Old 11-24-2001, 02:09 PM   #1
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Exclamation spark plug gap 2000 RS ??
having brain fart cant remember...throw me a bone!!
hehe
Jay McDade
Old 11-24-2001, 02:10 PM   #2
tulit
Member#: 338
09 STi
tulit is offline   Reply With Quote
Old 11-24-2001, 02:13 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
thanks!
Old 11-24-2001, 07:21 PM   #4
tulit
Member#: 338
09 STi
I meant .039 to .042 btw.
oops. sorry ;-)
Old 11-24-2001, 08:46 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
oh no!!! I gapped them at half an inch!!!
the ngks usually dont need gapping but I just wanted to check, they where all at .040
thanks again.
hehe
Old 11-24-2001, 09:40 PM   #6
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
you can also look under the hood there will be a decal there with the correct gap range for the car
tom@kartboy.com
Old 11-24-2001, 10:29 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
i looked, given that im blind...I may have missed it, Its suppose to be on the obdII certification label under tune up specs, but it only gives you valve clearances, Ive noticed on jap cars they dont like to put the spec.
anyhoooo, should I say that in 9 days Ill be employed at a subaru dealer hehe
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
www.hometown.aol.com/impreza25rs2000
Old 11-25-2001, 02:07 AM   #8
joltdudeuc
Member#: 6119
1999 GM6
RBP
doh... i went to pepboys and told him what car i had, and he said he had some Bosch Platinums... so i got them and put them in... i had a friend help me who had a socket set that would cover the job, and he said that i wouldn't need to set a gap... um do i? and how do i do that?
-Gagan
joltdudeuc is offline   Reply With Quote
Old 11-25-2001, 02:10 AM   #9
Silverscooby27
Member#: 9124
2013 Mustang GT/CS
2013 Ford Focus ST
Get a gap gauge and simply set it. My understanding is that at least in my car MY99, the gap is 0.044. The gap was very close to 0.044 out of the box, and I paid maybe $7 for the set of 4.
Silverscooby27 is offline   Reply With Quote
Old 11-25-2001, 10:58 AM   #10
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
I personally wouldnt put platinums, they are made for longevity not performance. Also you dont have platinums in there now.
the reason the gap is probably differnet on a 99 is cause it runs lower compression than a 2000/2000 *i think* its 9 to 1 DOHC and the 2000 are 10 to 1 with SOCH.
But I could wrong..
Jay McDade
Old 11-25-2001, 11:28 AM   #11
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
The compression ratio on a 99 is 9.7:1. The compression ratio on a 00-01 is 10:1.
You can't really gap platinum spark plugs, especially those platinum +4's.
Richard
Richard L. is offline   Reply With Quote
Old 11-25-2001, 12:00 PM   #12
tulit
Member#: 338
09 STi
Sure you can! (and need too).
I agree about the platinum +4's though. those can be gapped by the user.
Old 11-25-2001, 12:01 PM   #13
tulit
Member#: 338
09 STi
No there isn't...
Its in the serv manual though.
Old 11-27-2001, 04:36 PM   #14
joltdudeuc
Member#: 6119
1999 GM6
RBP
Opps.....
Well, it's run much smoother than before, so i'm pretty sure that the gap is close... But am gonna get NGK's and replace them when i get me a good wire set... i got time..
-Gagan
Old 11-28-2001, 12:57 PM   #15
ImprezedRS
Member#: 2771
2003 BMW Z4
I got a set of NGKs the other day and the gap was set at .036 and I checked on the webpage and it said to gap them to .044 so thats what I did.
ImprezedRS is offline   Reply With Quote
Old 02-26-2002, 06:18 PM   #16
joefocker20
Member#: 13745
2004 STI
I bought some NGK BKR6E-11's today and I have a 2002 2.5 RS, will I need to regap them?
joefocker20 is offline   Reply With Quote
Old 02-26-2002, 06:27 PM   #17
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
holy wow, where did this thread come from...hehe
but yes you should ALWAYS check the gap
Jay McDade
Auto Tech
Old 02-26-2002, 06:35 PM   #18
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Gap every set of plugs you buy, even if they are claimed to be "pregapped."
Wow, did it take me a *long* time to type that response or what? Jay beat me to it .
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
Old 02-26-2002, 08:55 PM   #19
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
fear my fast fingers...lol I cant believe someone actually searched and dug up this thread....
the search is ALIVE! lol
originally posted by McDade on 11-24-2001
hahah
Jay
Old 02-27-2002, 01:20 AM   #20
joefocker20
Member#: 13745
2004 STI
Should it be tight against the gapping tool or loose when youre measuring?
Old 02-27-2002, 09:29 AM   #21
ImprezedRS
Member#: 2771
2003 BMW Z4
not so tight that you can't get it out but not to loose to go to the next one.
Old 03-27-2002, 03:54 PM   #22
tsfxRS
Member#: 8442
98 2.5 RS
blur of red
Well its happened again
Im looking for hte correct gap for MY98 RS I assume its going to be .044 or close to that since the compression is similar to the MY99 I believe but I would like to make sure.
I checked the owners manual under spark plugs and it told me a lot of nothing. I called a subaru dealership and they said they didnt know because their plugs come pregapped... (which scares me a little)
I will be running NGK's heat range 8 plugs as soon as i find out hte correct gap
tsfxRS is offline   Reply With Quote
Old 03-27-2002, 05:16 PM   #23
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
IIRC, .044, sounds right, I think its a may be a little differnet, cause 98's are DOHC.
Call a different subaru dealer, cause no spark plugs come pre-gapped, even if they say they are pre-gapped, you must always check'em .
for all the non-believers...again I say THE SEARCH IS ALIVE! LOL
ill try and find out what the gap is from my friend who still works at the subaru dealer I did..his name is Booster on the board.
Jay McDade
Old 03-27-2002, 06:49 PM   #24
tsfxRS
Member#: 8442
98 2.5 RS
blur of red
thanks
also any idea what i should set my Fuel Pressure Riser at ? I want to put it in but dont know what to set it at so im waiting.
Old 03-27-2002, 10:04 PM   #25
Dolphin Overton
Member#: 1925
01 Allroad 6spd
13 Daytona 675R 99 Sprint
scientist**Actually it's .039-.043... huhoy!!!**scientist
Actually you could be right, but that's what I got off of Ravensblade-impreza on the tech specifications. It doesn't really matter I was just being a nerd
Dolphin Overton is offline   Reply With Quote
spark plug gap NGK Iridium plugs? SeaRex Factory 2.0L Turbo Powertrain 14 09-12-2004 09:49 PM
Spark Plug Gap Scooby South Factory 2.0L Turbo Powertrain 1 04-27-2001 12:10 AM
Spark Plug Gap??? Ben Legacy Forum 0 01-28-2001 10:49 AM
Spark Plug Gap SubeDonC General Forum Archive 3 09-08-2000 06:06 PM
spark plug gap for 98' RS SubeDonC Technical Forum Archive 1 08-08-2000 07:16 AM
Message Board Statistics All times are GMT -4. The time now is 08:37 PM.
