Welcome to the North American Subaru Impreza Owners Club Saturday December 27, 2014
Old 12-22-2009, 04:25 PM   #1
OLD MANS 04-RS
Member#: 220700
2004 RS
Java Black Pearl
Default Any Benefit To Catless Without Engine Management?
Simple question, if someone only replaces the cat with a trackpipe, will you help or hurt performance without engine management. This on a N/A .
OLD MANS 04-RS is offline   Reply With Quote
Old 12-22-2009, 04:33 PM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
motec system exhaust-RIP
It won't make much of a difference either way. Headers will make your biggest difference in the exhaust, everything else stock at least.
chazly413 is offline   Reply With Quote
Old 12-22-2009, 04:38 PM   #3
OLD MANS 04-RS
Member#: 220700
2004 RS
Java Black Pearl
I have heard headers do nothing more on our cars than make them sound nice.
Old 12-22-2009, 04:45 PM   #4
chazly413
Member#: 151079
2005 2.5RS RBP
That's if you get unequal length. If you get equal length headers, you will get a bit of an increase in power over pretty much the entire powerband.
Old 12-22-2009, 04:46 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
This isn't true. I got 12whp on the dyno with headers. I got 1 more whp with a track pipe. It was noisy as hell. I took it off the next day and reinstalled my high flow cat.
Old 12-22-2009, 04:50 PM   #6
OLD MANS 04-RS
Member#: 220700
2004 RS
Java Black Pearl
What kind of headers? Is this the Matt Monson who used to live in Harvard Illinois?
Old 12-22-2009, 05:00 PM   #7
OLD MANS 04-RS
Member#: 220700
2004 RS
Java Black Pearl
Anyone on this? Most I have ever seen is 3-4 HP with headers.
Old 12-22-2009, 05:10 PM   #8
OLD MANS 04-RS
Member#: 220700
2004 RS
Java Black Pearl
At BOXER4RACING, they are saying dynos show a consistant 10-12 hp with a trackpipe.
Old 12-22-2009, 07:31 PM   #9
GrundleJuice
Member#: 165749
2007 No YELLING
on the bus!
what year N/A? the header being replaced will make a difference since they changed to a better, EL-like design in 06.
an old high mileage cat with lots of build up and small ID on the inlet and outlet would most certainly benefit somewhat, but a newer design, like the 06+ cats that are integrated into the exhaust manifold cant be replaced without doing headers or some custom stuff, and gains will be small anyway.
GrundleJuice is online now   Reply With Quote
Old 01-29-2010, 05:50 AM   #10
shaggy2.5TS
Member#: 222553
2002 2.5TS
I was thinking about doing a full exhaust on my '02 TS with a track pipe. Also wondering about any performance gains. Does anybody have a sound clip with a track pipe?
shaggy2.5TS is offline   Reply With Quote
Old 01-29-2010, 02:08 PM   #11
RaceCarRiot
Member#: 6542
1997 Ver IV
wrong thread...
RaceCarRiot is offline   Reply With Quote
Old 02-13-2010, 02:28 AM   #12
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
your a loser for polluting our air with your catless set up. get a high quality high flow cat bro.
watchunglava is offline   Reply With Quote
Old 02-13-2010, 03:09 AM   #13
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
u didn't answer his question.
Jerry Xu is offline   Reply With Quote
Old 02-13-2010, 05:54 AM   #14
silverbug-i
Member#: 219680
1997 IOBS
White/gold
correct me if im wrong but on turbo'd cars you will feel a difference going catless, but on n/a cars you need a cat(s) for that needed backpressure.
silverbug-i is offline   Reply With Quote
Old 02-13-2010, 02:45 PM   #15
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Oh for Frack's sake...
NA CARS DO NOT NEED BACKPRESSURE! BACKPRESSURE IS ALWAYS A BAD THING!
Old 02-13-2010, 03:19 PM   #16
bandit_2017
Member#: 131188
05 2.5 rst
so your 5 inch exhaust makes your n/a car run like a top
bandit_2017 is offline   Reply With Quote
Old 02-13-2010, 03:59 PM   #17
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No, because the 5" exhaust would allow the exhaust velocity to drop. Backpressure is nothing but parasitic loss. Exhaust gas velocity is everything.
It amazes me that there are still people too stupid to have learned that.
Old 02-13-2010, 05:02 PM   #18
silverbug-i
Member#: 219680
1997 IOBS
White/gold
thanks douche for being the cool guy, i wasnt to sure thats why i said "CORRECT ME IF IM WRONG".
Old 02-13-2010, 05:53 PM   #19
bandit_2017
Member#: 131188
05 2.5 rst
so what you are saying is a 4 stroke engine does not need any back pressure. but wouldnt a smaller exhaust make more exhaust velocity and make more power too
Old 02-13-2010, 06:19 PM   #20
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Maybe. There's too many variables to make a simple statement like that. Yes, narrower piping should increase exhaust gas velocity. However, it's often hard to increase velocity without something undesirable (like backpressure) coming along for the ride. There's also a point at which the diameter of the piping itself becomes a restriction. Then there's the fact that the engine makes different volumes of exhaust gas at different throttle opening angles and different engine speeds. A tubing diameter that's correct for one engine speed and throttle opening will be incorrect for another. This is where the need to size your exhaust to your desired power band and engine output comes from.
So it's not that simple. The only real rule is that backpressure is always bad bad and correct exhaust gas velocity is always right. It's just that achieving those two goals at the same time gets really complicated.
Old 02-15-2010, 12:03 PM   #21
Skidd
Member#: 1853
GC6 Supercharged
STM
Ahhh.... my favorite automotive urban-myth.... Backpressure!!
http://forums.nasioc.com/forums/show...p?t=1630548#22
http://www.rs25.com/forums/f5/t37483...kpressure.html
My quest to rid the world of this myth continues!!
Skidd is offline   Reply With Quote
Old 02-15-2010, 12:41 PM   #22
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
It annoys me every time someone comes up with the backpressure myth, and then defends it by using extremes such as 5" pipe, or super narrow piping.
Backpressure is basically "clogging the pipes"
Try welding a metal plate to the exhaust manifold and then drill a pinhole.
All backpressure, no exhaust scavenging. I don't think you'll get much power.
In a super perfect hyper technologically advanced world, we would all have exhaust systems that would change diameters as the RPMs change.
The optimal diameter for a given engine is dependent on how much exhaust gas/flow is coming out of the engine. At lower RPMs, it is beneficial to have a narrow exhaust because with the low amount of exhaust gases out, a smaller diameter exhaust would be able to provide sufficient flow while being narrow enough to provide an exhaust scavenging effect. To large and this vacuum pulling effect is lost, decreasing flow. Of course, this would quickly change near redline where the higher volume of gases would not be able to pass through this narrow piping quickly enough, thus creating what we called backpressure preventing flow. A larger diameter will then reduce backpressure and restore the exhaust scavenging effect.
We don't have such magical exhausts, so the only thing we can do is have a diameter that will act as a compromise of sorts. Many here are running 2.25" piping past the headers which pretty much allows for the maximum CFM of our engines.
formula91 is offline   Reply With Quote
Old 02-15-2010, 02:36 PM   #23
Jerry Xu
Member#: 36629
07 2.5i
Originally Posted by formula91 View Post
To large and this vacuum pulling effect is lost...
Sorry, I never understood that vacuum thing. If you put a pressure gauge on one of the primaries, will you ever measure pressure lower than outside? Lets say if you drive a car that doesn't even have headers installed, granted it would be laud as hell, will it be slower because the lack of this "vacuum?"
Old 02-15-2010, 02:42 PM   #24
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yes, you'll measure near perfect vacuums followed by significant overpressures. However, that's not the effect really being discussed here. There's resonant scavenging and velocity scavenging. In resonant scavenging, the length of the pipes matters. The idea is that the near perfect vacuum "echo" of another cylinder firing arrives at the exhaust valve just as the valve opens, giving the cylinder a vacuum to dump into. Velocity scavenging is the idea that, once you get the exhaust gasses moving, they'd rather not stop. So you let the rush out of the cylinder and the momentum of the majority of the gasses keeps them moving as the cylinder empties eventually resulting in a partial vacuum that helps "suck" the last bit of exhaust gasses out of the cylinder. This effect is dependent on getting the correct velocity (both too high and too low are bad) so the diameter of the pipe matters.
Old 02-15-2010, 02:47 PM   #25
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I'm not sure if we could ever truly test your question, but I do believe that at least in the header, the exhaust isn't a continuous flow but a series of "pulses" in which (in my eyes as a student in Animal Science) is kind of like a bolus of food going down an esophagus. Even when you drink water it's not like a drain, but gulps. In between those gulps, the esophagus closes due to the lack of matter. ("vacuum" i feel like it's really more of a misnomer) Except in this case, the header remains open, and the vacuum is generated by the gas pulse rushing through pushing everything out leaving a vacuum. I almost feel like I should say that it's like slipstreaming in F1. This vacuum then assists in what's generally called exhaust scavenging by helping pull in fresh intake charge during the intake-exhaust valve overlap.
This is why EL headers are "better" than UEL since the exhaust pulses will end up combining at the same time and not ruin the vacuum effect.
Is it truly a vacuum? Probably not, I feel like it's a misnomer. However, I do believe that there is a significantly lower pressure in relative to the surrounding portions of the exhaust tract, and more specifically in between the pulses and the cylinder.
Getting Away without Engine Managment? SJwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-25-2003 10:38 PM
boost control without engine management iloveturbos Engine Management & Tuning 12 12-12-2002 02:29 PM
How far can you go without engine management Santo Domingo 2.5 RS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-09-2002 08:17 PM
How far can I go without engine management with these mods... fueledbymetal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-01-2002 03:17 PM
R/C 440s without Engine Management? Help!! adamsrs Normally Aspirated with bolt-on Forced Induction Powertrain 14 10-16-2001 05:21 PM
