Old 01-05-2007, 05:48 PM   #1
burritotown
Member#: 121031
1999 RHD Legacy Wgn
Green
Default Car heats up after idling for a long time.
After driving for a while and coming to an idle my coolant temp starts to get really warm. It hasn't hit red yet, but that's because the light always turns green before it would have the chance. It starts after about 5 minutes or so of idle. After I start moving, it goes down immediately and all is good.
The only thing I can think of is when I replaced my turbo I lost about a tablespoon or coolant and didn't feel any needed to be added since it lost so little. Could there be air in there or are my fans borked?
burritotown is offline   Reply With Quote
Old 01-05-2007, 05:50 PM   #2
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Well, do your fans turn on when it gets hot, or not? If they don't, turn on your A/C and see if they come on then.
Old 01-05-2007, 06:06 PM   #3
jason6787
Member#: 125757
Had a WRX now want
Another one!
maybe a hairline fracture in cylinder 3. Factory Default. It happend to my car at 32,000 Miles. Subaru Replaced my block for me under warranty. I hope not but i've heard of this before making your car over heat at idle and be fine while driving.
jason6787 is offline   Reply With Quote
Old 01-05-2007, 09:43 PM   #4
al3xgonz
Member#: 124214
06 WRX TR
maybe thermostat....
al3xgonz is offline   Reply With Quote
Old 01-06-2007, 01:34 AM   #5
acidrain088
Member#: 130973
most likley water pump or thermostat. the fan doesnt cool too much to the point of overheating. i would check the thermostat first in a pot of boiling water and if that doesnt fix it just replace the water pump.
acidrain088 is offline   Reply With Quote
Old 01-06-2007, 01:37 AM   #6
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
sounds like you have an air pocket.
have you verified your fans are plugged in?
ImprezaRSX is offline   Reply With Quote
Old 01-06-2007, 02:12 AM   #7
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Do you checked your coolant levels on a regular basis? Probably isn't going to make any difference. It does seem like either the thermo or the fans. Air is getting pushed through the radiator when you are moving which is why the cooling is fine then but when you stop the fans are there to ensure there is airflow through the radiator. I'm guessing the fans not kicking in because a dead thermo would cause the same issue.
Also why did you replace the turbo?
Do you know what caused the fracture to develop?
If it was the pump then it wouldn't be cooling the engine properly regardless if the car was moving or not.
Doubt it. Both of my cars have or have had air bubbles and it makes no difference. Also my computer cooling is loaded with air bubbles and it makes little difference to cooling performance.
i_c_the_light is offline   Reply With Quote
Old 01-06-2007, 02:26 AM   #8
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
ok, well after you troubleshoot everything else, check the air pocket
I'll bet you a free tune that it's an air pocket.
I've had it happen on many cars.
The temp sensor in our cars is in the crossover pipe. which just happens to be the highest point in the system (engine side). So any air pocket fills with steam in the crossover tube. At low rpm the water pump is turning slow and not creating enough flow or pressure to move water through the crossover pipe at a rate that keeps the sensor wet.
Old 01-06-2007, 02:31 AM   #9
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
There I go thinking air bubbles, which is probably not as bad as an air pocket.
If a bubbling sound is heard inside the when the engine is running is a good indication. An air pocket, bubbles, whatever is most likely to be in the heater core.
Old 01-06-2007, 02:31 AM   #10
burritotown
Member#: 121031
1999 RHD Legacy Wgn
Green
I_C, my previous td04 just quit spinning for some reason. I could reach in and force it to spin with my finger but after a few days it would stop again. It seems like a piece of my UP cat got caught in there (replaced that @ the same time), so I bought a used one with 10k miles and did the job myself. I check coolant during regular maintenance periods or when I have a reason to believe it's low (haven't had any time to go out and do it since this problem started, probably will Sunday)I will troubleshoot everything in this thread, thanks guys !
Old 01-06-2007, 02:43 AM   #11
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
half right.
When the car is cool, the air pocket will move to the highest point in the system. however, when the engine is running and hot, the air pocket will result in a low pressure in the engine. When the system is solid it develops a pressure as temp rises because water doesn't compress, this keeps the water in it's liquid state and minimizes steam formation. If you add an air pocket into the system, the air compresses and water boils at the hottest points in the engine. This creates steam pockets that rise to the highest point (the crossover pipe). Since the temp sensor is in the crossover pipe, your indication will be the high temp of the steam and not necessarilly the temp of the engine.
Old 01-06-2007, 07:38 AM   #12
dibblejr
Member#: 94070
05 LGT
Just open your owners manual and read and perform the CORRECT cooling system burping process. I dont know why more members do not read how to do this, anytime you remove the turbo or any of the coolant lines you need to perform the steps.
I have seen so many incorrect answers to the burping process. Sure it takes a while to do it correctly but you wouldnt have this problem.
HINT*** The steps do not require to remove your radiator cap at any time.
Jay-R
dibblejr is offline   Reply With Quote
Old 01-07-2007, 08:14 PM   #13
burritotown
Member#: 121031
1999 RHD Legacy Wgn
Green
So let me get this straight.
1. Idle
2. Take turbo reservoir coolant cap off when it starts getting hot
3. Repeat?
Do I use the turbo reservoir or the plastic one? Do you have any idea how hot the turbo reservoir would be if my car is overheating? I'd burn my hand ! Please let me know what's up.
Old 01-07-2007, 09:24 PM   #14
dibblejr
Member#: 94070
05 LGT
Wrong, I was hoping you would read your owners manual but here it is. I will spoon feed you.
These steps must be done in your driveway/ garage/ parked
1.) Top off plastic coolant resevoir
2.) Top off Turbo Coolant Resevoir ( metal one right next to intake manifold) do not drive the car
3.) Turn on heater to defrost and all the way up (speeds process a tad)
4.) Start car and hold to 3000 rpm's for 10 min ( even if it gets hot stay on it for 10 min)
5.) Turn ignition to acc to keep the fans running ( helps car cool off faster)
6.) Check both resevoirs and fill as needed
7.) Repeat steps 1-6 until no more coolant is added
**** Do not at anytime open the radiator cap, it will negate all the time spent on the proceedures above and will allow air back into the system*****
Jay-R
1. Idle
3. Repeat?
Old 01-07-2007, 09:32 PM   #15
burritotown
Member#: 121031
1999 RHD Legacy Wgn
Green
Jay-R
The problem is, why should I need to ADD that much coolant when I only spilled a spoonful? Isn't there a way to get air out without dumping another gallon of unneeded coolant in, or is this the only way? This is why the owners manual isn't helping me, it is assuming I have lost a decent amount of coolant.
Old 01-07-2007, 09:41 PM   #16
dibblejr
Member#: 94070
05 LGT
Until you perform the proceedure you dont know how much you have to add. You may only have to do it once.
I lost what I thought was a little and it took me almost an hour to complete the proceedure.
You can second guess all you want but if not followed correctly you will be posting an overheating thread or possibly a I melted my engine thread.
I dont want to seem harsh, but I gave you the correct advice a long time ago, I figured by now you would have completed it and everything was fine now.
It is the propper way to add any coolant to your system, dont get all wrapped up on the quantity. The book does not assume a loss of significant coolant, it assumes that your engine temp is high.
Trust me this will solve your problem unless there is something you havent mentioned.
Jay-R
Old 01-07-2007, 09:46 PM   #17
burritotown
Member#: 121031
1999 RHD Legacy Wgn
Green
Jay-R
Alright ! I trust you since you're steered me in the right direction many times. I'll get 'er done tomorrow. Thanks ! Also, do I keep both reservoir caps off while I'm doing this process? I don't want to screw up.
Old 01-07-2007, 09:51 PM   #18
dibblejr
Member#: 94070
05 LGT
Good luck and when you remove the metal resevoir cap use a towel just in case it splashes, dont get burnt it still may be hot even if the temp guage shows "c".
Use 50/50 coolant/water as described in your manual.
Let me know how it turns out.
Jay-R
Old 01-14-2007, 11:56 AM   #19
burritotown
Member#: 121031
1999 RHD Legacy Wgn
Green
I did the steps and ended up putting about 3/4 a gallon of 50/50 in. I'm very surprised it took so much. I did everything right, took it for a drive, and idled for about 10 minutes and the temp did not get past half on the gauge (fans were running, I confirmed it) so we'll see if the problem is truly solved. Thanks !
Old 01-14-2007, 06:11 PM   #20
dibblejr
Member#: 94070
05 LGT
You should be good to go, now.
Jay-R
Old 01-14-2007, 11:01 PM   #21
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
i love this guy!
Old 01-15-2007, 12:19 AM   #22
burritotown
Member#: 121031
1999 RHD Legacy Wgn
Green
i love this guy!
Thanks
Old 01-15-2007, 03:18 AM   #23
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
anytime
losing oil + car heating up on idle constantino7491 Newbies & FAQs 12 02-14-2010 08:19 PM
exhaust smokes only after idling for a few minutes and no other times. causes? rex n effect Service & Maintenance 36 07-29-2008 04:33 PM
Your car is warmed up and you let it idle for a long time: What's that damn knock? HamFist Normally Aspirated Powertrain 10 11-09-2006 12:55 PM
Help with engine noise after car being parked for a long time Undepelo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-05-2006 01:30 PM
Help with engine noise after car being parked for a long time Undepelo General Community 1 09-03-2006 10:34 PM
