Old 07-15-2009, 10:55 AM   #101
Mishimoto
NASIOC Manufacturer
Vendor Sales Rating: (-1)
Member#: 207954
Originally Posted by mystilexzero View Post
is that a plastic cap on the mishimoto radiator wtf??
No, none of our radiators have plastic caps.
Mishimoto is offline   Reply With Quote
Old 11-23-2009, 11:25 PM   #102
ayoraider07
Member Sales Rating: (2)
Member#: 223688
2004 wrx
I have the CXRacing radiator on a 04 wrx, I am currently using the stock upper/lower hoses, but my upper is swollen and needs to be replaced...So I got a Gates hose and it will not fit without rubbing on the (passenger-side)pulley, anyone else have issues or know which hose to get for optimal fitment using a CXRacing aluminum rad(off ebay)?
ayoraider07 is offline   Reply With Quote
Old 11-24-2009, 11:18 PM   #103
WeldingHank
Member Sales Rating: (22)
Member#: 98645
2002 WRX Wagon
trim the hose, it should be fine.
WeldingHank is offline   Reply With Quote
Old 12-23-2009, 09:58 PM   #104
XmikeX
Member Sales Rating: (9)
Member#: 184768
05 WRX
toasted white
read through all of these reviews and got kind of confused so it loks like mishimoto, cxracing, koyo are all the ebay radiators. seems like someone has a problem with each one.. so i guess its a hit or miss
XmikeX is offline   Reply With Quote
Old 01-04-2010, 09:12 PM   #105
0260B4U
Member Sales Rating: (1)
Member#: 33249
2003 WRX
white
So after a very long jaunt on the test track the other day my stocker seems to have split at a seam. Only leaks during hard acceleration but still it spraying right on the front of my manifold from under the radiator shroud.
Im looking at this rad on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...category=33602
Which one is this considered? Im really not worried much about superior increases in cooling since I dont AutoX anymore. Just a suitable replacement for the OEM one.
Or a lil larger one WITH the fans(im assuming they are bigger or higher efficiency?) or is that overkill for another 100 bux?
And should I put in a lower temp thermostat while im in there?
0260B4U is offline   Reply With Quote
Old 01-05-2010, 04:47 PM   #106
ownnij
Member Sales Rating: (17)
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
you can try that radiator but its risky because there isnt anyone that has documented that they have tried it. why not try the cxracing radiator? supposively you can see the difference in quality in the welds. i've had koyos all in my cars but had no real reason to replace it in the subie.
use your oem fans, they work very nice.
lower temp thermostat? why not? i got one. it's pretty cheap. grimmspeed FTW.
ownnij is offline   Reply With Quote
Old 01-05-2010, 07:24 PM   #107
0260B4U
Member#: 33249
2003 WRX
white
I know its one of those things that backfire, but Im trying to go as cheap as possible with funds being tight until taxes come around.
Old 01-06-2010, 11:17 AM   #108
ownnij
Member#: 70459
i know man. hard times and not many of us have the funds like we used to but you hear stories all the time about people buying cheaper parts and then back firing.
i know one of these radiators backfired but all the others are fine. like mentioned before every radiator company has at least one failure.
Old 01-07-2010, 10:42 PM   #109
Davidss
Member#: 27446
I bought this radiator off ebay (seller name turboworks):
http://cgi.ebay.com/ebaymotors/ws/eB...m=120510202036
When it arrived it actually has all the cxracing logos on it. It's well constructed and fits great. I actually pressurized it in a dunk tank when I got it to check for future pinhole leaks and everything was perfect!
So I am very happy with my $120 ebay radiator. If it goes out I will post an update!
Davidss is offline   Reply With Quote
Old 01-08-2010, 01:09 PM   #110
Box3r
Member#: 210057
Davidss, you're worried about the lack of a warranty on that radiator? Looks to be only a 30 day warranty.
Box3r is offline   Reply With Quote
Old 01-08-2010, 01:11 PM   #111
Mishimoto
NASIOC Manufacturer
Member#: 207954
I can't say anything bad about the radiator you purchased davidss, as I have no idea who made or where it possibly came from.
I can say this... our Mishimoto radiators are backed with a lifetime warranty and we even provide an accident protection plan, too! PM me if you have any questions.
Old 01-17-2010, 01:50 AM   #112
txl146
Member Sales Rating: (145)
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Mishimoto, has leaky drain plug issue been resolved? a lot of people seem to have this issue.
Old 01-18-2010, 12:13 PM   #114
Bill4458
Member Sales Rating: (3)
Member#: 186836
2006 wrx
Buy from Josh @ importimage he'll have it shipped out today
http://www.importimageracing.com/p/G...ombo-Kits.html
Bill4458 is offline   Reply With Quote
Old 02-18-2010, 03:59 PM   #115
SBW
Member Sales Rating: (18)
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
I have purchased the same radiator quoted above. I am always concerned about cooling as the 22t cas obviously less of a cooling jacket than the open/semi-closed deck engines. Im pretty psyched about it, I combined it with a cooler thermostat and some water wetter. It was cheap insurance as even though its not a three row, its got more volume than the stock setup and I got it to fit just like stock.
I trimmed the rubber stops that fit into the top radiator brackets and it sits perfectly. I even got my panel on there. I'll post pics.
SBW is offline   Reply With Quote
Old 02-21-2010, 12:47 AM   #116
nfm
Member Sales Rating: (11)
Member#: 171697
05 WRX
Post some pics. I need a replacement myself since my stock one is spraying all over and it's not pretty. I might get the same one, I would like to get Mishimoto but being a college student my budget is on the minus side and I have other problems with the car .
nfm is offline   Reply With Quote
Old 03-20-2010, 10:52 AM   #117
Whoa!ShutItDown
Member#: 191700
04 WRX
Just had a CXRacing radiator installed, no problems at all. Took about an hour from the point I pulled into the garage to when it was done, no fitment issues. The welds are surprisingly good for $120 shipped. I would defiantly recommend this radiator, I dont know how other eBay radiators are though.
Whoa!ShutItDown is offline   Reply With Quote
Old 03-20-2010, 12:52 PM   #118
ownnij
Member#: 70459
^^^ well there you go, another ebay success but it is a hit or miss thing.
Old 03-20-2010, 02:23 PM   #119
Whoa!ShutItDown
Member#: 191700
04 WRX
Yes, that is very true. I actually turned my A/C on a few minutes ago and the fan that turns on with it is making a horrible noise. Ill have to check it out more, everything else is fine though. I'm one of the lucky ones that doesn't leak...that I can see.
Now I'm wondering if an eBay turbo inlet would be worth it, too many mixed reviews to make this decision.
Old 03-20-2010, 04:30 PM   #120
Horkus
Member#: 112667
2002 WRX wagon
Default still going strong CXracing rad
After the 1st winter, Radiator still going strong and no leaks no issues.
Originally Posted by Horkus View Post
So I've finally have a pissing stock radiator I want to get rid off. So called around locally for some replacement Rads. All I found out was plastic rads including Genuine factory Subaru Rads are all over priced.
They were priced from $300-600 only plastic ones.
So Went to Ebay checked this out and found an All aluminum RAd for $180 shipped. So I went for it and within 5 days I received it.
Below are what I've done:
Open box time.
Replacing the Thermostat was a may as well thing. Trust me it's worth doing it at this time a lot more access.
you need to trim the ends approx 1/4" each end as this rad is 1/2" thicker than stock.
Horkus is offline   Reply With Quote
Old 03-20-2010, 05:13 PM   #121
0260B4U
Member#: 33249
2003 WRX
white
Question
So Ive been running my Godspeed 2 row form Ebay and so far so good, but even with the 2 row and water wetter I dont noticed the stock tempature gauge and lower than normal, or if it is, just a fraction of where it was. Is that normal? I was expecting a noticeable different.
Old 03-20-2010, 06:36 PM   #122
ownnij
Member#: 70459
with the inlet thing, i don't think it'll be any issues with the ebay versions but the gimmick one doesn't cost that much more. might as well get something that has been proven.
Old 03-20-2010, 07:32 PM   #123
69subaru360
Member Sales Rating: (69)
Member#: 159682
1995 WRX
2015 F150
The ebay inlets suck closed. It's not a myth. I tried one and it sucked closed the first time I went wot. You might get away with it on a stock td04 at low boost, but any kind of real turbo at higher boost will suck it closed.
I have no problem with ebay parts when they work. The inlets don't.
Old 03-21-2010, 06:51 PM   #124
dingobite
Member Sales Rating: (28)
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
Try American Radiator if you want the plastic koyo piece on the first page i paid about $250 shipped its the koyo oem replacement radiator shown on first page #2704. They also do ebay youll have to call them regardless to confirm no one is effin up the order.
I put 30,000 miles on it 2 winters.
American Radiator
PASCO, WA
800-826-6649
AR
SUNNYSIDE, WA
888-837-6403
WorldOne is selling the koyo radiator #2704 after google just now.
- Very good one here.
dingobite is offline   Reply With Quote
Old 03-22-2010, 05:41 PM   #125
Whoa!ShutItDown
Member#: 191700
04 WRX
I guess I'll go with the GMS inlet, especially since Im going to skip getting a tune on my td04 and go right for a new Blouch EvoIII 16g.
Aluminum Radiator from EBAY green rims Car Part Reviews 3 12-10-2008 04:11 PM
Ebay all aluminum radiator? Chi_San General Community 18 08-30-2008 05:56 PM
Ebay Aluminum Radiator $140 shipped sexycat Engine/Power/Exhaust 2 08-02-2008 07:48 PM
anyone on ebay all aluminum radiators? scobaru Pre-2002 Factory Turbo Powertrain 5 06-28-2008 11:13 PM
ebay aluminum radiators lightning1458 North West Impreza Club Forum -- NWIC 15 03-06-2008 01:27 AM
