Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 01-04-2007, 01:06 PM   #1
greenhand
Member#: 97677
1998 Impreza 2.5 RS
Unhappy Thermostat/Temperature Problem on my 98' RS
I have a 98 RS that is pretty much stock. Near the end of August I was have thermostat issues with it sticking and my car overheating. To sidestep the problem while on a roadtrip we just removed the thermostat and we've not had another problem since. Ok, so this past weekend I decided that my gas milage was suffering from me being lazy and I purchased a new thermostat and o-ring from the local Subaru dealership. Ran great...for about 2 days...overheating again from what appears to be another STICKING THERMOSTAT!!! Is this a recurring problem with these cars, or is there possibly another reason why my car chooses what temperature it wants to be at, pinned at the top of gauge one moment, then down to half and normal operating temperature the next. This is so frustrating, any suggestions?
greenhand is offline   Reply With Quote
Old 01-04-2007, 01:20 PM   #2
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
if you want to test the thermostat you can heat water up in a pot till it boils and dip the thermostat in to see if it opens without problems and then you can tell whether its the thermostat or something else
legacy1907 is offline   Reply With Quote
Old 01-04-2007, 07:36 PM   #3
SiFuSpEc
Top Scoob 008
Member#: 77299
'05 2.5RS
#78 ST, MAXIMUM ATTACK!
try spending a bit longer to burp the car...
squeezing both top and bottom hoses, and letting the car heat cycle a couple times..
SiFuSpEc is offline   Reply With Quote
Old 01-04-2007, 07:57 PM   #4
greenhand
Member#: 97677
1998 Impreza 2.5 RS
Does anyone have a cooling system diagram?
Old 01-04-2007, 10:56 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Head gaskets.
Old 01-04-2007, 10:57 PM   #6
kickitjp
Member#: 60035
Chapter/Region: PRSIC
Originally Posted by Patrick Olsen View Post
Head gaskets.
Seriously. Check your coolant for oil.
kickitjp is offline   Reply With Quote
Old 01-05-2007, 12:06 PM   #7
greenhand
Member#: 97677
1998 Impreza 2.5 RS
I did. I'm in denial right now. I know it's a 98...Headgasket. Yes, there is that very small oil sheen when I open the radiator. I took the thermostat out for the time being. From reading around, I should just get the OEM engine gasket set from my local Subaru Dealership? Also, does anyone have a PDF version of the Hayes or Service manual for the DOHC 2.5? Thanks for everyone's help! Looks like the cherry picker will go into use within a few weeks.
Old 01-05-2007, 12:21 PM   #8
greenhand
Member#: 97677
1998 Impreza 2.5 RS
Also, are there any easy, fairly affordable changes I should make while pulling my engine out and apart? Obviously I might need to machine the heads if they are warped, any aftermarket options I should be looking at? Any reccomendations are greatly appreciated. Thanks.
Old 01-05-2007, 12:46 PM   #9
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
How are you bleeding the cooling system? There should be a burp/bleed screw on the top of the passenger side of the radiator. This needs to be removed in order to properly bleed/burp the radiator of air.
In addition, there is a common failure point in the front on the passenger side end tank on the top...directly in front of where the top radiator hose enters. It will crack there, let coolant leak, and air back in when things cool.
Legacy777 is offline   Reply With Quote
Old 01-05-2007, 12:55 PM   #10
greenhand
Member#: 97677
1998 Impreza 2.5 RS
No leaking coolant in the engine compartment, yet losing coolant anyway. I turned the heat on high on the floor, ran the car with the radiator cap off while filling the coolant up, and waited for all the air to bleed out of the system...
Old 01-05-2007, 01:01 PM   #11
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Definitely make sure you remove the bleed/vent screw from the passenger side of the radiator. I've never had any issues with air in my cooling system, and I don't do anything special to fill it - engine off, remove radiator cap, remove vent screw, fill until the radiator's full, fill the overflow bottle to the "Full - Cold" line, done.
You can do performance stuff like Delta cams or getting the heads ported and polished. There are no aftermarket head options for the Subie engines. The OEM gaskets should work just fine, although some people use Cometic gaskets instead.
Pat
need some help with my 98' RS rlig Normally Aspirated with bolt-on Forced Induction Powertrain 8 06-10-2006 04:48 PM
rs mudflaps wont fit on my 05 rs. rsracer2005 Interior & Exterior Modification 6 03-30-2005 11:37 AM
Steering Problem on my '02 RS? Rosso_Corsa Normally Aspirated Powertrain 1 12-31-2003 01:35 AM
most recent pics of my 98' RS SubeDonC Member's Car Gallery 7 09-09-2002 11:47 AM
I have the terrible Cold clutch shudder problem with my 2001 RS scootr Normally Aspirated Powertrain 16 12-21-2000 10:53 PM
