Old 01-26-2007, 09:58 AM   #26
nate.the.great
Member#: 72031
Originally Posted by REX8 View Post
I've heard that you CAN (from about 3 people) use 04 struts with 02/03 springs and tophats. Are you 100% sure you can't?
really? 02/03 springs and tophats with 04 struts? i'll have to do some research.
nate.the.great is offline   Reply With Quote
Old 01-26-2007, 01:00 PM   #27
noboost4u
Member#: 126442
My car is slower
than your car
I know that I've read that elsewhere on here too, wish I could remember where.
...The Truth IS Out There...
noboost4u is offline   Reply With Quote
Old 01-26-2007, 01:38 PM   #28
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Well - fwiw I sold my V7 rear springs and tophats to a local fellow with an 06 and he said they fitted fine:
http://forums.nasioc.com/forums/show...17&postcount=4
UkNuck is offline   Reply With Quote
Old 02-07-2007, 10:28 PM   #29
XtremePsionic
Member#: 138057
06 WRX
I don't see it on this post (or I'm just blind!), what about 06 STI full take off with top hats, would that fit an 06 WRX?
edit: is that the same as the V9 suspension senerio involving spacer? Sorry I don't know if they changed the suspension at all for the 06/07 model on top of the engine and face lift.
XtremePsionic is offline   Reply With Quote
Old 02-08-2007, 08:18 AM   #30
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Top hats aren't the issue in that case - what won't fit is the 06 (or 05, or 07) STI front struts on the WRX (or any other Impreza) front hub/knuckle.
Old 02-08-2007, 11:37 AM   #31
XtremePsionic
Member#: 138057
06 WRX
Ok thanks. So from the first post by Nate it seems like I need to find a shop to slot the strut's mounting hole and add a spacer on the bottom then to make it fit.
Hmm sounds like maybe it's not worth it then.
Old 02-10-2007, 12:06 AM   #32
halas
Member#: 108720
2006 9-2x
so basically any Sti strut will fit my 06, but if its from a 05+ Sti I have to slot 0.330" - BUT I have a GC so it's all a guess right now!>!>!>!
halas is offline   Reply With Quote
Old 02-10-2007, 10:04 AM   #33
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
The GC rear tophat bolt pattern is different. V7 (bugeye) stuff can be made to fit by re-using GC rear tophats; later Impreza suspensions (including any USDM STi) have the tapered rear springs which won't fit the GC tophats.
http://www.jdmpartstx.com/gc8_suspension/
Old 02-12-2007, 10:48 AM   #34
Fathead
Member#: 91842
2008 Titan Crew
If you want to fit a 2005+ STi (V9) suspension on your WRX...
"Originally Posted by tom@kartboy View Post
you just need to slot the lower bolt hole up 0.330 and machine a spacer to makeup the width difference in the knuckle."
Is there a writeup or diagram on this anywhere, or someone w/experience who could walk me through this? I have '06 OEM STi springs, '05 OEM STi struts, trying to fit an '05 wagon. I understand there are camber issues up front, but I figure if I'm slotting the struts anyway, I can fix that. Any help would be appreciated (oh yah: already know about "saggy butt". . . not a concern). THANKS.
Fathead is offline   Reply With Quote
Old 02-12-2007, 12:08 PM   #35
nate.the.great
Member#: 72031
i have never seen a slotting writeup. i would PM tom and ask him to do a writeup. however, since we are dealing with suspension components, i would recommend bringing it to a machine shop of some sort.
Old 03-08-2007, 12:09 PM   #36
luvMySub
Member#: 132112
2002 WRX Sedan
midnight black pearl
Default newbie question - will 06 struts fit my 02?
As the title states, will 06 impreza sedan struts fit in my 02 WRX sedan? Any replies would be greatly appreciated!!!
luvMySub is offline   Reply With Quote
Old 03-08-2007, 12:16 PM   #37
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
as long as they're not from an STI sedan
The 04+ rear tophats are different, but that way round (new struts w/ old tops and springs) supposedly works OK without modification. You could use complete assemblies (i.e. 04-07 strut+spring+tophat) if you want 100% fit
Old 03-08-2007, 12:53 PM   #38
luvMySub
Member#: 132112
2002 WRX Sedan
okay...
So, to clarify, I have an 02 WRX sedan. I plan on removing my struts and replacing them with struts from an 06 impreza sedan (not STi). My 02 top hats and springs will remain in my car, just the struts will be replaced.
Will they fit and work properly?
Thanks...
Old 03-08-2007, 04:39 PM   #39
luvMySub
Member#: 132112
2002 WRX Sedan
Anybody out there that has had any experience (positive or negative) installing 06 sedan struts on an 02 wrx sedan (using 02 wrx springs and top hats)...just looking for someone's personal experience...
anybody???
k...well, i'll be installing some this weekend unless I hear otherwise so I will post the results...
Old 03-09-2007, 12:15 PM   #40
luvMySub
Member#: 132112
2002 WRX Sedan
Anybody?...just fishing for others experiences
Old 03-09-2007, 12:28 PM   #41
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Check out the thread I linked in post #28 (my old V7 springs + tops on an 06). I didn't do the install myself, but he seemed happy that everything fit.
Old 03-09-2007, 02:34 PM   #42
luvMySub
Member#: 132112
2002 WRX Sedan
Excellent, thanks!
I'll post my results after the swap...
Old 03-11-2007, 06:01 PM   #43
stoney98
Member#: 65888
2004 FXT
Just to clarify, I am not going to need a set of Scooby921 spacers with the following setup:
02 Strut body
04+ Koni Inserts
04+ STI Tophats
04+ STI Pink Wagon Springs
Thaks
-Mark
stoney98 is offline   Reply With Quote
Old 03-11-2007, 06:24 PM   #44
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Correct - inserts make the year of the strut bodies irrelevant
Old 03-12-2007, 03:38 PM   #45
luvMySub
Member#: 132112
2002 WRX Sedan
Default 006 struts DO fit with 02 top hats/springs
So, did the install on the weekend and the '06 impreza (sedan) struts do fit in the '02 impreza (WRX sedan) springs and top hats...
Now if you want to purely exchange the whole assemblies (struts/springs/top-hats) from an '06 impreza sedan into an '02 WRX...DO NOT DO SO....
Your car will literally be raised 1.5" -2"... both the top-hats and spring rates are different...we tried it first and my car looked like an SUV ...horrible...just thought I'd post my results...
Old 03-13-2007, 05:37 PM   #46
theostubbs
Member#: 122286
2007 STi
Thats Excellent to know! Thanks
Now... will 2006 USDM STi springs / top hats do the same thing as you described? Was there a change between 05 and 06 with regards to STi springs/top hats?
theostubbs is offline   Reply With Quote
Old 03-14-2007, 01:16 PM   #47
luvMySub
Member#: 132112
2002 WRX Sedan
I believe, but I am not 100% sure that the top hats on the '06 whether they are from an rs, wrx or STi are different than the 02 WRX top hats.
And yes, I beleive there was a change between the 05/06 tophats. I would just use your 02 top hats with the newer struts...it worked great!
Again, I am not an expert in the specific differences between the years so don't take my advice as gospel
However, as mentioned I can 100% verify that 06 struts do in fact fit with 02 top hats and springs...
Good luck!
Old 03-14-2007, 02:23 PM   #48
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Details? Pics? Did you let the struts settle (e.g. drive it around the block)? Seems strange, that's all...
Old 03-14-2007, 03:19 PM   #49
luvMySub
Member#: 132112
2002 WRX Sedan
Hey there...no pics, and yes, I let the car settle for a good 20 minutes before taking it out and driving it pretty hard around some twisties...
Basically, the top hats on the 06 is shaped differently with a sort of riser which the 02 didn't have so the top hat itself added 3/4" - 1" in raise and the spring rate/size on the 06 sedan struts was different so not quite as low as my wrx springs...
So, sorry, no pics, but trust me when I say it looked pretty bad! If you own an 02/03 wrx with stock springs, the back doesn't look bad but the front is quite high...well, put it this way, the back had just as much wheel/fender clearance as the front if not more (which is more necessary in the front to account for wheels turning)
Just thought I'd post my results...
Old 03-14-2007, 03:30 PM   #50
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Yeah I'm aware of the differences between 02/03 and 04/5/6 but any year's correct spring+tophat combination should fit without altering the height.
Also you are saying 06 differs from 05... ?
Will this exhaust fit with my downpipe? jcl Factory 2.0L Turbo Powertrain 3 01-06-2010 08:21 AM
Will these shocks fit? skybox Newbies & FAQs 0 12-29-2007 06:55 AM
will this downpipe fit with my exhaust Sedatives17 Newbies & FAQs 4 09-23-2006 02:15 PM
Will Fluidyne radiator fit with A/C on 02' WRX??? Farnsrocket Newbies & FAQs 5 05-17-2005 12:00 PM
Will espelir catback fit with my HKS downpipe? ImportVenom Factory 2.0L Turbo Powertrain 2 07-29-2004 12:08 AM
Message Board Statistics All times are GMT -4. The time now is 10:46 AM.
