Old 01-05-2007, 08:42 AM   #1
waktasz
Member#: 86356
Default logging IAM question
I've been logging my car the last two nights after reflashing to one of the open source maps and I can't seem to find the IAM value.
I'm using the memory location listed on Scoobypedia for the 06 WRX and it reads 1.5 at all times. Even after an ECU reset. Is this right?
waktasz is offline   Reply With Quote
Old 01-05-2007, 11:50 AM   #2
qoncept
Member#: 44762
2013 BRZ
You'll have to do it the old fashioned way -- just enable a bunch of them and see which one looks right. The 06 ECU will definately have it at an address above 0xFF0000.
qoncept is offline   Reply With Quote
Old 01-05-2007, 02:46 PM   #3
waktasz
Member#: 86356
Did that, none of them seemed to give any useful info. I'll have to try again with them all checked. What values am I looking for? Between 1 and 16, right?
Old 01-05-2007, 04:31 PM   #4
blkscooby
Member#: 44422
2008 G8 GT
Burnouts on Central!
If you reflashed with an OS map, your IAM should be 16 to start.
blkscooby is offline   Reply With Quote
Old 01-05-2007, 04:45 PM   #5
waktasz
Member#: 86356
Cool...and that's what the ECU reports? it's not some other number that has a multiplier added to it? I thought I read somewhere it would be between 1 and 4 and have some conversion applied to it to get the actual IAM. Maybe I'm mental.
edit: So that means if I reset the ECU it will default back to the max value? Thanks again
edit again: In looking at the map in enginuity, the advance multiplier(initial) is 1. This should be 16? I suppose I could change it at first at least until I find the right memory location.
Old 01-05-2007, 06:17 PM   #6
06rexwagon
Member#: 114730
2006 WRX Limited Wag
IAM is 1 for 32 bit ecu, 16 for older ecus. The address for an '06 is FF6848. OTS maps set it anywhere from .6 to 1 to start out.
06rexwagon is offline   Reply With Quote
Old 01-05-2007, 06:36 PM   #7
waktasz
Member#: 86356
Great, thanks. So 1 is "happy" and if my car doesn't reduce that number any, I'm pretty good?
Old 01-14-2007, 10:44 PM   #8
waktasz
Member#: 86356
bump for an answer to the above
Old 01-14-2007, 10:55 PM   #9
testes1010
Member#: 47145
2005 LGT 5MT VF52'd
yes, for the most part....get an EGT gauge & a WBO2 logger to double check.
testes1010 is offline   Reply With Quote
06 WRX-VF39-Airboy map-logs-some questions Team Scream Open Source Reflashes 0 01-26-2009 07:06 PM
IT Guys Get in Here: JBoss log files question The Enemy Off-Topic 3 04-03-2008 03:41 PM
data log #'s question rotaman Engine Management & Tuning 2 11-18-2006 08:34 PM
FP18 log w/question powbmps Engine Management & Tuning 12 02-23-2004 02:18 PM
UTEC Install today: Log, pics, questions, impressions, thoughts, etc. Shamr0ck Engine Management & Tuning 23 09-18-2003 02:46 PM
Message Board Statistics All times are GMT -4. The time now is 07:18 AM.
