Austin) heat?
Thanks.
2002 Outback LTD
113k miles
H4 engine
manual
Eric
erichollins is offline   Reply With Quote
Old 01-04-2007, 09:56 AM   #2
skunkfifty
Member#: 73102
1998 legacy outback
white
sounds like a money making scheme to me. Ask this in your regional forum, see what other central Texas Subaru owners think. then just to be sure, call a couple other subaru dealerships and ask them.
skunkfifty is offline   Reply With Quote
Old 01-04-2007, 10:05 AM   #3
erichollins
Member#: 89523
2002 Outback LTD
Green
THanks. I just crossposted.
Old 01-04-2007, 10:11 AM   #4
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Yeah, that's bull****.
Wiscon_Mark is offline   Reply With Quote
Old 01-04-2007, 10:22 AM   #5
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
BS for sure.
fibuz is offline   Reply With Quote
Old 01-04-2007, 10:24 AM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Well,
Disregarding what the service writer told you, I would ask the question if your timing belt was done at 105k when it should have been done. That's really the overlying question here. If it was just done 8k mi ago, don't change it. If it's the original, change it. The whole 60k question is kind of irrelevant...
Old 01-04-2007, 10:36 AM   #7
erichollins
Member#: 89523
2002 Outback LTD
Green
Originally Posted by Matt Monson View Post
Well,
I bought the car at 103k miles and timing belt was due at 105k. I didn't get it done until today at 113k. Even though this is 8k late, I'm going to change the belt again at 210k which will then be 8k early. I don't really care because I find it easier to just go by the maintenance schedule than trying to remember or go through my records for the last service and do the proper 30/60/105k service after that.
Old 01-04-2007, 11:36 AM   #8
rougeben83
Member#: 115154
2005 Outback XT
White on grey
well, I'll tell you a little secret. The old subaru's had the timing belt listed to be changed at 60k. Then California (oh bless California) passed a mandate about certain engine components needing to be "extended life" (like coolant, timing belt, etc to reduce waste). Guess what most manufacturers did? They just wiped the "change every 60k" label off their parts and put "change every 10xk".
Anyway, it was just changed, so I wouldn't bother changing it either.
rougeben83 is offline   Reply With Quote
Old 01-04-2007, 11:51 AM   #9
subielicious02
Member#: 133964
1991 legacy
gold brown champagne ish
if you dont want him to do it. dont let him. its not like you **** anything up in a subaru by breaking the belt anyway.
subielicious02 is offline   Reply With Quote
Old 01-04-2007, 12:09 PM   #10
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
uhh, maybe not on your 91...
Old 01-04-2007, 12:35 PM   #11
subielicious02
Member#: 133964
1991 legacy
wait. so not all subies are non interference. i didnt know that. my bad.
Old 01-04-2007, 01:43 PM   #12
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Interference:
EJ25x
97+ EJ22
Non Interference:
90-96(ish) EJ22
I say "ish" because there was a bit of crossover in the 96MY. Some 96s had single port heads, some had dual, some had hydraulic lash adjusters, some had solid lifters, etc.
The reason the EJ22 became interference is because in 97 they changed the shape of the valves (to get a higher compression) which means that if timing goes, you will bend your valves.
Interference can also mean the pistons overextending and hitting each other, but I don't know if that's possible on our engines or not.
Old 01-04-2007, 07:10 PM   #13
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Originally Posted by Wiscon_Mark View Post
Interference:
EJ25x
97+ EJ22
Non Interference:
90-96(ish) EJ22
Mark - I always assumed that all MY96 Legacys were Non-Interference. I have been blissfully driving along in my '96 Legacy L with unknown service history and nearly 190K miles on the odometer, but reassuring myself that if the belt 'lets go', its just a tow to the nearst Subaru dealer. Any tips on how to determine what type of heads and lifters my car is running ?
Thanks.
Jonathan is offline   Reply With Quote
Old 01-05-2007, 01:13 AM   #14
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Hmmm. The thing is, the year was very frankenstein'd, so one thing (like HLAs instead of Solid Lifters) might not mean that you're not interference. Single port exhaust apparently doesn't mean anything either.
Take Plays_With_toys for instance. He has single port exhaust on his EJ22 and has Hydraulic Lash adjusters like the earlier EJ22s.
I have dual port exhaust on my 95.
So...I can't tell you difinitively. sorry dude
Time to do the timing belt + water pump at that mileage anyways.
Old 01-05-2007, 04:22 AM   #15
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
my subie has over 75k miles of TX heat driving, and I haven't had a problem yet...
janikphoto is offline   Reply With Quote
Old 01-05-2007, 01:31 PM   #16
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Engine temperatures completely negate whatever outside heat there is anyways.
I'd be more worried about having the car parked in the super cold than the hot.
Old 01-05-2007, 01:43 PM   #17
rougeben83
Member#: 115154
2005 Outback XT
White on grey
+1
Old 01-05-2007, 06:44 PM   #18
erichollins
Member#: 89523
2002 Outback LTD
Green
I got it replaced yesterday and asked them to give me the belt back. It looks nearly new. Problem is that I don't have the maintenance records for the car before 103k so I don't know if the belt was changed at 60k or not. Assuming that it was changed at 60k, this belt has 53k on it and I think it could easily last another 52k. This thing has been in Austin the entire time and it's not getting changed again for 105k.
Old 01-05-2007, 08:31 PM   #19
janikphoto
Member#: 10471
2000 BMW Z3
well, you know to check belts by making a tight loop with part of it and checking the crown of the loop for small cracks. If it doesn't show many hairline cracks when you put that pressure on it, it must be pretty new...
Old 01-05-2007, 08:44 PM   #20
dplacen
Member#: 117010
1997 Legacy GT
2006 Spec B #256
They are trying to get your money! Timing belt replacement at 105k on your car.
dplacen is offline   Reply With Quote
Timing belt change due at 105k miles? JDAspenW02 Service & Maintenance 7 05-18-2009 05:30 PM
any mods to do with timing belt change? (2.2L) darkwaterz Normally Aspirated Powertrain 9 04-28-2008 05:36 PM
Cam locking tools for timing belt changes... where to rent/borrow? Buttsy Service & Maintenance 2 02-10-2008 08:56 PM
Timing belt change at 60k due to Texas (Austin) heat? erichollins Texas Impreza Club Forum -- TXIC 20 01-08-2007 01:01 PM
Timing belt change interval 60k or 100k ? il96 Normally Aspirated Powertrain 7 10-06-2003 03:51 PM
