Old 01-07-2007, 04:38 PM   #1
Lawrence
Member#: 82518
2005 wrx
Default Oil change
I Just did an oil change yesterday. So i did everything fine except there is oil drippping. Kinda scared...If I did anything wrong.
This is what i did.
Took out the 17mm bolt from the oil pan.
Took out the filter.
Replace the ring with a newer one.
screwed the filter but forgot to lubricate it
When I tightened the 17mm bolt to the oil pan and it maid cracking sound.
(I think thats where i went wrong. Did I strip the oil pan?)
How much am I supposed to tighten?
Please help
Lawrence
Lawrence is offline   Reply With Quote
Old 01-07-2007, 04:47 PM   #2
bbaker80
Member#: 41517
2005 WRX Wagon
WR Blue
Did you look underneath to see where the oil is dripping from?
bbaker80 is offline   Reply With Quote
Old 01-07-2007, 04:48 PM   #3
IIdiceII
Member#: 90438
is it dripping from the drain plug or the oil filter?
you might have cross threaded the drain plug...
IIdiceII is offline   Reply With Quote
Old 01-07-2007, 05:10 PM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
May have been some dirt/small gravel particle that whent crunch...Or could have over tightened it, or it may not be tight enough...I would back it off some and check if threads are OK, (you can turn plug by hand a few turns) and re-tighten.
wrxdrvr is offline   Reply With Quote
Old 01-08-2007, 02:07 AM   #5
Lawrence
Member#: 82518
2005 wrx
sorry about the late reply. The drip is actually from the drain plug. Do you know the torque spec on the bolt?
Old 01-08-2007, 02:07 AM   #6
Lawrence
Member#: 82518
2005 wrx
If I really have cross threaded it, How can I fix it? Do i have to get a brand new oil pan?
Old 01-08-2007, 03:42 AM   #7
silver-RS
Member#: 94447
2005 2.5RS
i've done 3 oil change with my subaru
and i didnt really tighten it according to the torque spec
i just make sure i dont OVER-tighten it
anyway...i think there's better way to fix it than to buy a new oil pan
its alot of work...stop by a local mechanic and ask for PROFESIONAL ADVICE!
silver-RS is offline   Reply With Quote
Old 01-08-2007, 05:15 PM   #8
Lawrence
Member#: 82518
2005 wrx
For some reason it stop dripping
Old 01-08-2007, 05:45 PM   #9
vividwrx13
Member#: 66402
2005 STi Ver8
out of oil??? lol j/k man...did u replace the crush washeR?
vividwrx13 is offline   Reply With Quote
Old 01-08-2007, 07:27 PM   #10
SubiRS05
Member#: 104925
2006 vf39 wrx
cgm
hmm...hit up the dealer
SubiRS05 is offline   Reply With Quote
Old 01-08-2007, 07:28 PM   #11
59wrx
Member#: 115099
2005 Evo VIII MR
Graphite Grey
Default Replace, replace, replace!!!
good call my friend! You should ALWAYS replace the drain plug crush washer when changing your oil.
It will distort and will not seal correctly. For the <$1.00 it costs, is it worth a new engine not to replace it?
Okay, so it won't leak enough to cause engine failure, but it will make you fell a whole lot better if you don't see any leaks!!!
59wrx is offline   Reply With Quote
Just did my first oil change/gear oil change since i got my car ayobreezie Newbies & FAQs 12 07-19-2006 09:29 AM
change oil filter with every oil change? BlackBeastie Service & Maintenance 1 03-15-2003 08:29 PM
2nd oil change and which oils to change? makofoto Service & Maintenance 4 12-28-2002 09:07 PM
