Old 01-09-2007, 02:59 AM   #1
wrxracer25
Member#: 137061
2005 STi
Default JDM EJ20 into a 95 impreza
i own a 1995 impreza L and i just got a JDM EJ20 motor and i was wondering if anybody could give me some tips on installing it. I would like to get some info about how i would get the ej20 with hydrolic clutch to work with my pull type pedal set up in my car. that is a big one there. but any thing will definetly help me out. i need help. thanks!
wrxracer25 is offline   Reply With Quote
Old 01-09-2007, 03:46 AM   #2
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Which 'box are you using? And remember to use a turbo front crossmember too!
Marnix is offline   Reply With Quote
Old 01-09-2007, 06:28 AM   #3
Sube78
Member#: 132999
1996 "'l"w/ej20t
black/black
Default re: which box
I'm having the exact opposite problem
Sube78 is offline   Reply With Quote
Old 01-09-2007, 09:15 AM   #4
dasnube
Member#: 104658
Default RE:help!
So you have an ej20t and you're mating it up with the trans out of the subaru "l" and trying to get the cable system to work or the hydraulic one? My problem is I'm using the s.t.i engine and trans and cannot get the cable
set up in the "l" to work on it maybe we can help each other out if not good luck to you.
dasnube is offline   Reply With Quote
Old 01-09-2007, 09:40 AM   #5
kheff46
Member#: 66739
2002 WRX wagon
you have just the turbo engine? not the trans from the turbo car? your trans will bolt up and run fine. it may be weak compared to an STi trans but it will fit and drive fine.
keep the clutch/tranny in it till you get all parts to convert the cable one to hydraulic. parts you need to convert to hydr.edal box(all pedals, switches, etc), M/C, hydr. line to tranny, hydraulic tranny(RS,WRX,STi).
you don't NEED one. it'll help when your upping the power tho. your stock tranny will hold for a while and is already in the car. if you are gonna replace it, do it now.
--keith
kheff46 is offline   Reply With Quote
Old 01-09-2007, 10:09 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
mmm i would add that you NEED a new stronger clutch the stocker isn't gonna cut it
Old 01-09-2007, 10:56 AM   #7
kheff46
Member#: 66739
2002 WRX wagon
yep. sorry. oversight. thanks JAXX!
Old 01-11-2007, 02:54 AM   #8
wrxracer25
Member#: 137061
2005 STi
Default My Reply
i do have the wrx tranny hat came with the motor and so the jdm tranny has the hydrolic setup and my "L" has the cable set up. and i want to hook up the jdm tranny. so is it possible to hook up the setup from my "L" tranny and then hook it up to my jdm motor. is that possible?
Old 01-11-2007, 09:45 AM   #9
kheff46
Member#: 66739
2002 WRX wagon
no. cable won't work the hydr. clutch. you need hydr. pedals and m/c and line to use the good trans..
Old 01-12-2007, 12:19 AM   #10
wrxracer25
Member#: 137061
2005 STi
where can i get those parts to convert my pedal asembally to work on a hydro. setup?
Old 01-12-2007, 09:20 AM   #11
kheff46
Member#: 66739
2002 WRX wagon
any RS/WRX/STi/ impreza or forester(all had 2.5 and hydro iirc) most newer legacy have hydro clutch and pedal box obviously.
--keith
Old 01-12-2007, 01:48 PM   #12
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
just buy the pedals and the clutch master cylinder and the clutch line and your set.
circaisdashiat is offline   Reply With Quote
Old 01-18-2007, 02:21 PM   #13
wrxracer25
Member#: 137061
2005 STi
is there any problems that i might run into while installing this motor?
Wire Guru's: Jdm Ej20 Into 93 Impreza 4wd (No E-Techs Please) ScoobySnacksURhonda Subaru Conversions 4 09-25-2007 05:36 PM
jdm ej20 into 98 LOB davestout Subaru Conversions 8 12-26-2005 09:47 AM
jdm ej20 into a 95 1.8L smahala1286 Subaru Conversions 3 11-06-2005 11:07 PM
need help jdm wrx engine into my 95 impreza l turbocolin Subaru Conversions 5 04-14-2004 09:52 AM
putting a JDM ej20 into an impreza L...... Silver_Fox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-30-2001 07:54 PM
