Old 01-08-2007, 07:30 PM   #1
NcKidd
Member#: 133267
2004 psm WRX
Subaru Stars SS Brake Line Install Help
searched for brake line installation help w/o much luck...
anyone have a link to a good install thread?
thanks a bunch
NcKidd is offline   Reply With Quote
Old 01-08-2007, 08:42 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
sure.
Step 1. Unbolt brake lines
Step 2. Bolt up new brake lines
Step 3. Bleed brakes
Shane
PARANOID56 is offline   Reply With Quote
Old 01-08-2007, 09:17 PM   #3
Titanium
Member#: 10749
2006 WRX Wagon SGM
2006 BMW E85 3.0si
Titanium is offline   Reply With Quote
Old 01-08-2007, 09:20 PM   #4
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Or if you're not quite paying attention.....
Originally Posted by PARANOID56 View Post
sure.
Step 1. Attempt to unbolt brake lines without line wrench and strip the nut.
Step 1a. Re-attempt to unbolt lines from hardline w/ channel locks or vise grips and further strip the nut followed by twisting and kinking the hard line because you didn't support the body bracket.
Steb 1b. Go to dealer and get hardline and line wrench - pay a lot and re attempt installation - this time semi successfully
Step 1c Overtighten banjo bolt and strip threads in caliper
Step 1d Get caliper re-threaded and purchase fittings to fit new size.
Step 3. Bleed brakes but forget to keep master cylinder filled and suck air into master cylainder
Step 3a. Get long hose to attach from caliper to MC to bleed MC while on steep incline
Step 4 Get more fluid
Step 5 Post on Nasioc that you did SS lines in 45 minutes and the new found pedal feel has you outbraking Porsche Cup Cars.
Shane
There are a few subtle hints in there
KNS Brakes is offline   Reply With Quote
Old 01-08-2007, 09:25 PM   #5
STi-MAN
Member#: 70252
05 STI
blue
Use a high quality flare wrench (eg. snap on, craftmans) i first used a crappier brand and nearly striped on hard line flare nut.
STi-MAN is offline   Reply With Quote
Old 01-08-2007, 10:51 PM   #6
TCE
Member#: 100868
So sad but often true. Rush it and you shall pay...
TCE is offline   Reply With Quote
Old 01-09-2007, 02:37 PM   #7
NcKidd
Member#: 133267
2004 psm WRX
Lightbulb
these little "hints" were what i was lookin for.....
its nice to know about special tools in advance i guess. What would be the size of the flare wrench i will need (is it fixed or adjust.)?
thanks again
would i ever use the line wrench again if i never had to change out brake lines again?
how much is it ballpark?
Old 01-09-2007, 03:25 PM   #8
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
They usually come w/ 2 sizes - one on each end....u need a 12 iirc
they can be handy at times - only about 10-15 bucks depending on what you get
Drive over here to cary and borrow mine
infantsam is offline   Reply With Quote
Old 01-09-2007, 05:41 PM   #9
STi-MAN
Member#: 70252
05 STI
blue
you need a 10mm for the flare nut on the hard line. you can use a regular wrench for the caliper banjo, which is a 12mm.
Old 01-09-2007, 06:38 PM   #10
badtaste
Member#: 116636
2003 impreza
black
ive heard issues with the abs after doing this, any one got somthin on that? im putting mine of saturday once we get the shop caught up on work
badtaste is offline   Reply With Quote
Old 01-09-2007, 11:35 PM   #11
DZnutz
Member#: 91837
you have to pay very close attention to the condition of the brake line nut... both my front ones were already a little rounded from the factory. using a wrench would have rounded them right off... instead use a vise-grip, clamp the nut tightly and "snap" the nut counter-clockwise... breaks it loose quite nicely. everything else is easy as pie
DZnutz is offline   Reply With Quote
Old 01-10-2007, 12:03 AM   #12
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
use the flare wrenches and make sure you have a torque wrench for the banjo nuts. these will break very easy
try this it tells it all
http://www.scoobymods.com/forums/showthread.php?t=2731
dstan is offline   Reply With Quote
Old 01-10-2007, 02:58 AM   #13
grippgoat
Member#: 62182
2005 STI
I use my flare wrenches quite a bit. I didn't do my own brake lines (I have brake fluid), but I try to use them anywhere I have room to get it on the nut.
-Mike
grippgoat is offline   Reply With Quote
Old 01-11-2007, 12:27 AM   #14
NcKidd
Member#: 133267
2004 psm WRX
Subaru Stars
thanks for all the good info-
this will be my 1st mod (other than my k&n)- plan to spend the weekend babying my ride:
installing ss brake lines
flush, bleed, new motul fluid
kartboy ss w/ bushings
mequires 2 step wax
tint
this is all I can afford at the moment, tax check = more madness
Old 01-11-2007, 01:03 AM   #15
dstan
Member#: 120386
well Brakes are the first thing you should do
Tires are Very important too! Brakes are no good if tires
suck.
Old 01-11-2007, 07:13 PM   #16
NcKidd
Member#: 133267
2004 psm WRX
Subaru Stars
i look to have 1-2 more months on my stockers, i'm gonna shred em up on March 2, my 1st track day ever.
After that = tax check = rotas, kumhos, and sti pinks
Old 10-20-2007, 10:20 PM   #17
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Can you elaborate on this?
Are you saying to keep the brake line in the bracket with the clip on and then put the vice grip on the brake line collar that's in the bracket? Then use the 10mm box wrench to loosen?
I'm afraid to use the 10mm to do anything but hold that nut in place because I'll twist the hard line. I do NOT want to break/bend the hard line.
But... there's no good way to hold the break line collar!
chimchimm5 is offline   Reply With Quote
Need Help ASAP - SS Brake Line Install / WTF TixArmy South West Impreza Club Forum -- SWIC 8 03-16-2010 11:32 AM
car in air/SS brake line install ? help? jkyes Brakes, Steering & Suspension 8 08-24-2003 07:48 PM
Need SS Brake Lines Installed Ryan24 North West Impreza Club Forum -- NWIC 4 08-16-2001 11:10 AM
SS brake line installation.... Penphoe Brakes, Steering & Suspension 3 07-21-2001 01:23 PM
Anyone with SS Brake Lines Install Experience? BigElm Tri-State Area Forum 7 03-12-2001 05:22 PM
