Old 01-04-2007, 04:36 PM   #1
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
Default Ej22 engine rebuild
I'm really contemplating doing the headgaskets and the timing belt.
Think I should pull the whole engine out and do a complete overhaul? The engine is in great running condition, with 203k miles on it, so should I just wait for it to crap out or do it before something bad goes wrong?
runninstrong is offline   Reply With Quote
Old 01-04-2007, 07:07 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Pull the engine, and while it is out and once you have the heads off take a look at the condition of the cylinder walls. That should give you an idea of bearing condition. If the bearings are getting tired, it will be starting to groove the walls.
Also, a leakdown and compression test is always a good indicator before you do anything. If it appears to be in good nick and presents good numbers, just do the head gaskets, oil pump, water pump, rear main seal, cam seals, valve cover seals and timing belt and drive it for another 100k mi...
Old 01-05-2007, 01:59 AM   #3
spdracr00
Member#: 65823
1996 Impreza L
Red
man, you got a 2.2 those things will go forever, dont tear down a good motor.
wait till somethign goes wrong, if you're worried then change the timing belt, but leave the motor as is.. after 200k its all broken in. and to be honest you can pick up lower milage 2.2's for like nothing around here.. way cheaper than a rebuild.
spdracr00 is offline   Reply With Quote
ej22 engine rebuild tedsan126 Subaru Conversions 2 01-15-2010 12:11 AM
EJ22 Turbo Rebuild help EJ22T hotdogpimp Pre-2002 Factory Turbo Powertrain 3 05-05-2009 11:20 AM
Holiday Engine Special-GT30$1799-VF34$825-Manifolds$325-Engine Rebuild Kits$899 Gruppe-S Engine/Power/Exhaust 38 01-10-2008 08:53 PM
Free Crank Pulley-Free Dampers-Engine Combos-Engine Rebuild Kits$699-Manifold Combos Gruppe-S Engine/Power/Exhaust 24 11-16-2007 09:25 PM
EJ18 and EJ22 Engine Swap Leftover Parts subachad Private 'For Sale' Classifieds 15 02-22-2004 11:06 PM
