Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 01-05-2007, 12:20 AM   #1
Jaredm83
Member#: 65816
2014 Forester XT
Default OEM Axle-back on bosal mid-pipe???
I have an 02 wrx with 3" SPT cat-back. I would like to mate my OEM axle-back up to my SPT mid-pipe. I have 2 questions, will I be able to do this? I know the fit wont be optimum but will it work. Also, will I loose that much power or restrict my exhaust too much for stage II? Right now I'm running a conservative economy tune. I'm not really worried about power tight now, just want it to be very driveable and get good gas mileage as I do alot of driving right now. Thanks, Jared
Jaredm83 is offline   Reply With Quote
Old 01-05-2007, 03:05 AM   #2
Jaredm83
Member#: 65816
2014 Forester XT
anyone? I guess I jus try it and see tommorow
Old 01-05-2007, 03:14 AM   #3
el dude
Member#: 85197
2002 Impreza WRX
i was planning on doing the same thing tomorrow
el dude is offline   Reply With Quote
Old 01-05-2007, 05:02 AM   #4
silence2-38554
Member#: 121459
I just did the exact opposite of what you're wanting to do. I bought a used Bosal axle-back and bolted it to my oem midpipe. The holes & everything line up, what you're going to run into is gasket size. I solved my issue by using both a 2.5 & a 3" gasket, both w/ copper gasket sealant on both sides. no leaks at all!! also, if you can't find both gaskets, get a sheet of Mr. Gasket exhaust gasket material for like 10 bux & cut your own out w/ an x-acto knife. That's what I did & have no leaks at all
silence2-38554 is offline   Reply With Quote
STI axle-back, dp and mid pipe Subiemax Engine/Power/Exhaust 7 02-23-2008 12:24 AM
FS:FL 02 stock axle back and 3" mid pipe jcis2ez Engine/Power/Exhaust 2 04-01-2007 01:12 AM
MI - Prodrive axle back + 2.5" mid pipe cherrywrx Private 'For Sale' Classifieds 2 01-29-2005 11:19 AM
