Old 03-29-2011, 07:05 PM   #151
Nick Boxler
Member Sales Rating: (3)
Member#: 180326
2005 WRX
HTA68'ed San Remo Red
Originally Posted by Kavik View Post
that's a little cumbersome Nick (overall length, with that handle: 4.42"). If you put that on with an elbo to make it point away from the front of the car, you'd be hitting the engine before the valve closes lol
Good call, I didn't notice that it was that long haha. I like your solution more.
Nick Boxler is offline   Reply With Quote
Old 03-30-2011, 04:01 PM   #152
Kavik
Member Sales Rating: (29)
Member#: 112278
2003 Sonic wrx wagon
2005 blue "wrx" Wagon
I just went to home depot last night, for under $10 I got a ball valve with 1 male end and one female end and a 2 pack of hose barbs with threaded male end to connect to the valve female end (there weren't any single packs)
found them both in the air tools section...
Same basic idea of the parts I linked to above, roughly the same size, and didn't have to wait on shipping
Kavik is offline   Reply With Quote
Old 10-23-2011, 10:05 PM   #153
ScoobDud
Member Sales Rating: (16)
Member#: 198472
Bumping an old thread.
I was wondering for those that are running aftermarket aluminum radiators which ones have allowed you to run the stock fan setup since I don't want to pay the extra amount to run aftermarket fans. Any input would be appreciated.
ScoobDud is offline   Reply With Quote
Old 11-19-2011, 01:42 PM   #154
brew02wrx
Member Sales Rating: (13)
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
i just wanted to chime in to mention that over the summer my radiator popped on me going to work, i ordered a new radiator off ebay (all aluminum, 2 row, i dont remember the brand) it showed up very good quality, perfect fitment, i reused the old hardware to remount the fans, it's been 5 or so months now since i installed it and there have been zero hiccups, my car runs nice and cool at all times, for a little under 200 bucks it's definately worth it
brew02wrx is offline   Reply With Quote
Old 12-03-2011, 11:26 PM   #155
nightestkiduknow
Member Sales Rating: (1)
Member#: 274576
2002 impreza wagon
My tidbit of info, so plastic failed on the stocker,jb weld failed! (used it just to get by tell radiator arrived)
Ok so i orderd the speedy racer radiator from ebay(cxracing knock off all the same specs) it came and looked great! welds were even looked like all mounting points were good but when it came to instillation that was a different story
When i put her in the fans didn't quite match the mounts not a biggie was thinkin of swapping for some slim ones.
saw there was an extra nipple at the end (probably for turbo model) decided to put clear hose on it and cap it off. great way to see coolant levels. also shaved down top hose to clear belts
when i filled her had a small leak out of the cheap plastic petcock when i went to turn it, it snapped!
Pulled everything back out took a bolt and Teflon tape and re did that cheap mess
Got everything back together and she is runin great a lot cooler ive only had it for a short time but so far so good i will post up if fails but for under 90 bucks not bad so far!
please don't mind the pics very bad camera lol
nightestkiduknow is offline   Reply With Quote
Old 01-06-2012, 02:59 PM   #156
sohchx
Member#: 213634
2002 Impreza
So I've been pondering on the CXracing piece from Turboworks on Ebay and after looking at some of you guys pics here and especially the auction it looks like the radiator is a bit taller from top to bottom than the stock unit and as a result is causing the two mounting supports at the top to bend up or not sit flush at the top of the core support. It looks really bad on the car in the auction pics. WHat's that about?
http://www.ebay.com/itm/CXRacing-Alu...item1e6976cfa0
sohchx is offline   Reply With Quote
Old 01-06-2012, 03:32 PM   #157
sorrowfulkiller
Member Sales Rating: (7)
Member#: 170439
I <3 Lamp
It's not generally an issue
sorrowfulkiller is offline   Reply With Quote
Old 01-09-2012, 01:42 AM   #158
jason11
Member#: 306317
very nice, convinced me to buy
jason11 is offline   Reply With Quote
Old 01-10-2012, 03:32 PM   #159
FCmaniac
Member Sales Rating: (69)
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
I have this radiator and it fits perfect. I'm not sure what is up in that picture.
FCmaniac is offline   Reply With Quote
Old 02-04-2012, 10:55 PM   #160
mystilexzero
Member Sales Rating: (15)
Member#: 154674
2007 wrx
ugm
does anyone run ebay radiator fans with success?
mystilexzero is offline   Reply With Quote
Old 02-04-2012, 11:38 PM   #161
Unabomber
👌 Big Ron 👌
Member Sales Rating: (11)
Member#: 18062
on car parts so PM
me b4 j00 buy
The only fans smart people run are OEM. If you run ANYTHING else, even if Jesus makes them, you are a moron as the all suck.
Old 02-05-2012, 12:13 AM   #162
ardevas09
Member Sales Rating: (21)
Member#: 164710
05 440whp STi
2014 Evo X
now, are you talking about my cousin Jesus or the deity? I feel as though the latter may produce a better cooling fan, that's all.
ardevas09 is offline   Reply With Quote
Old 02-05-2012, 07:34 AM   #163
FCmaniac
Member#: 142029
2013 Forester
The OEM fans bolt right up and they are more than adequate... seriously.
Old 02-05-2012, 04:10 PM   #164
mystilexzero
Member#: 154674
2007 wrx
ugm
only reason I'm asking is because i need to run the slim fans because of the custom turbo set-up i have that mounts to the fog light, the fans touch the header even with most of the bottom shroud removed. the stock fans are 14'' i need to run 12'' fans.
back to subject has anyone seen or have run these fans with success?
Old 07-26-2012, 02:26 PM   #165
Mr.Sparkle
Member Sales Rating: (2)
Member#: 83725
2015 WRX
Two years ago my stock radiator cracked on my 03 WRX. The car had 150K so it wasn't surprising. I started shopping around and went with a CXRacing based on reviews here. It fit fine and worked well until a few months ago. I noticed small spots of coolant under my car which eventually git bigger. I spot checked the radiator but couldn't tell where it was leaking. The hoses were fine and the plug wasn't leaking. It got really bad so I shopped around again.
I went with a Mishimoto I found on Amazon for $240 shipped. When I pulled the old one I filled it with water and saw it was leaking from the bottom so I figure the core had gone bad. Just a heads up but I figure I got a bad one as others have been happy with theirs.
Mr.Sparkle is offline   Reply With Quote
Old 07-26-2012, 06:03 PM   #166
SatinWhitePearl
Member Sales Rating: (10)
Member#: 170780
2007 STi
Satin White Pearl
.... I wasn't even aware that radiators were "knocked-off."
Either way, enjoy them!
SatinWhitePearl is offline   Reply With Quote
Old 10-05-2012, 02:56 PM   #167
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
Hello:
Unfortunately we do not provide warranty on any of our products, we only have a 15 day return or exchange after receipt of product, provided it is unused and in good condition.
CXRacing
tebriel is offline   Reply With Quote
Old 10-05-2012, 03:44 PM   #168
SatinWhitePearl
Member#: 170780
2007 STi
Satin White Pearl
This community will never grasp the concept of quality over quantity; its always how many "mods" can I get for as little as possible, great mentality.
Old 10-05-2012, 03:51 PM   #169
Surf WRaX
Member#: 4550
2002 WRX Wagon #4321
CXRacing/
Holy sh$%, CXRacing has an account here on Nasioc? Worst customer service ever when I ordered my AL radiator from them several years ago. Had to go to Paypal claims to get my money back when CSR went MIA.
Surf WRaX is offline   Reply With Quote
Old 10-05-2012, 11:10 PM   #170
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
Satin I don't think that most are like that, but some things are overpriced - like paying 450 or 650 for a radiator.
I went with a Sonic Motors radiator, which comes with a limited lifetime warranty.
Surf, that was the email I got from CXR - no idea if they have an account here.
Old 09-24-2013, 01:26 PM   #171
palmerx141
Member Sales Rating: (17)
Member#: 58312
WRB Bugeye SQC 217
272whp/283wtq
About to pull the trigger on either the CXR.
Tebriel, how are you liking your Sonic Motors unit? Fit well?
palmerx141 is offline   Reply With Quote
Old 12-20-2013, 12:12 PM   #172
hella_sti
Member#: 139289
2003 WRX Wagon
I've been getting a slight coolant smell on the colder days and looked today and there was a small spot of coolant on my skid plate on the passenger side, small leak/seep but nothing dramatic. I'll probably wait until it gets worse and replace the radiator in the spring, until then the cx racing units are a waste of money in my eyes, only lasted 2 years and maybe 30-35k in my daily driver. Save your cash and buy a quality unit or oem.
hella_sti is offline   Reply With Quote
Old 12-20-2013, 01:49 PM   #173
FCmaniac
Member#: 142029
2013 Forester
It's probably just the drain petcock. They sometimes leak. You could just remove it and put it back in with some teflon tape and it should be fine.
Aluminum Radiator from EBAY green rims Car Part Reviews 3 12-10-2008 04:11 PM
Ebay all aluminum radiator? Chi_San General Community 18 08-30-2008 05:56 PM
Ebay Aluminum Radiator $140 shipped sexycat Engine/Power/Exhaust 2 08-02-2008 07:48 PM
anyone on ebay all aluminum radiators? scobaru Pre-2002 Factory Turbo Powertrain 5 06-28-2008 11:13 PM
ebay aluminum radiators lightning1458 North West Impreza Club Forum -- NWIC 15 03-06-2008 01:27 AM
