Old 11-23-2001, 05:26 PM   #1
Fubaru
Member#: 6046
'08 Prius
Default Engine coolant Q
The coolant reservoir in my subie looks like it could use a refreshment. A few questions:
Can I just top it off with tap water + Prestone?
Manual recommends the "Subaru" brand coolant + "soft" water.
It also specifies "never mix different kinds of coolant"
I was thinking about just adding Prestone + DI water, 50/50 mix.
Fubaru is offline   Reply With Quote
Old 11-23-2001, 06:46 PM   #2
dave1rr
Member#: 2826
1996 Impreza Outback
Deep Navy Pearl/Slate
Just use distilled water and the coolant of your choice. Change it every year or two and you'll never have a problem.
Dave
dave1rr is offline   Reply With Quote
Old 11-23-2001, 09:41 PM   #3
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Dave
I'm not trying to nitpick, but just in case, remember, don't mix the longlife pink coolant like GM uses with normal coolant as it causes REALLY BAD things to happen.
-Jason
jay25RS is offline   Reply With Quote
Old 11-23-2001, 11:37 PM   #4
Fubaru
Member#: 6046
'08 Prius
jay25rs, I'm pretty sure that although GM owns a piece of FHI, the coolant used by Subaru is not that long life dexcool stuff (yet).
Just curious, what happens to the coolant system when you mix the pink & green antifreeze?
Old 11-23-2001, 11:52 PM   #5
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Fubaru:
I realize that Subaru doesn't use dexcool stuff yet, I was just cautioning to not add dexcool to our system.
When you mix the two, I've heard that it creates a black hole and sucks all of the technology out of our cars.
Seriously though, I think that it corrodes something including headgaskets and creates major problems.
-Jason
Old 11-24-2001, 02:47 AM   #6
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Here is a good thread on Dexcool: "Click Me"
Please read through it to learn about the problems associated with using Dexcool.
Richard
http://www.whitetyphoon.com/impreza/
Richard L. is offline   Reply With Quote
Old 11-25-2001, 12:20 AM   #7
cruzito
Member#: 11159
2000 ImprezaRS
Question
I'm just wondering, is there a drain plug on the block itself?
cruzito is offline   Reply With Quote
Old 11-25-2001, 01:00 AM   #8
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Thumbs up
yes there is a block drain for the coolant in the heads. One for each side. If you have a WRX the one on the passenger side is used for the Oil cooler, either supply or return I am not sure. But the one on the drivers is not used and is a plug with a 14mm allen socket in the center. This one can also be used for the block heater. But alas the Universal block heater's cord is not long enough to reach the little cut out in the bumber. As was designed to go in the passenger side plug. I found this out I am not sure if there is a drain on the center section of the block.
Just a little info
Happy Motoring
mr2guru is offline   Reply With Quote
Old 11-25-2001, 02:37 AM   #9
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
cruzito, on your 2000 RS, there are two engine block drain plugs, one behind the oil filter and one behind the thermostat housing.
Here is a pic of the passenger's side one:
Here is a pic of the driver's side one:
The service manual says to remove both drain plugs when draining the coolant. I don't think a 14mm allen socket will fit since the drain plugs are around 13mm.
Richard
Old 11-26-2001, 04:04 AM   #10
cruzito
Member#: 11159
2000 ImprezaRS
Default Thanks
Thanks Richard L, and Mr2guru for the info and picture, I'll go ahead and change the coolant right now. Totally, appreciate it you guys are awesome.
Old 11-26-2001, 11:17 AM   #11
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default DEX-COOL
I think that people who are afraid to use Dex-Cool are missing the point. You have to be a morron to believe that any coolant will last 5 years and/or 150k miles in a car. That's a ridiculous claim. You'll be lucky if it lasts that long sitting in its container. That's, by the way, the biggest advantage of Dex-Cool. The green stuff has a shelf life of only 18 months. You have to wonder if it set in the store longer than that before you bought it, plus you have to use it immediately. Dex-Cool is supposed to last 8 years unopened. This is a real advantage. If it sits for years in a local WalMart, you can still be reasonably sure that it's fresh when you buy it.
3 years and 30k miles is already pushing it, even with a long-life coolant. I would not keep any type of coolant longer than 2 years in my car. The green stuff should be changed every year, the red (or blue) stuff can go for 2 years. It takes a few hours to change it and it's not a big deal.
I have heard from many professionals that Mercedes antifreeze is the best. It's more expensive, but you get what you paid for.
Oh yeah, don't forget to change your brake fluid once a year, too.
vvk is offline   Reply With Quote
Old 11-26-2001, 09:31 PM   #12
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
I don't know where you got that idea. Sealed ethylene glycol antifreeze has a VERY long shelf life. See the Prestone FAQ where it specifically states the stuff is good for MANY years.
Now I suppose the enviromentally friendly stuff might well be less stable - but for normal antifreeze, just use it.
Alan is offline   Reply With Quote
Old 11-26-2001, 11:34 PM   #13
Delhi
Member#: 4511
Default how much?
How much is the total volume capacity of the our 2.5l engine holds? Do I need 2 cans to drain them?
Thanks. And Do I need to jack the car up?
Delhi is offline   Reply With Quote
Old 11-27-2001, 02:33 AM   #14
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Delhi, total capacity for the 2.5L is 6.2 quarts. What did you mean by two cans? You will need a large drain pan to catch the used coolant. You should not have to jack up the car. However, you might have a tough time trying to remove the two engine block drain plugs.
You will need to get a gallon of coolant and a gallon of distilled water for refilling the radiator and the engine block.
Richard
Old 11-27-2001, 01:49 PM   #15
Delhi
Member#: 4511
thanks rich.
what i meant was since there' two drain hole, won't u need 2 catch pan then?
Old 11-27-2001, 02:02 PM   #16
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
You don't really need two catch pans. Just drain the radiator first, then move your catch pan under the passenger's side drain hole and drain it, then move your catch pan under the driver's side drain hole and drain it. Having two catch pans might be more convenient, however.
Richard
Old 11-30-2001, 11:37 AM   #17
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default DEX-COOL
Look at this article for explanation of DEX-COOL "problems":
Click Here
As far as Prestone, I have had problems with it and I have read bad reviews. Once I had a water pump fail two weeks after flushing the system and filling with regular Prestone.
Old 11-30-2001, 03:22 PM   #18
AndyHidley
Member#: 1031
It more than likely was the flush that ruined the "aged" H2O pump, not the new antifreeze
AndyHidley is offline   Reply With Quote
Old 12-01-2001, 03:58 AM   #19
jhonas
Member#: 9015
2002 Impreza 2.5RS
Platinum Silver Metallic
What do you think about those flush kits where you hook up a garden hose into a little fitting on one of the coolant hoses, and open the radiator cap and let the water flow through while the engine runs?
That was a little long winded, hopefully you can make sense of it.
-Matt
jhonas is offline   Reply With Quote
Old 12-01-2001, 11:40 PM   #20
AndyHidley
Member#: 1031
My neighbor buys old cars and fixes them up and sells em.. He use to use the flush stuff and said that everytime he used it on a "tired" water pump he always ended up replacing it cause it would "go" .. Now he just drains the old antifreeze and puts in water and a box of arm and hammer baking soda, lets it run for awhile and flushes it out good with lots of water and then puts in new antifreeze.....
Also here is a fact for you guys... Keep your radiator filled to the top.. If its not to the top then air is in it and it'll cause corrosion/rust . If its full it wont happen
Old 12-02-2001, 10:55 AM   #21
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
I'm sure the plug on the passenger side is 14mm, I've removed it to install an oil cooler. It's a bugger to get out and even harder to find a 14mm Allen.
http://www.scoobymods.com/mods/impreza/oilcooler.php
With a WRX you have the cooler already so you only have to remove the hose from the plug/nipple that's there. Which is a lot easier.
On the drivers side it would be easier to just drop the thermostat housing rather than getting that plug out.
Peaty is offline   Reply With Quote
Old 12-02-2001, 04:16 PM   #22
fatVdub
Member#: 5296
01 2.5RS
so what brand of coolent do you guys recommend? im stick'n' to the green stuff...Dexcool stuff won't hurt....if you flush the entire system...GM uses it, prob.'s are with their cooling design...VW uses it in MOST and all of their passat's amd GTI's( info. from a tech. buddy that works for VW in Reno)...but as far as brands go what the consensus(sp)??
fatVdub is offline   Reply With Quote
Old 12-02-2001, 11:44 PM   #23
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
I personally use regular green Prestone mixed with distilled water.
Richard
Old 12-04-2001, 11:27 AM   #24
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default block plugs
14mm allen is usually available from neighborhood hardware stores. Get one at least 6 inches long on one side. Also get a long steel pipe to be used as a lever. Works like a charm. It's probably better to have another person to help you. They can turn the pipe while you are holding the allen key in the plug. Wear eye protection.
I just did one of my Imprezas this Sunday. It was a piece of cake. Actually, the plugs were not so tight because this is the second time I change coolant in this car and I used Loctite with Teflon on the plugs last time. Initially they were very tight, but I used a 4 foot pipe for leverage...
The best "green" antifreeze I've found is Zerex by Valvoline. It's cheap and available at Wal-Mart. They also list chemical content on the container, so you know what's in it. As far as I can tell, it does not contain silicates, which is a Japanese engine requirement. Contains phosphates, though, so it's not for my SAAB.
I've been using DEX-COOL in all my cars for a while, without any problems. Just did my inlaws' Cavalier, too. Original DEX-COOL came out clear and new-looking. It's been in there for 5 years and 115K miles. Stupid cooling system design, though. You can tell that they heavily borrowed from OPEL, but did not borrow everything. The bleeding hole is too small, so you have to wait forever for the air to come out. Very, very poor design.
Engine coolant gone and all over engine bay junkboxer Service & Maintenance 3 02-23-2008 08:15 PM
Changed engine coolant...engine heats up stxwrx69 Newbies & FAQs 7 12-30-2006 11:40 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 03:42 AM
CEL.......Engine Coolant very low?!?!? JoeBloggz23 New England Impreza Club Forum -- NESIC 6 10-15-2001 01:53 PM
Drain the engine coolant w/o removing plugs? jasony Newbies & FAQs 5 05-20-2001 10:09 PM
