Old 11-24-2001, 12:27 PM   #1
samuraiRS
Member#: 7723
2000 2.5 RS
Silverthorn
Default CEL problems help (searched already)
Here's the situation, i had a constant CEL for a day, then it went away. It's been about a week and now I have a constatnly blinking CEL as soon as I start the car. The engine feels like it is idleing roughly, but the rpm gauge looks pretty normal. My friend has a 97 GT and was able to pull codes off his car by plugging in 2 harnesses. I looked under the dash but didn't see anything like that there. I did a search and I "think" the only way to pull the codes is to use a scan tool. Am I right? I had the Cobb CAI on for about 5 months now and it never had this problem. The stock intake is back on but I am still getting the blinking. I did hit a deer a while back but i don't really "see" anything out of the ordinary under the car. Just wondering if anybody has any insight on this. Thanks.
BTW, i had called the dealer about the possibilty of there being a recall on my O2 sensor, but when they checked the VIN to my car, they said there was no recall for my O2 sensor.
Andy
samuraiRS is offline   Reply With Quote
Old 11-24-2001, 02:35 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
the only way to pull the codes is with an OBD-II scanner, and it sounds like you have a misfire code stored. I reccomend taking it to the dealer.
Jeremy
Old 11-24-2001, 03:55 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
STOP DRIVING!!!!!!
when the check engine light blinks, it usually means a misfire with lack of spark, wich means you are dumping raw fuel into the cats....catalytic converter failur is imenent, thats why the light flashes! so you know to stop driving, says it in the owners manual.
if the car is still under warranty have it towed to the dealer.
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
9 more days till subaru weeeeee
Old 11-24-2001, 06:05 PM   #4
samuraiRS
Member#: 7723
2000 2.5 RS
Silverthorn
I started the car, noticed the blinking lights and never moved. I remeber reading that a blinking light was bad but i couldn't remeber if that was for the wrx's only or not. The service center doesn't open till monday so i won't be able to bring it in thill then. I started the car a few times and it never seemed stable enought to drive. I'll have it towed in on monday. Just wondering if that deer was the cause of this or something else...
Old 11-25-2001, 04:35 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
well on a SFI system if the hole is dead it will typicall shut the injector down purposely to prevent the cats from overheating and melting down. these are MPI systems.
jeremy
Old 11-26-2001, 03:25 AM   #6
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
Did this happen all of a sudden?
Or were you messing with wiring under the dash?
My buddy saw two green connectors one day when we were installing some gauges and connected them... blinking CEL.
He thought he had unplugged them when he installed the alarm and forgot to reconnect.... nope.
ImprezaRSX is offline   Reply With Quote
Old 11-26-2001, 07:01 AM   #7
foolio
Member#: 9351
2006 trailblazer SS
black
take it to a dealer. blinking light = not good
J
foolio is offline   Reply With Quote
Old 11-26-2001, 07:42 AM   #8
samuraiRS
Member#: 7723
2000 2.5 RS
Silverthorn
Didn't mess with anything under the dash. I will be taking it to the dealer today. It should be safe to drive it there, the dealer is less than 2 miles from my house. That shoud'nt be a problem should it?
Old 11-26-2001, 08:05 AM   #9
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
IF THE LIGHT IS BLINKING, DONT DRIVE IT. HAVE IT TOWED.
--Roy
LUME is offline   Reply With Quote
Old 11-26-2001, 11:37 AM   #10
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
A few weeks after I bought my car I had a blinking check engine light. Came on when I shifted into 4th gear. It blinked 4 or 5 times and turned off. Never came back on. Had the code pulled and it had no stored codes. If it is constantly blinking and not running correctly I would have it towed. See if your insurance has towing coverage.
Drac9 is offline   Reply With Quote
Old 11-27-2001, 04:14 AM   #11
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
did you change or mess with the plugs?
HOK is offline   Reply With Quote
Old 11-27-2001, 07:20 AM   #12
samuraiRS
Member#: 7723
2000 2.5 RS
Silverthorn
The car has been towed to the dealer. I still had the roadside assistance that subaru provides so i used it...
The 2nd to last time i started the car, there was sparking from one of the plugs. IT was not doing that before. I cleaned off the plug and the connection and made sure it was tghtly plugged in. No more blinking CEL but it is still on. They haven't had a chance to look at it yet but will do it today. I'll let you know what is going on.
Old 12-04-2001, 06:19 AM   #13
samuraiRS
Member#: 7723
2000 2.5 RS
Silverthorn
Default follow up
Turns out, O2 sensor was bad. Distributor coils and 2 spark plug cables were fried. All taken care of under warrenty...
Phew...
Old 12-04-2001, 03:38 PM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Thumbs up
glad to hear it
jeremy
Old 02-15-2010, 09:11 PM   #15
skifree09
Member#: 238492
I've been having similar problems. Engine was misfiring and I believe the CEL was flashing so I drove it the remaining 3 blocks to the dealer. I think that may have screwed up my catalytic converter, but I'm not sure of the initial problem causing misfire- don't want it to return.
skifree09 is offline   Reply With Quote
Flashing CEL problem.. help! LuckyStar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 06-18-2010 07:37 PM
Perrin EBCS CEL problems, help? IIdiceII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-02-2008 06:33 PM
Idling problems and wierd Cel problem.. Help please SPOOLME Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-26-2008 02:07 PM
CEL Problems........... HELP!! brokemypiston Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-02-2006 10:39 PM
J&S Q's (tried the search already) IMPBOY Normally Aspirated Powertrain 4 01-02-2001 09:40 PM
