Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 01-09-2007, 11:12 AM   #1
disillusioned
Member#: 87962
06 STi
AW
Default i need a little help from the IT gurus on here.
i have a client/buddy (from a competing consulting firm, no less) that needs to extend the system partition on a WIN2K3 server.
although im throughly against it, and i would NEVER try this type of thing on any of my clients servers, im looking for some software that will extend the partition without destroying the server. the thing that worries me the most about this is that i dont know if the server is a domain controller or not.
do any of you gurus know of any software that will do this without making my life miserable?
or, has anybody been able to do this successfully?
disillusioned is offline   Reply With Quote
Old 01-09-2007, 11:14 AM   #2
OriginalSin
Member#: 66341
new drive, make the partitions dynamic, right click and extend in drive management
OriginalSin is offline   Reply With Quote
Old 01-09-2007, 11:21 AM   #3
disillusioned
Member#: 87962
06 STi
AW
if only it were that simple.
you cant extend system partitions like that.
Old 01-09-2007, 11:22 AM   #4
markman
Member#: 93623
partition magic will do it.
markman is offline   Reply With Quote
Old 01-09-2007, 11:30 AM   #5
disillusioned
Member#: 87962
06 STi
AW
ive used partiton magic with really bad results.
i think the guy is messing with Acronis Disk director.
i really hope i dont have to go in and fix his mess, if a mess is created.
Old 01-09-2007, 11:33 AM   #6
pityr
Member#: 31719
best way = backup data, fdisk, restore data.
If you have spare disks this can be done mostly offline in a spare system to minimize downtime.
pityr is offline   Reply With Quote
Old 01-09-2007, 11:39 AM   #7
cwb124
Member#: 15571
2006 06 Forester XT
Partition Magic is flakey at best on a W2k3 NTFS partition.
The only real acceptable way to do it is to back up data, add or rebuild your drives/array properly this time, and then restore data.
cwb124 is offline   Reply With Quote
Old 01-09-2007, 11:41 AM   #8
serial
Member#: 33569
Hey! Back off, man.
I'm a scientist.
FDISK doesn't exist in Win2K/2K3.
The best way is to DISKPART the drive and recreate it, e.g. copying it off and rebuilding it. Any 3rd party disk management software/ghosting software will put a FS overlay on the disk, making it difficult for recovery should it fail someday.
serial is offline   Reply With Quote
Old 01-09-2007, 11:42 AM   #9
pjcoregon
Member#: 15384
no FTL
Acronis Disk Director FTW
pjcoregon is offline   Reply With Quote
Old 01-09-2007, 11:44 AM   #10
OriginalSin
Member#: 66341
i swear i did this with an array controller and it was on the boot partition, but i only extended the data partition. maybe i dreamt it, i dunno. good luck
Old 01-09-2007, 11:47 AM   #11
cdclark
Member#: 8095
2010 OB: Subie #3
2010 Golf TDI 6sp Manual
I asked this same question here last year. I ended up using ghost to take an image of the system drive and restored it to a larger drive. This was a Windows 2000 domain controller.
cdclark is offline   Reply With Quote
Old 01-09-2007, 11:51 AM   #12
cwb124
Member#: 15571
2006 06 Forester XT
that's your fastest and easiest method of backup/restore.
I'd say forget about resizing the drives. Even Acronis is flaked on Ws03 NTFS partitions. And like someone else said, you'll have another FS on there that might caus instability.
Old 01-09-2007, 11:53 AM   #13
disillusioned
Member#: 87962
06 STi
AW
i agree 110%, unfortunately some people would rather take the easy way out in these situations.
Old 01-09-2007, 11:54 AM   #14
pityr
Member#: 31719
There is no easy way out for this. At least not one that won't cause a ton of headache later on.
Old 01-09-2007, 11:54 AM   #15
cdclark
Member#: 8095
2010 OB: Subie #3
Old 01-09-2007, 12:00 PM   #16
disillusioned
Member#: 87962
06 STi
AW
^^ thanks for the link!
Old 01-09-2007, 12:41 PM   #17
smoSTI
Member#: 99962
2005 WRB STi
'88 Porsche 944
You could always just move the data off the system disk that is using up all the space, onto what we like to call a "data" disk. I mean, does it really have to be resized?
smoSTI is offline   Reply With Quote
Old 01-09-2007, 12:50 PM   #18
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Dell gave us a utility named extpart. Google it. If you can't find it, I suppose I'd consider emailing it. :P
It works like a charm on windows 2000 and 2003 with basic volumes. I would not suggest using it on Dynamic or GPT volumes.
ColinL is offline   Reply With Quote
Old 01-09-2007, 12:52 PM   #19
pityr
Member#: 31719
He didn't mention if he was using a SCSI or SATA in a RAID setup. That would complicate things quite a bit.
Old 01-09-2007, 01:07 PM   #20
disillusioned
Member#: 87962
06 STi
AW
^^no mention of that.
now im getting really nervous...
Old 01-09-2007, 01:28 PM   #21
snorekl
Member#: 78139
2005 Saab 9-2X
Red
If he was using RAID, he could add more physical disk capacity and add the new space into the array with the RAID utility. IBM Serveraid and HP Netraid did this quite nicely when I was a boy.
snorekl is offline   Reply With Quote
Old 01-09-2007, 01:48 PM   #22
disillusioned
Member#: 87962
06 STi
AW
i realize that adding more disks, or moving data would be an acceptable solution, but i really dont know much about the server other than its a 2k3 server, and the system partition needs to be resized.
im assuming they left a tiny primary partition (as dell usually does with pre-installed servers) and the Windows folder or another app that needs to reside on the system drive is killing the space.
this would be much easier if i were the one doing the work...
Old 01-09-2007, 01:53 PM   #23
teiva-boy
Member#: 22825
Diskpart.exe will not resize a system partition.
You should really find out more about the hardware on the machine before a valid suggestion is made.
In some cases, Symantec Ghost could be used, and there will be a little downtime in this, but it works well.
In other cases, some popular drive partition programs would work too.
But whatever you do, always, always make a full system backup.
teiva-boy is offline   Reply With Quote
Needs a little help from the SC folk chinoswrx South East Region Forum 15 07-09-2009 11:14 PM
Need a little help from the Atlanta group Don Arm South East Region Forum 5 03-09-2007 07:32 AM
need help from the ecu gurus 02ej257 Engine Management & Tuning 4 01-21-2007 03:58 PM
Need help from the Networking Gurus! rlin0997 Off-Topic 2 07-19-2006 05:27 PM
A little help from the SD guys on Sat.? Longitude Southern California Impreza Club Forum -- SCIC 3 05-24-2002 02:21 PM
