Old 01-05-2007, 06:57 PM   #1
benw
Member#: 103320
1998 swapped
Forester L
Default Can a Subaru dealer tell if an ECU has been EcuTek flashed?
Searched and had little luck. When a dealer uses their subaru select scan tool, does it do a checksum on the particular ECU map for a given car? This is regarding EcuTek flashed ECUs failing warranty work. I would think since the base tables are modded, the dealer tool would not be the wiser, since it's basically a glorified code puller and reflasher for specific systems (airbag, immobilizer, et al.)
Experience in this matter would be helpful!
Thanks,
Ben
benw is online now   Reply With Quote
Old 01-06-2007, 12:54 PM   #2
LateApex31
Member#: 135686
Well since the dealership no longer has the ability to reflash the ECU, then yeah it might be a problem. If it is an older ECUTek flash then it might be OK. Most likely, the first thing the dealership does when a car comes in for service is to flash the latest calibration to the ECU. If they can't they know that you/someone has tampered with the ECU. Not sure if the SSM tool does a checksum on the cal file, maybe someone else has some knowledge of this?
LateApex31 is offline   Reply With Quote
Old 01-07-2007, 04:11 PM   #3
benw
Member#: 103320
1998 swapped
Forester L
bump for more information. My tuner was fairly sure that the dealer would not know anything about the flashed ECU. But I'd like some clarification.
Old 01-07-2007, 04:27 PM   #4
Tea cups
Member#: 103136
Not sure what capability the dealer has as it relates to a checksum, but I've never heard of anyone's warranty work being denied to a modified ecu. This argument is only relevant if we are talking about a stage 1 car with no other mods other than a flash. With any other mod, the dealer will most likely use it as an excuse rather than bothering with the ecu (example downpipe, intake, etc.). Also, with Ecutek's EasyECU you should be able to flash a stock map on your car before going into the dealer and then flashing back to your custom tune afterwards. Older Ecutek tunes and AP 1.0 users can back up their rom with the openecu tools and flash to stock before going in as well. And I'm guessing you can do the same with AP 2.0 by unmarrying (also possible with 1.0).
Tea cups is offline   Reply With Quote
Old 01-07-2007, 10:38 PM   #5
benw
Member#: 103320
1998 swapped
Forester L
How does one know if I have an older EcuTek that can be backed up with the openecu tools?
Old 01-08-2007, 10:17 AM   #6
Tea cups
Member#: 103136
You don't know until you try it. If it is less than a year old, then most likely it is has the lock. I guess you could take it to your Ecutek dealer and see if they could tell you.
Old 01-15-2007, 04:16 PM   #7
benw
Member#: 103320
1998 swapped
Forester L
bump for more insights
Anyway to tell if my car has been tuned? SpeedWRX06 Newbies & FAQs 18 03-24-2010 01:19 PM
can you tell if an ecu has been flashed? mrwilliwizard Newbies & FAQs 13 11-11-2009 12:42 PM
How do I know if my ECU has been re-flashed? jet8300 Engine Management & Tuning 2 08-17-2006 09:28 AM
Can you tell if a car has been fixed? jonney_boy General Community 13 02-16-2006 03:48 PM
how do i know if an ecu has been ecuteck Blackpantherwrx Engine Management & Tuning 24 11-28-2005 04:25 PM
