Old 01-09-2007, 05:04 PM   #1
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
Default Missing Air Panel Filter
I've had my car since Aug 2003 and I never change the panel air filter until today. I've been planning to replace that darn air filter for a couple years now but I was too lazy to do it thinking that there was an air filter sitting in there.
Well, today was the day that I wanted to do this simple project. Went to the dealership and bought the filter from them. After removing the glove box assembly and removed the air filter cover, there were no filters to be found
I should've done this long time ago and for the past 3 years, I've been sniffing all the dust and all that pollen ishhh....
scooby_wooby is offline   Reply With Quote
Old 01-09-2007, 06:27 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I love the dust I sniff. Hope you got it from Perry with the discount I set up for us in VA Beach.
Old 01-09-2007, 06:31 PM   #3
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
Yeah, I bought it from Perry. Any OEM item that I need, I buy it thru them.
Old 01-10-2007, 12:16 AM   #4
hadboosttroy
Member#: 109560
2002 BMW M5
Goodbye STi :(
If you didn't get the filtration accessory from the dealer, then you have an empty spot. Are you surprised?
hadboosttroy is offline   Reply With Quote
Old 01-10-2007, 02:27 AM   #5
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
Gee for a while I thought you ran your car without an air filter X_X
Gunner is offline   Reply With Quote
Old 01-10-2007, 04:16 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....I just GOTTA try some of THAT......
I'll pm ya the addy to ship to...
....that reminds me----I gotta check mine
Old 01-11-2007, 10:53 AM   #7
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
It's a dealer option and a pricy one at that.
crampfan is offline   Reply With Quote
Old 01-11-2007, 03:35 PM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....yep. That's why I opted to purchase & install most of my add-on accessories by myself (i.e. auto-dim/compass mirror, cabin filter, alarm, etc.). Most accessories are plug & play and the instructions Subaru provides are typically very clear.
Kean is offline   Reply With Quote
Old 01-12-2007, 02:02 PM   #9
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
My wife's MY04 Forester did not have the air cabin filter. Dealer wanted $75 to install it. I just put it on later myself.
I am not mistaken, I believe MY06 was the first year the air cabin filter was standard on the Impreza model.
joecerv is offline   Reply With Quote
Old 01-12-2007, 08:51 PM   #10
Hayes
Member#: 11808
I think the cabin filter housing is standard but, not the filter. Don't know which year they put filter housing in.
Hayes is offline   Reply With Quote
Old 01-23-2007, 08:23 PM   #11
SloSubie
Member#: 63411
2004 Impreza WRX
Does the In-Cabin Filter do anything noticeble. I understand it filters the ou the Dust but Will I notice a difference.
SloSubie is offline   Reply With Quote
Old 01-23-2007, 09:03 PM   #12
ivwarrior
Member#: 100610
MBP
Probably not, unless maybe you have bad allergies.
ivwarrior is offline   Reply With Quote
Old 01-23-2007, 09:19 PM   #13
SloSubie
Member#: 63411
2004 Impreza WRX
It may be somthing from me to think about with spring around the corner. i'll talk to brad tomorrow at Perry and see whats up.
Old 01-23-2007, 10:04 PM   #14
bluesubie
Member#: 767
04 FXT
There have been pictures posted here of some very NASTY filters.
-Dennis
Old 01-23-2007, 10:15 PM   #15
Kean
Member#: 25187
'08 Foz Prem TGM
Every filter I've replaced in my Subaru was noticeably soiled with dirt/dust and misc. debris wedged within its folds. ......if I had no filter, all of that gunk would have been circulated through the cabin.
Old 01-24-2007, 07:57 AM   #16
SloSubie
Member#: 63411
2004 Impreza WRX
Im headed to the dealer with in the hour.
Old 01-24-2007, 08:08 AM   #17
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
definitely cuts down on dust - the interior of my car stays pretty clean (compared to my old car which didn't have one)
I have been using filters cut out of a large 3M Filtrete filter (the high end one) - costs less than the OEM filter (which is just a filter - no structure to it) and you get 4 to 8 filters out of it - probably does a better job filtering, too!
Old 01-24-2007, 08:32 AM   #18
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The cabin filter will cut down on dust and larger particulates entering the cabin through the vents. It won't keep the car immaculate since it's not a sealed environment, but it does help. It will NOT keep chemicals and odors out, only an activated charcoal filter can do that.
Another advantage of having the filter is that it keeps leaves and other debris from reaching the vent fan and getting caught in the blades where it makes noise. The evaporator stays clean as well, when I removed mine a while back to do the AC freezing fix it was spotless thanks to the filter.
You are most likely to notice the filter's presence if you neglect it for a very long time, after which it will become clogged and there will be little or no airflow through the vents. If you have one you do need to check/service it periodically.
Here is an old but still relevant thread about making your own filters as DrD has mentioned-
http://forums.nasioc.com/forums/showthread.php?t=476514
As long as you are willing to spend a little bit of time making the filters up, this method can save you some $ compared with buying the dealer filters at $40 a pop.
Old 01-24-2007, 10:09 AM   #19
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
The biggist thing that I have noticed, was that the evap. and heater cores stay clean, meaning that there is none of the bad smells, and I think over time it will help with the life of the cores. The filter is located after the blower motor, so it will, as far as I know, not stop debris from getting into the blower fan.
Old 01-24-2007, 04:51 PM   #20
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
Anyone have any instructions/pics of where to place the filter?
prspect06 is offline   Reply With Quote
Old 01-24-2007, 05:26 PM   #21
Kean
Member#: 25187
'08 Foz Prem TGM
.....check the link Mulder provided (two posts up from yours).
Old 01-24-2007, 07:00 PM   #22
racingfish
Member#: 60976
1969 LGT
FATURBO
yeah if u notice that your ac is not blowing as hard. it might be your cabin air filter. most people dont even know they have one... and subaru suggest to change them twice a year or 7500 miles i think it is....
racingfish is offline   Reply With Quote
Old 01-24-2007, 09:19 PM   #23
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The filter is actually above the blower fan and ahead of it in the airflow path, so it will indeed keep leaves out of the fan. However if you get enough of them in there the airflow will be noticeably less so you'll have to open it up and clean the stuff out.
You can still get mildew in the evaporator from standing water due to AC operation, the filter won't help with that.
WTB: K&N Panel Filter #33-2075, Stock 04 Air box Bimmerod Private 'Wanted' Classifieds 12 11-29-2004 03:18 PM
K&N panel filter vs Paper factory Air filter trustWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-07-2004 04:24 PM
Fram Air Hog Panel Filter JayGold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-27-2004 02:57 PM
('93-'01) K&N Air Panel Filter ???? Vinnie Impreza Forum 4 09-07-2001 07:59 PM
Cool Air intake VS. K&N panel filter metoo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-20-2001 08:41 PM
