Old 01-08-2007, 10:16 PM   #1
derekok
Member#: 132911
2006 Sti
SMG
Default 02 sensor went...stealership quoted
around 400 with labor....350 for the sensor. Is tha my only option?
derekok is offline   Reply With Quote
Old 01-08-2007, 10:32 PM   #2
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
The sensor itself can be had for ~$250, maybe a little less. Installing it is easy. Rent an O2 socket if you don't have one, and remember - left loosey, righty tighty. It's in the passenger-side exhaust collector. Easy to get to by removing a plastic access panel in the front inner portion of the wheel well.
RP31 is offline   Reply With Quote
Old 01-08-2007, 10:38 PM   #3
derekok
Member#: 132911
2006 Sti
SMG
Would Bosch sensor on a 06 sti be ok?
Oh and how bad is it for the engine without a working one....because I need to drive back about 800 miles...I mean chances are that it will run richer than leaner I think. Right?
Old 01-08-2007, 10:43 PM   #4
RP31
Member#: 123574
CGM STi
It is a Bosch sensor... But you have to make sure you get the right kind.
How bad it is depends on what your fuel trims are right now, but it will eventually go rich.
Old 01-08-2007, 10:46 PM   #5
derekok
Member#: 132911
2006 Sti
SMG
Ok thanks
Old 01-09-2007, 12:31 AM   #6
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Call Jamie at subaru genuine parts.
wrxfactor is offline   Reply With Quote
Old 01-09-2007, 09:46 AM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
an o2 sensor socket its worth the price i think i paid $12... you will need it
Old 01-09-2007, 10:50 AM   #8
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Vise Gips FTW. The 10" ones were perfect for removing my O2 sensor which hadn't been pulled once in 109,000 miles until I had to do it.
Old 01-09-2007, 07:41 PM   #9
joeymdz
Member#: 100715
05 Twin Scroll STI
430/430 DOM power
i literally just replaced mine... its a snap.. Like 5 minutes if that! First unplug your sensor. Turn the wheel to the right. Bend back your wheel cover (passenger side... lol) and there she is.... i used a 22mm box wrench (if im not mistaken). i was lucky enough to pick a new/used sensor for $50.00!!! SCORE! if i was to buy a new one $175.00 OEM.
But your car will run rich... very crappy below 2500rpms when its on closed loop.
joeymdz is offline   Reply With Quote
Old 01-09-2007, 07:57 PM   #10
Freon
Member#: 88322
2009 BMW 135i
Does that come with a tube of lube?
Freon is offline   Reply With Quote
Old 01-09-2007, 08:06 PM   #11
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Yeah cause if you're paying that, they are sticking it in you real bad and it's gotta hurt.
Old 01-09-2007, 08:23 PM   #12
flycaster
Member#: 60142
2011 WRX
Grey
Worse than that...they threw sand in it.
flycaster is offline   Reply With Quote
Old 01-10-2007, 05:16 AM   #13
Starkiller
Member#: 82741
2007 350Z Silver
Front O2 sensor $150 online
Starkiller is offline   Reply With Quote
Old 01-10-2007, 06:03 AM   #14
RP31
Member#: 123574
CGM STi
Link?
Old 01-10-2007, 11:26 AM   #15
Petersubaru
Member#: 134593
2001 Outback
I had the same problem not long ago..dealer and aftermarket parts place wanted $350-$400 and some online places $150..eventually got an exact fitting(Bosch) one from Importecparts.com for $55..it has worked flawlessly for the last 2months of owning the car
Petersubaru is offline   Reply With Quote
Old 01-10-2007, 05:16 PM   #16
NWstiLTD
Member#: 133458
2007 WRX STI Limited
"urban gray metallic"
that sounds a little pricey. If it is the front (pre cat) sensor dont wait because if it does run rich, it could damage the catalyst. If u need a post cat sensor you could put it off as that one just monitors the catalyst efficiency...no bearing on fuel mixture. some aftermarket sensors are crappy and require using the existing connector, crimping the wires to the sensor. dont get one of these
NWstiLTD is offline   Reply With Quote
Old 01-10-2007, 07:36 PM   #17
Dragon Wagon
Member#: 101095
1997 leggy gt
Reo Red
yes I second that I bought my air/fuel ratio sensor and o2 sensor for 263.00 shipped
Dragon Wagon is offline   Reply With Quote
Old 01-11-2007, 10:11 AM   #18
Jon [in CT]
Member#: 2992
02 WRX Sedan
You can buy an STi front A/F sensor for $165.79 + S&H from http://www.rockauto.com/catalog/cata...1428791k976688.
Jon [in CT] is offline   Reply With Quote
Old 01-14-2007, 08:26 PM   #19
angler228
Member#: 137667
Here's the cheapest source for Denso O2 sensors I found...
http://sparkplugs.com/
angler228 is offline   Reply With Quote
Old 01-15-2007, 07:23 PM   #20
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Thats the price you pay when you have a dealership install it. Learn to work on your car yourself and you can save money. If not, then pay up.
blackfang is online now   Reply With Quote
Wanted: MAF mass air sensor. 02 sensors. EGT sensor timing cover. tscott915 Private 'Wanted' Classifieds 10 10-07-2009 01:26 AM
Front 02 Sensor,Rear 02 Sensor,MAF Sensor,Blox Shift Knob,SPT Oil Cap, bunch of stuff TopEndPull Engine/Power/Exhaust 11 08-14-2009 05:48 PM
CEL came then went? 02 sensor? ScubaruImpreza05 Normally Aspirated Powertrain 3 07-02-2009 03:19 PM
WTB: 02-07 Maf Sensor, 04-07 Sti or 06-07 WRX 02 Sensor. TopEndPull TXIC Private Classifieds 1 07-26-2008 09:54 AM
Oem 02 front sensor Or Wideband 02 sensor Fast_Wrx62 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-06-2006 09:58 AM
