Old 08-10-2007, 01:44 AM   #51
domestic_abuser
Member Sales Rating: (14)
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Can you give us the link to the exact radiator you bought.
Originally Posted by IMPORTIMAGE View Post
hmm? aftermarket fans arent moving enough air at low speed...i need to get the switch wired in right...
stock= not overheating...so hmm!?
domestic_abuser is offline   Reply With Quote
Old 08-10-2007, 09:33 AM   #52
IMPORTIMAGE
NASIOC Storefront Vendor
Vendor Sales Rating: (617)
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
i forget, send a pm to jetfan8178, i have way to many paypals to figure out who i sent what to. (he won the auction, i paid as he put it together)
IMPORTIMAGE is offline   Reply With Quote
Old 10-08-2007, 01:32 PM   #53
breathinez
Member Sales Rating: (20)
Member#: 79859
2002 384 whp
332.5 lbs
So the Mishimoto is good? There is no info on the radiator that was in the pic that Import Image was using. So we don't know what not to buy. My radiator cracked this weekend at VIR and I need something now and can't afford the Koyo. I haven't looked at the Haste but I will shortly. The Mishimoto does use the stock fans correct?
breathinez is offline   Reply With Quote
Old 10-08-2007, 03:16 PM   #54
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
yeah i finally got it all under control, whenever business slows down ill have to dig through my parts and take a pic so you can see what NOT to buy...my PWR radiator now even with the ac on with my gms thermostat and upgraded hoses (stock fans) stays at about 1 quarter even with the ac on around 85 degrees...
during the heat of the day it still doesnt even come close to the middle. of the coolant temp gauge.
Old 10-08-2007, 03:33 PM   #55
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
I'm thinking the radiator not cooling like it should and then eventually failing is why I've been having some performance issues. The PWR is kind of expensive to isn't it?
Old 12-14-2007, 01:30 AM   #56
txl146
Member Sales Rating: (145)
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
so what's the final consensus about the eBay radiator?
Old 04-19-2008, 02:27 AM   #57
rougeben83
Member Sales Rating: (62)
Member#: 115154
2005 Outback XT
White on grey
Bump, anyone have the generic Ebay aluminum ones? Not the Haste or Mishimoto?
rougeben83 is offline   Reply With Quote
Old 06-19-2008, 11:16 PM   #58
qhatherly
Member#: 80121
2002 GDA w/ complete
06 STi conv +GT30R etc.
I just finished test fitting one and it fits perfect. I'll put up some pics in a minute.
qhatherly is offline   Reply With Quote
Old 06-19-2008, 11:24 PM   #59
qhatherly
Member#: 80121
Let me know if these pics don't work.
Old 07-21-2008, 03:32 AM   #60
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
I thought I'd post some feedback regarding a cheap radiator I purchased for my bugeye.
I got a JustJap "cooling pro" alloy radiator a few months back after my oem one cracked and have not had an problem with it apart from needing to replace the cheap radiator cap with one that works.
It fit into place without any problems using the factory top brackets and the slots at the bottom and included all mounting holes required to mount the oem fans and hosing brackets.
As I mentioned at the begining, it came with a cheap radiator cap which I needed to replace - once replaced with a new cap (I got a Buddy Club cap) all was good.
During logging tests, the Justjap "cooling pro" radiator is more efficient at cooling, running up to 20 deg C cooler then oem.
I have plotted the stats from the log into a graph (below) for visual comparison. You can see water temps from both radiators start at around 92 Deg C, but the oem water temps continue to increase until it plateaus at around 97 Deg C, while the Just Jap "Cooling Pro" water temps continue to drop until it plateaus at around 79 Deg C, highlighting its better cooling efficiency.
Some pics (sorry about photo quality) - radiator
A close-up showing one of the fan mounting points and welds:
Another close-up showing fan mounted and welds:
Edit: A link to the JustJap "Cooling Pro" alloy radiator page is HERE. Also of importance, if you do buy one, ensure you order the correct one as there are a few different types for the WRX
wrxsti.l is offline   Reply With Quote
Old 07-21-2008, 09:35 AM   #61
jheeno
Member Sales Rating: (1)
Member#: 177805
2007 WRX
very nice,
youve convinced me to buy
JJR are less than 10km away from me too!
did it come with the fan ? or was the OEM fan used
jheeno is online now   Reply With Quote
Old 07-21-2008, 11:13 AM   #62
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
No fans included - but it has all the mounting points for the standard fans - they bolt straight up
Old 11-11-2008, 09:50 PM   #63
Nick Boxler
Member Sales Rating: (3)
Member#: 180326
2005 WRX
HTA68'ed San Remo Red
anybody try the CXRacing radiator on eBay?
their intercoolers are known for being nice, just wondered if their radiators would be the same.
the pics on their ebay posting show it installed, all nice and purdy.
http://cgi.ebay.com/ebaymotors/CXRac...Q5fAccessories
Nick Boxler is offline   Reply With Quote
Old 11-12-2008, 10:17 PM   #64
2gnt2wrx
Member Sales Rating: (61)
Member#: 123625
2015 WRX
Galaxy Blue
Audiosavy has one and has reported it to be a perfect fit and very good construction. I just ordered one today and will be putting it on sometime next week. I'll letcha know.
2gnt2wrx is offline   Reply With Quote
Old 11-13-2008, 03:06 AM   #65
texask5
Member#: 179131
I also have a cx racing radiator. Fit it great and definetly quite a big thicker than the factory radiator. Fans fit in perfectly. As of about two months no problems, and not forseeing any.
texask5 is offline   Reply With Quote
Old 11-13-2008, 09:47 PM   #66
Nick Boxler
Member#: 180326
2005 WRX
great, thanks!
unless i find an OEM radiator for cheap soon, i'll just be getting a CXRacing one as well.
Old 02-10-2009, 01:18 PM   #67
Tar--Mac
Member Sales Rating: (6)
Member#: 163754
2002 Impreza WRX
just wanted to add my $.02.. just put in a CXRacing radiator from ebay, Fit PERFECT with all OEM mounting points, solid construction and the core is twice as thick as OEM... definitely reccomend this radiator to anyone!
Rad has been going strong for 2 months now with no leaks or anything! Definitely satisfied...
Tar--Mac is offline   Reply With Quote
Old 02-11-2009, 03:06 PM   #68
FunkRider
Member#: 195055
I installed a CXRacing radiator last month after my stocker exploded. 100% perfect fitment minus trimming the rad hoses. Amazing price too.
FunkRider is offline   Reply With Quote
Old 04-08-2009, 07:08 PM   #69
mystilexzero
Member Sales Rating: (15)
Member#: 154674
2007 wrx
ugm
so is the cxracing radiator alot better than the oem unit? im trying to cool down my car a little more than stock, considering i dont see a really good NEED for them as i see gt35 sti's run oem radiators, i just want my car to run cooler in the summer time. anyone log with the cxracing radiator?
mystilexzero is offline   Reply With Quote
Old 04-08-2009, 08:28 PM   #70
rigpin
Member Sales Rating: (11)
Member#: 31529
1974 datsun z
soon to be silver
Thumbs up Mishimoto
I've had a Mishimoto rad on my track car (240sx) for over a year with no problems so far. The temps have been a constant 180F in just about ant weather even on the track. Had no problems with fitment either.
rigpin is offline   Reply With Quote
Old 04-14-2009, 11:07 AM   #71
Kavik
Member Sales Rating: (29)
Member#: 112278
2003 Sonic wrx wagon
2005 blue "wrx" Wagon
question about this CXRacing Radiator VS. this CXRacing Radiator
I have an '03 WRX, the first one says it's specific to 2002, but the one that says it's for 2002-2007 has the extra radiator cap on top. My stock one doesn't, so I want to replace it with this one that doesn't, right?
All the other measurements are the same on both
Kavik is offline   Reply With Quote
Old 04-17-2009, 05:54 PM   #72
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I'm looking for a new radiator for my 02 also, and even though the 02's don't have the filler neck you should get one that does. It's a better design and makes filling the radiator much easier b/c you can see when the level drops when burping and can add accordingly.
Superorb is offline   Reply With Quote
Old 04-18-2009, 04:23 PM   #73
gregnice123
Member Sales Rating: (2)
Member#: 165609
2006 WRX
Aspen white
Unhappy
I guess its really hit or miss with these cheapy (ebay and mishimoto) radiators. I'm on my second CXR (and crossing my fingers) hopefuly it won't leak at the seam AGAIN. My cousin is on his THIRD mishiNONO. Yes these cheapies do offer their limited warranties, but after all this trouble and how much I value my time (removing, reinstalling, and bleeding these darn things); I've figured out that only thing these companies can stand behind is their limited warranties, NOT their quality. Sure, if it leaks or you receive a warped radiator they will replace it, but then you are down on shipping costs, and not to mention the time to put them back in. Then after all that, I continue to worry if it will hold up! All the extra time and money could have gone toward a reputable brand in the first place. That is actually next on my wish list.
gregnice123 is offline   Reply With Quote
Old 04-26-2009, 04:04 AM   #74
Horkus
Member#: 112667
2002 WRX wagon
I just bought one installed it, it was awsome so far no leaks nothing.
http://forums.nasioc.com/forums/show...679917&page=18
Horkus is offline   Reply With Quote
Old 04-27-2009, 06:38 AM   #75
Horkus
Member#: 112667
2002 WRX wagon
So I've finally have a pissing stock radiator I want to get rid off. So called around locally for some replacement Rads. All I found out was plastic rads including Genuine factory Subaru Rads are all over priced.
They were priced from $300-600 only plastic ones.
So Went to Ebay checked this out and found an All aluminum RAd for $180 shipped. So I went for it and within 5 days I received it.
Below are what I've done:
Open box time.
Replacing the Thermostat was a may as well thing. Trust me it's worth doing it at this time a lot more access.
you need to trim the ends approx 1/4" each end as this rad is 1/2" thicker than stock.
Aluminum Radiator from EBAY green rims Car Part Reviews 3 12-10-2008 04:11 PM
Ebay all aluminum radiator? Chi_San General Community 18 08-30-2008 05:56 PM
Ebay Aluminum Radiator $140 shipped sexycat Engine/Power/Exhaust 2 08-02-2008 07:48 PM
anyone on ebay all aluminum radiators? scobaru Pre-2002 Factory Turbo Powertrain 5 06-28-2008 11:13 PM
ebay aluminum radiators lightning1458 North West Impreza Club Forum -- NWIC 15 03-06-2008 01:27 AM
