Old 01-08-2007, 01:09 PM   #1
rexspeedmaster
Member#: 123103
2003 WRX
Full 07 STI trans
Default Bucking at any speed any gear ??misfire??Whats wrong
Ok Here is the thing. I posted a while ago that I had an idle problem and also bucking. I cleaned the IACV because of some advice I recieved. That helped the idle problem alot. Now I still have the bucking problem. I drove the car around for 2.5 miles and it was fine. I hit some boost up to about 10psi and no leaks or bad sounds or anything ran perfectly. Then a little way (.25 mile) down the road while i was in vacum i had one buck, felt like a fuel cut. I immediately turned around and headed home. It still bucked every one in a while even though I was hardly on the accelerater and always in vacum. What is wrong? Any ideas?
rexspeedmaster is offline   Reply With Quote
Misfire? whats wrong? PelvaanAli Newbies & FAQs 30 10-01-2008 02:15 AM
Bucking at any speed any gear Misfire??? rexspeedmaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-08-2007 01:03 PM
UTEC question...bucking at around 5k RPM in upper gears. Neek Engine Management & Tuning 3 03-10-2005 04:22 PM
Squeek/Squeel at low speed - Any ideas? Joe Longworth Service & Maintenance 3 08-07-2002 12:38 AM
Whats wrong with my 5th gear? Vitamin-K General Forum Archive 1 11-06-2000 11:10 PM
