Old 01-08-2007, 09:35 PM   #1
ratso
Member#: 119458
Default "Drive cycle" procedure??
I have an 02' Legacy, 2.5L. When I hook a scan took to the OBD port, it flashes the O2 sensor monitor(no trouble codes though). According to the scan tool manual, this means the system monitor has not yet run and finished it's self diagnostic test. It says I need to complete a "drive cycle procedure" to complete the test so the flashing indicator clears. What is the drive cycle procedure??
Thanks,
Jim
ratso is offline   Reply With Quote
Old 01-09-2007, 12:22 AM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Drive it around for a tank then recheck? It hasn't learned any value because of a recent ecu reset(battery disconnect) or something? That would be my guess.
fibuz is offline   Reply With Quote
Old 01-09-2007, 07:00 AM   #3
ratso
Member#: 119458
Been driving it for 3 years. It has never had the battery disconnected or the ECU reset. Isn't there some sort of "drive cycle" step by step procedure?
Old 01-09-2007, 08:56 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
None that I've ever seen.
Old 01-09-2007, 10:38 AM   #5
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
No, you just drive and it gets used to your driving style and maps the fuel accordingly.
Wiscon_Mark is offline   Reply With Quote
Old 01-09-2007, 12:16 PM   #6
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
There is a drive cycle; it's pretty much universal for all OBD-II cars. It pretty much requires a tremendous amount of open space. I just tried searching for it... I know I posted it somewhere. Either way, it's a ridiculous amount of heat up, cool down, variance of and holding speeds, and so on. In your day-to-day driving, the registers should find their way to READY.
Was your O2 sensor nicely heated when you plugged in? I'm guessing that's your problem. Where are you located?
LetItSnow is offline   Reply With Quote
Old 01-09-2007, 03:54 PM   #7
ratso
Member#: 119458
I assume it was hot. I had just driven 70 miles. I live in Northeast PA.
I am going to try this scan tool on my other Subaru, it is a 97 Legacy GT, and see if it reads the same error.
spotted: blue sti, exhaust, "drivers image" LatentWagen Mid West Subaru Owners Club Forum -- MWSOC 0 08-29-2004 04:13 PM
Bets on "Drive and Stare" SoLo OnE Off-Topic 25 02-10-2003 06:52 PM
Sunday drive Dec 1, "Drive through Tree" psoper Bay Area Impreza Club Forum -- BAIC 13 12-03-2002 04:15 PM
What should I put on "Driving CD" Ghomer1 Off-Topic 49 10-31-2002 09:14 AM
Rally-X "drive it like you stole it" tom grossmann South West Impreza Club Forum -- SWIC 40 10-30-2002 04:26 PM
