Old 01-06-2007, 11:34 PM   #1
ZOINKS!
Member#: 12884
2002 WRX Sedan
WR Blue
Default 2002 WRX A/C questions
My A/C started making gurgling noises and quit blowing cold air. Performed some troubleshooting, and it wouldn't hold a vacuum. Put a small amount of 134a back into the system and detected a leak where the high-pressure line joins with the compressor.
Thinking the O-ring that fits into the coupling where the high pressure line joins with the compressor may need replacing, I ordered one through a dealership. The part number they used (73039AA030 PT751093 on the invoice) is not correct-it's too large in diameter and not thick enough.
Questions:
1. Does anyone happen to know the correct Subaru part number for that O-Ring?
2. Does anyone know the recommended viscosity of the DH-PR PAG compressor oil?
3. And, of course, has anyone experienced a leak in their A/C at this place?
Thanks
ZOINKS! is offline   Reply With Quote
Old 01-07-2007, 01:43 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
probably 73039FA100 for the o-ring
Old 01-07-2007, 05:06 PM   #3
ZOINKS!
Member#: 12884
2002 WRX Sedan
WR Blue
Thanks Doc.
Where did you find that information on the o-ring?
Any idea on the compressor oil viscosity?
Old 01-07-2007, 09:55 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
www.subaruparts.com - they have a picture based part lookup - there are two connections to the compressor - one uses the o-ring you have, and the other one uses the one I mentioned above
2002/2002 WRX Factory Sub Question awdsvx Alaskan Impreza Club Forum -- AKIC 3 04-11-2003 03:16 PM
To all 2002 WRX owners ... stupid question Snake Eyes Bay Area Impreza Club Forum -- BAIC 9 12-21-2001 06:45 PM
2002 WRX Mod benefits question. TFW Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-25-2001 06:46 PM
just got a 2002 wrx with 16's..question wrxxtc Brakes, Steering & Suspension 2 10-25-2001 11:30 AM
('93-'01) Just owned 2002 WRX, have some questions? sj208 Impreza Forum 4 05-16-2001 06:28 AM
