Old 01-08-2007, 01:28 PM   #1
JPinn
Member#: 80925
2004 WRX Stage 2
WR Blue
Post Ventilation system makes ticking noise
When I turn my ventilation system on I hear a ticking noise coming from near the passenger side. It is not directly coming from any of the vents as I can find. Also, this happens with the AC on or off and on any setting. The car is an 04wrx sedan. I tried to take it to a dealer to have them look at it and It seems to be fairly intermittent as to how loud the ticking gets. The dealer didn't seem to thing anything was wrong. This is a very anoying problem so if anyone has any input it would be greatly apreciated.
JPinn is offline   Reply With Quote
Old 01-08-2007, 01:35 PM   #2
kaspur_eh
Member#: 80569
1996 OBS
Now... I don't want to alarm you, but there is a bomb in your ventilation system. Hopefully you still have warranty.
Is it coming from somewhere in the vents (or behind dash?), or engine?
kaspur_eh is offline   Reply With Quote
Old 01-08-2007, 01:50 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...something stuck in the fan
Old 01-08-2007, 02:04 PM   #4
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Either something stuck in the fan, or there's a little electronic gizmo (i'm not exactly sure what it is, except that it regulates fan speed) behind the glovebox on most subies that tends to burn out leaving you with a smaller option of fan speeds...maybe it is ticking? It did this to me before it burned out.
I just took it out, resoldered it and stuck it back in...works like a charm.
Wiscon_Mark is offline   Reply With Quote
Old 01-08-2007, 02:49 PM   #5
rkramer
Member#: 118209
2015 WRX Limitec
leaves (or pieces of them) sucked into the intake is my guess... drop the blower out and clean it out.
Old 01-08-2007, 09:02 PM   #6
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
Turn fan on high, turn off and repeat. Did the problem go away?
Happens to mine from time to time...that usually resolves it. I'm guessing small leaf against vent circulating fan blade.
skimobile is offline   Reply With Quote
Old 01-08-2007, 09:12 PM   #7
bWRX
Member#: 6672
^^^^+1
bWRX is offline   Reply With Quote
Old 01-08-2007, 09:38 PM   #8
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
I had a bunch of leaves in there too...
moogoob is offline   Reply With Quote
Old 01-09-2007, 11:29 AM   #9
JPinn
Member#: 80925
2004 WRX Stage 2
WR Blue
The problem is intermittent, it will come and go. Turning the fan on high does not always help. Is there a post somewhere of how to remove the blower and clean that out. Sounds like stuff stuck in there could be my problem.
Old 01-09-2007, 02:36 PM   #10
riverwrx
Member#: 61253
2003 wrx wagon
I had a similar problem. My issue was the condensation line was kinked. The condensation would fill the air box and drip on the fan. Occationally it would leak to the floor. I just unkinked the line and all was fixed.
riverwrx is offline   Reply With Quote
HELP.. system making whinning noises 02bugeyeWRX Car Audio, Video & Security 13 01-24-2009 05:04 PM
AVCR selenoid valve making loud ticking noise (problem or not) WRX-Blue-Mica Engine Management & Tuning 10 07-17-2005 06:18 PM
my engein is making really loud ticking noise!! sjtangb21 Normally Aspirated Powertrain 28 04-06-2005 10:19 PM
