South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 01-09-2007, 02:44 PM   #1
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
Default HELP missfiring issue.
hey guys, i keep getting misfiring CEL and the car has been obviously misfiring. the car idles rough when misfiring, i have only noticed it doing it when idling. if i turn off the car when its doing it and turn it back on the misfiring goes away but the cel does not. what could be causing this to happen?
Thanks
James
SubeSTIle is offline   Reply With Quote
Old 01-09-2007, 02:46 PM   #2
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
What mods?
Valhakar is offline   Reply With Quote
Old 01-09-2007, 02:49 PM   #3
le wagon
Member#: 109109
2005 WRX wagon
Wrong Fitment Crew #015
maybe you just need some new spark plugs? have you ever changed them?
le wagon is offline   Reply With Quote
Old 01-09-2007, 04:33 PM   #4
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
spark plugs are new about maybe 5-7k miles, car is stock engine wise
Old 01-09-2007, 05:20 PM   #5
LegacyGt05
Member#: 80074
2007 BMW 335i
Sapphire Black Metallic
Your fuel injectors might be going bad as well .... I had one that was going bad, but it took two weeks for it to throw a check engine light.
LegacyGt05 is offline   Reply With Quote
Old 01-09-2007, 06:10 PM   #6
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
oh thats always a happy thought... if i upgrade my injectors to STI pink 565cc injectors, do i need to upgrade the fuel pump also?
Old 01-09-2007, 11:14 PM   #7
dozer54321
Member#: 116437
good idea to do, put some injector cleaner in, prolly wouldnt hurt to try, also check your plugs, did you gap them correctly? maybe water in coil? have you been playing to gotten your car cleaned?
dozer54321 is offline   Reply With Quote
Old 01-10-2007, 12:42 AM   #8
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
Robert at FAT installed new plugs when he did my short block, i assume they were gapped correctly. i will run some injector cleaner through it, im going to get some magnacore plug wires i think and see if that helps the problems, anyone know anywhere to get those relativly inexpensive?
Old 01-10-2007, 11:19 AM   #9
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
Yeah thats what i would go for the plug wires if they are old
Poweredbysnail is offline   Reply With Quote
Old 01-10-2007, 11:41 AM   #10
LegacyGt05
Member#: 80074
2007 BMW 335i
Why haven't your brought the car back to FAT? I am sure Robert would be more than happy (Or Chris) to help diagnose your issue
Old 01-10-2007, 11:49 AM   #11
ArizonaSTI
Member#: 113345
2006 Impreza STI
Steel grey
you can pull the spark plug wire off of the spark plug while its running and maker sure that cylinder is firing
ArizonaSTI is offline   Reply With Quote
Help with issue on this forum.....(Computer issue.) JDMbyBlood General Community 5 10-30-2008 05:55 PM
Help. Missfire on all 4 cylinders. Chaotic Yeti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-24-2008 03:07 PM
Help Missfire... bee_rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-16-2007 08:39 AM
need help re/issues on the ej25 Benjamin Tang Normally Aspirated Powertrain 2 02-09-2003 08:20 PM
