Old 01-07-2007, 10:12 PM   #1
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Default Logging boost
I have seen in several people's logs that they are logging boost values 19 psi and above. How is that accomplished? I am running about 19 psi now but my logs only show a max of 18.47.
blkscooby is offline   Reply With Quote
Old 01-07-2007, 11:50 PM   #2
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
I got the same problem, my max is 16.87.
04 WRX 18g'd
gaby is offline   Reply With Quote
Old 01-08-2007, 02:13 AM   #3
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
pulled from EcuTEK
"When people discuss boost pressures, they are generally referring to manifold relative pressure. For vehicles running high boost, it is better to view manifold absolute pressure due to the way in which the data is reported: The manifold relative pressure parameter can only report pressures up to around 19 PSI. Beyond this pressure, the ECU will just report 19 PSI. To get around this limitation, read manifold absolute pressure instead. This parameter will read up to approx 37PSI. Subtracting 14.5 PSI for atmospheric pressure shows that this parameter can convey boost pressures of up to approx. 22 PSI.
As an example... If a car is said to be running 16 PSI of boost, this would be a 'manifold relative pressure' of 16 PSI, or a 'manifold absolute pressure' of 16 + 14.5 = 30.7 PSI. That's 16 PSI relative to the atmosphere, or 30.7 PSI relative to a complete vacuum. "
that's a different route i guess. But i assume it works. Hope that helps and i hope you find your real answer.
druxboyz is offline   Reply With Quote
Old 01-08-2007, 02:48 AM   #4
qoncept
Member#: 44762
2013 BRZ
Wow, that's kind of a silly thing for ecutek to say. If you want it to be accurate, log both manifold absolute pressure and atmospheric pressure, and subtract that instead. Or if you're using ecuExplorer or Enginuity, you can have the logger do the subtraction for you.
qoncept is offline   Reply With Quote
Old 01-08-2007, 08:06 AM   #5
blkscooby
Member#: 44422
2009 G8 GT
I got it. Log Manifold Relative Pressure Corrected in ecuExplorer and that will that the manifold absolute pressure and subtract the atmospheric pressure to get true boost.
Now I have logged a boost of 20.46 psi.
Old 01-08-2007, 10:26 AM   #6
gaby
Member#: 94097
[email protected]
Ok I'll try that today.
Logging Boost??? Zackbo Open Source Reflashes 4 02-10-2009 01:15 PM
Log, boost issues..... rallytim888 AccessPort 8 07-26-2006 10:11 PM
So how do I log Boost??? Nixlimited Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-11-2006 07:14 PM
Can't log boost in StreetTuner shemoves Engine Management & Tuning 4 10-28-2005 12:31 AM
My log, stage 2 + uppipe, closed loop boost. overdose Engine Management & Tuning 14 11-30-2003 10:25 AM
