Old 01-05-2007, 10:31 PM   #1
impactblue
Member#: 132411
2003 WRX
Default WOT boost oscillation at around 85 mph, please help
Hey guys:
I have searched around for this problem in the last 8 hours but can't come up with a def answer. It seems like other people have the similar problem but no one has mentioned anything about WOT.
Here are my power mods so far:
AP V2 ACN stage 2
Bosal Divered WG downpipe with the stock 3rd cat
HKS Hi-power Axle back
HKS suction air filter
Here is what happened:
Just installed stage2 and the downpipe a week ago. Everything was running smoothly. Boost spikes seem to be very minimum. Then 1 day I was going around 75 mph on the freeway, floored it in 5th and boost reached 1.15 bar, which was what stage 2 was supposed to be at. As soon as I reached 85 mph I noticed my boost just started going back and forth between 1.2 bar and 0.8 bar, non-stop. I was freaking out, then slowed down to around 70 mph and tried it again, and it did the exact same thing when I went over 85 mph. I cant seem to have this problem in any other gear or speed not like others do, except when I go +85 mph at WOT.
P.S: Also tried to go above 85 mph but not at WOT, and there was not boost oscillation presented.
Please help! Any advice would be greatly appreciated.
impactblue is offline   Reply With Quote
Old 01-05-2007, 10:35 PM   #2
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
What year WRX?
blkscooby is offline   Reply With Quote
Old 01-05-2007, 10:36 PM   #3
impactblue
Member#: 132411
2003 WRX
03 bugeye
Old 01-05-2007, 10:40 PM   #4
fastlanerex
Member#: 133391
2004 boosted saleen
white
I know that when me and my boy did my downpipe it was invidia v3 divorced wastegate and my boost pressure does the same thing. My boy said its cause the wastegate is going nuts "also has to do with the computer" cause its building too much boost too fast and doesnt know what to do with it. A good protune and you should be good my protune stopped it. Hope this helps.
fastlanerex is offline   Reply With Quote
Old 01-05-2007, 10:43 PM   #5
impactblue
Member#: 132411
2003 WRX
A protune..........emmmmmmmm.......sounds like something i shoulda done.
Thank you very much fast!!
Old 01-05-2007, 10:46 PM   #6
fastlanerex
Member#: 133391
2004 boosted saleen
white
I forgot to mention you can adjust the wastegate where the little pole sticks towards the downpipe. Theres a c clip that holds it on take it off and give it like 2-3 turns do it gradually and test run it in between watch for boost spike if that occurs its too tight and u need to loosen it some.
Old 01-05-2007, 10:46 PM   #7
hondaeater69
Member#: 60324
yup ya needs a tune. keep in mind those OTS maps are just that... they are one size fits all.
be sure to tell the tuner your issues, and make sure he spends a decent amount of time tuning your boost map.
Old 01-05-2007, 10:48 PM   #8
fastlanerex
Member#: 133391
2004 boosted saleen
white
no prob i got protuned and got the wastegate adjusted on mine.
StreetTUNER (AP Ver 1.0)
For the AccessPORT Ver 1.0
AccessECU's StreetTUNER upgrade for the AccessPORT is for enthusiasts who want the ability to “tweak” their mapping. The StreetTUNER software runs on a PC-compatible computer to allow for end-user programming of the factory ECU.
Old 01-05-2007, 10:57 PM   #9
impactblue
Member#: 132411
2003 WRX
Thank you very very very much guys. I def feel the love in here.
Old 01-05-2007, 11:06 PM   #10
fastlanerex
Member#: 133391
2004 boosted saleen
white
Smile
yea man any time make sure you get it tuned on a dyno if u have an accessport though you have to buy that upgrade tuner program and then take that to a reputable tuner that is familiar with the accessport and protunes.
Old 01-06-2007, 06:39 PM   #11
impactblue
Member#: 132411
2003 WRX
So in order to get my car protune i will have to buy the street tuner software?
Old 01-07-2007, 12:35 AM   #12
RationalGaze
Member#: 133751
2003 Impreza WRX
World Rally Blue
No, all you need to do is take your AP with you to the tuner who does ProtTunes.
In other words: if the tuner does cobb ProTuning, all you do is bring the AP with you.
RationalGaze is offline   Reply With Quote
Old 01-07-2007, 01:59 AM   #13
MdWRX
Member#: 69636
2002 Wrx
Sedona Red
My car started to have an oscillation problem only after my protune, make sure you tell your tuner what the car is doing so they can adjust for it. I talked to mine and he said that the gain may be off but I havent had a chance to take it to him again to get it adjusted.
MdWRX is offline   Reply With Quote
Old 01-07-2007, 06:05 AM   #14
impactblue
Member#: 132411
2003 WRX
Just wondering how much does a protune normally run? and how long it takes?
Old 01-07-2007, 09:33 AM   #15
jupiterrex
Member#: 119970
2006 WRX Wagon
Grocery Getter!
I would say it would cost anywhere from 350-500 depending on the shop, and the time needed. shouldn't take more than like two hours... maybe three.
jupiterrex is offline   Reply With Quote
rattling at 3,000 rpm please help! madeguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-01-2006 02:46 AM
boost gauge light wont turn off, please help! jmanny152 Electrical & Lighting 4 02-20-2005 10:39 PM
boost then low idle then stall? please help me!!?? zavala Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-03-2004 04:58 PM
Bucking/Surging at constant 2750 rpm.. Please help wyowrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-15-2003 09:52 PM
humming at around 35+ MPH? sangree99a Brakes, Steering & Suspension 4 05-13-2003 01:55 PM
