Old 01-05-2007, 01:13 PM   #1
Dodik
Member#: 122609
2002 Outback H6 BE
82 GS750E
Question Ej25 rebuild is it worth it?
Ok I have a dilema on what to do with the car?
It has almost 270K and still running I already changed HG once before at 225k the car is running but without thermostat only, it starts really rough coolant disapears somewhere and not in the oil, and is not dripping much. also have quite a few oil leaks. One of the lifters is knocking when car is cold because HG are a bit thinner than OEM and one of the headbolts is bigger diam because it snapped while removing it.
The question is. Should I rebuild buy a different Ej25 with less miles or get a newer SUBY??? And price wise if any1 knows numbers for rebuilding I would really appreciate them. Oh yeah and Im not a mechanic so this rebuild or new engine swap will take me at least a month to do.
Dodik is offline   Reply With Quote
Old 01-05-2007, 01:20 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Really depends on your financial situation.
If you have the cash to swap, do that.
If you need to take a loan out, get a new(er) suby.
Thats my opinion...
fibuz is offline   Reply With Quote
Old 01-05-2007, 01:40 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I found a complete '98 2.5RS engine - oil pan to throttle body, accessories, everything - for $600. It has only 106k miles on it (or 108k? something like that), and the head gaskets and timing belt were done 9k miles ago.
If you can find something like that then it's pretty easy financially. I probably could have talked the previous owner down off the $600, so conceivably you could find an engine out there even cheaper.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 01-05-2007, 01:59 PM   #4
Dobes
Member#: 164
2008 Exige S240
Rebuilds can be very expensive. For an EJ25 I doubt it would be worth it, especially considering you've got so many miles on that one. 270k miles means you probably have to bore the cylinder (which could mean new pistons), clean the valves, regrind the valve seats, etc, etc, etc. For just machining, you're probably looking at $1k. Then there's seals, gaskets, etc. Of course, your engine would be practically new after that but it'll be way, way less expensive to just get a used engine like Pat suggested. That's my vote anyhow.
JD
Dobes is offline   Reply With Quote
Old 01-05-2007, 02:10 PM   #5
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Rebuilds would probably cost almost as much as swapping the engine in labor. I would pick a turbo engine and go with that instead of you can afford it straightup.
Otherwise, get a newer subaru if you need to take a loan out for the engine swap/rebuild itself.
rougeben83 is offline   Reply With Quote
Bigger plug spark...is it doable? Does it hurt things? Is it worth it? kaisersouse Normally Aspirated Powertrain 8 01-27-2006 07:35 PM
is this legal? if so is it worth it? svek Interior & Exterior Modification 22 08-26-2005 12:37 PM
David Cooperfield is in my town this week. Is it worth it? Mud Pig Off-Topic 11 04-25-2005 04:45 PM
Mobil One synthetic Tranny fluid is it worth it Jimmy Normally Aspirated Powertrain 6 06-04-2001 08:14 AM
Factory Alarm, Is it worth it? jbell303 Car Audio, Video & Security 7 03-19-2001 03:56 PM
