Old 01-05-2007, 07:45 PM   #1
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
Default - Knock Correction in my Log. Bad?
Got my tactrix a week or so ago and did a few logs with my stock ECU before flashing to OSECU Stage 2. I noticed some - Knock in my logs. Can you guys tell me whats going on in this portion of the log?
Stock 03 WRX log. Noon 1/5/07 about 60 degrees outside.
Code:
Time	RPM	TOA	MAF	IAT	IT	MPH	KC	AFSV	MRP	PWGD	EGT	AM	EL
0	1369	0	7.82	68	20	1	0	1.6	-8.561	0	689	16	0.69
161	1360	0	7.95	68	20	1	0	1.6	-8.561	0	689	16	0.69
351	1328	0	7.95	68	23	1	0	1.6	-8.561	0	689	16	0.69
541	1340	0	7.66	68	20	1	0	1.58	-8.706	0	689	16	0.69
731	1327	0	10.1	68	21	1	0	1.66	-8.706	0	689	16	0.72
922	1309	0	5.22	68	20	1	0	1.58	-8.561	0	689	16	0.69
1112	1299	5.1	12.86	68	22	1	0	1.9	-6.675	0	689	16	0.97
1302	1481	5.1	14.14	68	34	0	0	1.9	-5.949	0	689	16	1.09
1493	1563	5.1	13.84	68	36	0	0	1.9	-6.094	0	689	16	1.06
1683	1526	4.71	13.96	68	35	0	0	1.9	-6.094	0	689	16	1.09
1873	1501	4.71	13.66	68	34	0	0	1.88	-6.094	0	689	16	1.09
2063	1476	4.71	13.31	68	34	1	0	1.88	-5.949	0	689	16	1.09
2254	1490	0.39	10.04	68	32	1	0	1.7	-6.529	0	689	16	0.94
2444	1496	0	10.94	68	26	1	0	1.76	-7.4	0	689	16	0.88
2634	1461	0	10.49	68	23	1	0	1.74	-7.545	0	689	16	0.84
2824	1429	0	10.44	68	21	1	0	1.74	-7.545	0	689	16	0.84
3015	1422	0	10.29	68	20	2	0	1.72	-7.545	0	689	16	0.84
3205	1435	0	10.09	68	19	2	0	1.72	-7.69	0	689	16	0.84
3395	1438	0	9.8	68	19	2	0	1.7	-7.69	0	689	16	0.81
3586	1421	0	10.04	68	20	2	0	1.72	-7.69	0	689	16	0.81
3776	1404	0	10.44	68	21	2	0	1.74	-7.545	0	689	16	0.88
3966	1403	0	10.39	68	20	3	0	1.74	-7.4	0	689	16	0.88
4156	1416	0	10.34	68	18	3	0	1.74	-7.4	0	689	16	0.84
4347	1431	0	10.39	68	16	3	0	1.74	-7.4	0	689	16	0.84
4537	1385	3.92	11.88	69.8	19	4	0	1.86	-7.255	0	689	16	0.91
4727	1366	4.31	14.5	69.8	31	4	0	1.92	-5.659	0	689	16	1.13
4917	1513	4.31	14.55	68	34	3	0	1.92	-5.514	0	689	16	1.16
5108	1468	3.92	14.38	69.8	33	3	0	1.92	-5.369	0	689	16	1.16
5298	1466	3.53	13.78	69.8	33	3	0	1.9	-5.514	0	689	16	1.13
5488	1511	1.57	12.16	69.8	34	3	0	1.82	-6.094	0	689	16	1.03
5679	1506	0	11.66	69.8	32	3	0	1.78	-6.675	0	689	16	0.94
5869	1603	0	10.89	69.8	19	2	0	1.76	-7.4	0	689	16	0.84
6059	1625	0	10.24	69.8	11	2	0	1.72	-8.125	0	689	16	0.78
6249	1606	0	10.29	69.8	12	2	0	1.72	-8.416	0	689	16	0.75
6440	1612	0	9.67	69.8	13	2	0	1.66	-8.706	0	689	16	0.72
6640	1606	0	5.35	69.8	17	2	0	1.58	-9.431	0	689	16	0.59
6830	1557	0	8.19	69.8	19	2	0	1.62	-9.286	0	689	16	0.63
7021	1519	0.78	8.27	69.8	22	2	0	1.64	-9.141	0	689	16	0.63
7211	1465	7.06	11.76	69.8	19	2	0	2.06	-6.82	0	689	16	0.97
7401	1625	7.06	18.44	69.8	35	2	0	2.06	-5.078	0	689	16	1.25
7591	1837	7.06	18.59	69.8	39	2	0	2.08	-5.224	0	689	16	1.22
7782	1858	10.2	21.8	69.8	39	1	0	2.18	-4.498	0	689	16	1.34
7972	1949	10.2	22.23	69.8	40	1	0	2.18	-4.208	0	689	16	1.34
8162	1971	10.98	22.7	69.8	40	1	0	2.18	-3.918	0	689	16	1.38
8362	1895	10.98	23.66	69.8	38	1	0	2.2	-3.773	0	689	16	1.44
8553	1823	10.98	23.09	69.8	37	1	0	2.18	-3.337	0	689	16	1.5
8743	1772	11.37	23.09	69.8	35	1	0	2.2	-3.192	0	689	16	1.53
8933	1680	11.37	22.7	69.8	32	1	0	2.18	-2.902	0	689	16	1.59
9124	1608	11.37	22.33	69.8	30	1	0	2.18	-2.612	0	689	16	1.63
9314	1505	11.37	21.55	69.8	26	2	1	2.12	-2.176	0	689	16	1.69
9504	1417	16.08	19.93	69.8	26	2	1	2.24	-1.741	0.78	689	16	1.69
9694	1703	17.25	25.69	69.8	27	6	-1	2.26	-1.306	2.35	689	16	1.78
9885	1848	17.25	26.41	69.8	31	6	-2	2.3	-1.451	3.53	689	16	1.72
10085	1979	17.25	28.7	69.8	33	7	-3	2.34	-1.596	5.49	689	16	1.72
10275	2201	17.25	30.45	69.8	35	7	-3	2.38	-1.886	7.84	689	16	1.66
10465	2350	16.47	31.88	69.8	36	7	-3	2.4	-2.322	10.59	689	16	1.63
10656	2494	16.08	34.03	69.8	37	11	-3	2.44	-2.902	12.16	689	16	1.63
10846	2654	15.69	34.51	69.8	37	11	-3	2.46	-3.337	11.76	689	16	1.56
11036	2749	14.12	33.06	69.8	38	12	-3	2.42	-4.063	12.55	689	16	1.44
11227	2860	13.73	32.94	69.8	37	12	-3	2.42	-4.498	13.73	689	16	1.38
11417	2997	13.73	32.33	69.8	38	12	-3	2.42	-4.788	14.9	689	16	1.28
11607	3028	13.33	31.99	69.8	39	14	-3	2.4	-5.078	16.86	689	16	1.25
11807	3158	0	16.4	69.8	43	14	0	1.74	-9.141	0	689	16	0.59
11998	3081	0	9.05	69.8	29	16	0	1.66	-10.592	0	689	16	0.38
12188	2789	0	9.36	69.8	23	16	0	1.68	-10.737	0	689	16	0.41
12378	2412	0	9.89	69.8	17	16	0	1.72	-10.592	0	689	16	0.47
12568	1990	4.71	10.09	69.8	17	16	0	1.72	-9.867	0	689	16	0.63
12759	1809	15.29	29.03	69.8	32	16	0	2.34	-4.353	3.53	698	16	1.47
12949	1871	15.69	27.45	69.8	33	16	0	2.3	-2.176	7.84	689	16	1.69
13139	1820	23.53	28.41	69.8	32	16	2	2.36	-1.596	10.59	698	16	1.84
13330	1842	25.88	30.13	69.8	34	16	7	2.36	-0.435	14.12	698	16	1.91
Should i be worried?
druxboyz is offline   Reply With Quote
Old 01-05-2007, 08:47 PM   #2
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
YES BE WORREDI BEWARE!!! HUUHHAHAHAHHHHHHHA! jvio
akira02rex is offline   Reply With Quote
Old 01-05-2007, 09:46 PM   #3
qoncept
Member#: 44762
2013 BRZ
I'm very surprised your IAM didn't drop in that range. I was using an OTS stage 2 map with a ported and polished turbo which was hitting 18psi at 2600rpm (way before the timing map was tuned for), and I had just a few cells with negative KC and my IAM quickly dropped to 4.
qoncept is offline   Reply With Quote
Old 01-05-2007, 10:28 PM   #4
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
i've read a few other threads, mainly http://forums.nasioc.com/forums/show...ight=happy+IAM
so it seems -3 isnt bad after all since my IAM is a constant 16. So would most stock ecu wrx's receive knock of -3's every now and then?
Old 01-06-2007, 10:51 AM   #5
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
You aren't even flooring it. If you're just driving around cruising then -KC is perfectly fine.
The stock timing map sucks balls because the KC map/Main ign. map are so lumpy and this is the very reason you may see -KC in some areas.
You have nothing to worry about.
Old 01-06-2007, 12:28 PM   #6
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
^^^ thanks a lot for your reply. As you know, i'm new to this stuff and I would never have known that -KC is only bad when on 100% throttle.
each noob question i ask, i learn a bit more.
Q about rough knock correction and IAM scoobystas Open Source Reflashes 6 06-04-2010 07:31 PM
my axle is jammed in my diff = Bad? 05ASPINREX Transmission (AT/MT) & Driveline 6 06-01-2009 10:42 PM
Pinched nerve in my neck = bad DoinkMobb Off-Topic 19 07-16-2008 07:10 PM
master or slave? am i correct in my limited subie troubleshooting experience SQ3.0dotJP Transmission (AT/MT) & Driveline 17 10-28-2007 09:52 AM
OpenECU logs Knock Correction but Street Tuner doen't Sausage Engine Management & Tuning 2 03-09-2007 08:13 AM
