Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 01-07-2007, 05:42 PM   #1
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
Default STX EcuTek tuned wrx only 10psi?
Was professionally tuned a while ago. Never really saw a lot of psi, but now it seems to level/steady off around 10PSI. I am at altitude (5280ft), but I'd still expect more up here.
Mods are bosal DP, Helix UP, custom 3 inch exhaust w HF cat, and ecutek.
I'm not positive, but there might be a leak on the uppipe. Would that cause this? Should I get full PSI back (if only for a bit) if I reset the ecu and test it (I haven't done this yet)?
The boost does spike to around 12-13 psi before leveling off, likely due to my downpipe.
xcdhridr is offline   Reply With Quote
Old 01-07-2007, 05:48 PM   #2
qoncept
Member#: 44762
2013 BRZ
Sounds more like a boost leak if anything, or you may have your boost control solenoid connected backwards. Have you made any changes?
Check when you're at 10psi, too. At redline thats as much boost as you should be running.
qoncept is offline   Reply With Quote
Old 01-11-2007, 08:30 PM   #3
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
no changes =(
If there a snazzy way to check for a boost leak?
Old 01-11-2007, 10:41 PM   #4
qoncept
Member#: 44762
2013 BRZ
You can pressurize the intake with a compressor. There should be a number of threads that discuss this.
Old 01-12-2007, 03:00 PM   #5
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
I thought STX does not allow any changes to boost levels???
minifreak is offline   Reply With Quote
Old 01-12-2007, 05:07 PM   #6
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
It doesn't - which means if he is running 10psi, something is wrong with the car physically.
mcowger is offline   Reply With Quote
Stage 2 WRX only hitting 10psi. WhiteRu AccessPort 25 12-30-2010 04:36 PM
FS: ECUtek tuned WRX 02-03 ECU SnowmanFX TXIC Private Classifieds 2 01-29-2010 10:46 AM
SoCal 05 STX WRX, only 14k garage kept. stubaru88 Private Vehicle 'For Sale' Classifieds 1 01-09-2008 11:35 PM
'07 STI - SPT Cat Back only with Ecutek Tune vs stock Dyno Flash Proven Power Bragging 54 08-09-2007 12:38 PM
New boost gauge, pulling lots of vaccum and only 10psi WOT??? I am b Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-02-2001 03:37 AM
