Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 01-07-2007, 12:54 AM   #1
Member#: 85568
02 EJ257 FP Green
Blaze Yellow
Default cam seal installation help for a noob
Does anyone have a good method for installing these?
I am using a 1 1/2" socket, rubber mallet and a dialetric grease. The cam seal's seem to almost completely press in by hand and then I tap them lightly with the socket/mallet to seat them the rest of the way.
A couple times when I have tried to install a cam seal, it goes in completely crooked like it is stuck on something. When this happens I remove the cap and the seal to try again, but 50% of the time the seal gets damaged. I have inspected the cap and it doesn't look jagged anywhere. I'm not sure if it is badluck or if I am installing it wrong.
I would definietely appreciate some advice from those of you more knowledgable.
q2brass is offline   Reply With Quote
Old 01-07-2007, 03:53 PM   #2
Member#: 34773
2013 WRX STi
I remember me and my friend going threw a few cam seals on LT4 when doing new heads, cams, intake, ect... We tried sockets, tubes of all sorts until we found the "Perfect" piece of copper pipe that mated pefecty with the O ring, it didnt leave any of the seal exposed when we pressed it into place, also it perfect size didnt alow any play when sliding it into place on the cam shaft. He keeps this piece of copper in his tool box with GM Special Tool #5 writen on it. Needless to say we have invented a few GM Special Tools.
Now I havent seen ours yet, but I can only assume its just as much of a PITA without the Factory Subaru tools. And being any sort of off on the install is going to destroy that seal.
So reinspecting your tool of choice might be your solution. Its prob nothing bured or jagged. We thought the same thing doing our cam, we went through a few and I remember them being stupid money to by from the dealer.
Cheveyboy is offline   Reply With Quote
Old 01-07-2007, 05:47 PM   #3
Member#: 94070
05 LGT
Yep its all about the tools. ^^^^
dibblejr is offline   Reply With Quote
Grease for cam seal install? anon_az Service & Maintenance 2 10-08-2009 06:27 AM
cam seal install tool - what size socket instead? HOLLYW00D Built Motor Discussion 6 05-28-2008 08:41 AM
failed cam seal install?? kmo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-19-2007 07:15 PM
Cam seal installer for 04+ STi DoctorNick Service & Maintenance 1 01-14-2006 12:32 PM
Cam seal install? Boost4U Service & Maintenance 1 06-16-2003 05:17 PM
