Old 01-09-2007, 12:37 AM   #1
Gorge
Member#: 97449
2007 WRX
Default Car won't start. Won't crank, but lights will turn on
I'm guessing the starter, but any suggestions before I hack away? I've never had problems with the starter. When I turn the key over, it'll make a humming sound, no crank, and the lights and radio will turn on fine. Any suggestions?
Gorge is offline   Reply With Quote
Old 01-09-2007, 12:38 AM   #2
Trigun001
Member#: 107092
2005 WRX Evo3 16g
Platinum Silver Metallic
battery? jump it
Trigun001 is offline   Reply With Quote
Old 01-09-2007, 12:40 AM   #3
06_Aspen_STI
Member#: 114223
2006 Subaru STI
Aspen White w/ Gold Wheel
Sounds like the starter, although I have never experance the problem. Any autozone or schucks can test it for free. Problem is you have to take it out.
06_Aspen_STI is offline   Reply With Quote
Old 01-09-2007, 12:41 AM   #4
Gorge
Member#: 97449
2007 WRX
Originally Posted by Trigun001 View Post
battery? jump it
Yah, I was thinking battery.. but my nav, lights, and radio turn on fine. They aren't dim at all. Just trying to narrow down my choices before I run to Pep boys and try to do this all tonight so I can get to work tomorrow.
Old 01-09-2007, 12:42 AM   #5
Gorge
Member#: 97449
2007 WRX
Yah, I was thinking starter.. but don't they gradually go out? Plus I never knew how inaccessible they are in these cars. I don't want to spend an hour pulling it out before I realize that wasnt it.
Old 01-09-2007, 12:45 AM   #6
Gorge
Member#: 97449
2007 WRX
HAHAHA.. Best Noob Award goes to me!!
I kicked the kill switch out. Good night all.
Old 01-09-2007, 12:56 AM   #7
Trigun001
Member#: 107092
2005 WRX Evo3 16g
you have a kill switch? thats pretty bamf.
Old 01-09-2007, 01:04 AM   #8
NWstiLTD
Member#: 133458
2007 WRX STI Limited
"urban gray metallic"
Lightbulb
lol that will do it
for anyone with the same situation, just take a test light, connect to ground, touch tip to small wire at starter (from ign start) and attempt to crank. if light comes on you pretty much need a starter, if not check your clutch switch, etc(this is assuming you have batt voltage and starter does nothing when you attempt to start)
NWstiLTD is offline   Reply With Quote
Old 01-09-2007, 01:06 AM   #9
cperkins
Member#: 48378
'04 WRX Wagon - WRB
8 minutes. That could have been a LOT worse
cperkins is offline   Reply With Quote
Old 01-09-2007, 01:23 AM   #10
socalsfinest
Member#: 133512
2005 Subaru Wrx Sti
im gonna guess starter motor...
get it checked out and tested at your local pep boys or kragen or w.e you got closest to you!
socalsfinest is offline   Reply With Quote
How-To mod the 2004/2005 fog lights to turn on with 12 volts. LESLIEx317537 Electrical & Lighting 265 05-11-2011 11:20 AM
Car will turn on but won't start HotDrifter9 Service & Maintenance 22 06-03-2005 07:54 PM
driver side HID light wont turn on intence Electrical & Lighting 19 05-07-2004 05:07 PM
The brake idiot light keeps turning on? BlueWRXWagon Brakes, Steering & Suspension 3 10-31-2002 04:45 PM
Popping noise when the lights are turned on Verist Car Audio, Video & Security 4 08-08-2001 10:41 PM
